| Barber haulers #56157 08/29/05 08:57 AM 08/29/05 08:57 AM | Anonymous
| Anonymous
Unregistered | I want to add barber haulers to my p18. I was thinking about the Hobie Miracle 20 setup because it is so simple. It goes through the front crossbeam. Does anyone have any suggestions on a better barber hauler arrangement?
Who could help me make sure I order all the parts I need (I couldn’t figure out if I had all the right parts from the diagram)? Is the hobie helpful? Or do I have to order through a regional supplier?
Matt | | | Re: Barber haulers
[Re: ]
#56158 08/29/05 10:17 AM 08/29/05 10:17 AM |
Joined: Apr 2005 Posts: 473 Panama City, Florida Redtwin
Posts: 473 Panama City, Florida | I'm not sure about the Hobie setup, but the Nacra setup is a bit of a P.I.T.A. I would say to just make sure you get good cleats. The jamb cleats on my boat just don't cut it.
-Rob V. Panama City Nacra 5.2 Rob V.
Nacra 5.2
Panama City | | | Re: Barber haulers
[Re: Redtwin]
#56159 08/29/05 02:02 PM 08/29/05 02:02 PM |
Posts: 306 St. Louis, MO | If the set up you are talking about on the H20 is stock, then you can get a parts list on the website at http://www.hobiecat.com/support/pdfs/PARTS_20.pdf This is the illustrated parts guide for the stock boat. For my Hobie I usually use this to get eh proper sizes then buy the brand I like. It's a good starting point.
Nick
Current Boat Looking for one
| | | Re: Barber haulers
[Re: hobienick]
#56160 08/29/05 02:22 PM 08/29/05 02:22 PM | Anonymous
| Anonymous
Unregistered | Yeah on that picture it is hard to tell what I need.
I know I need the two rings (BARBER HAULER RING 61290011)
The cam cleats (PIVOT BLOCK HSB129)
But there are two pulleys and two plates to mount onto the front cross bar that I don’t see. That could be BARBER HAULER UPDATE KIT 41160010 or UPDATE PLATE 41162001?
It is hard to tell.
I just want to make sure there is not a better system out there.
[Re: ]
#56162 08/29/05 07:15 PM 08/29/05 07:15 PM |
Posts: 1,911 South Florida & the Keys | The two blocks on the front beam are on page 70. Front beam assembly. It is truly simple and works very well. The only "special" parts are the mounting brackets for the pivot blocks.
Eric Arbogast ARC 2101 Miami Yacht Club | | |
428
guests, and 42
Mod | | Forums26 Topics22,406 Posts267,062 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
