enclosed trailer ideas #58022
09/26/05 07:44 AM
09/26/05 07:44 AM
Toronto, Ontario
pitchpoledave Offline OP
Toronto, Ontario
Hi Folks,
I am planning on getting an enclosed trailer for moving 3 cats, with a bit of storage in the front. Does anyone have any pictures of similar trailers? Any info or tips on how to build it? Is there anyone else out there who has one of these?
Thanks,
Dave
Re: enclosed trailer ideas [Re: pitchpoledave] #58023
09/26/05 08:31 AM
09/26/05 08:31 AM
CraigO Offline
CraigO  Offline
Nigel Pitt in Georgia at one time was toting two inside and one on the top!! Maybe someone has some pictures of his rig.
Re: enclosed trailer ideas [Re: pitchpoledave] #58024
09/26/05 09:04 AM
09/26/05 09:04 AM
I can get some pictures of Nigel's rig this weekend - I might have to sneak around 'cause that pesky Brit can be a bit cagey sometimes!
He has an internal rack system that you load a cat on and hoist it up to the ceiling inside the trailer. You can then load a second cat underneath the first, a golf cart, or even a mini cooper. Cradles on the roof allow a third cat to go up top and all the masts go on the roof.
Re: enclosed trailer ideas [Re: Jake] #58025
09/26/05 09:55 AM
09/26/05 09:55 AM
K
KMarshack Offline
KMarshack  Offline
K
Unless you are loading "A" Cats, you will be wider than the 8'6" allowed. Solutions are to break down the boats, or just hope you will not get caught. That could prove to be one expensive fine, not to mention having to hire a commercial truck driver to move your now impounded rig.
Re: enclosed trailer ideas [Re: KMarshack] #58026
09/26/05 11:35 AM
09/26/05 11:35 AM
Toronto, Ontario
Toronto, Ontario
ummm, how about a permit? They are very easy to get.
Re: enclosed trailer ideas [Re: Jake] #58027
09/26/05 11:36 AM
09/26/05 11:36 AM
Toronto, Ontario
Toronto, Ontario
Hi Jake,
Ok great...thanks a lot!
Dave
Re: enclosed trailer ideas [Re: pitchpoledave] #58028
09/26/05 11:40 AM
09/26/05 11:40 AM
RickWhite Offline
RickWhite  Offline
They are not that easy to get.., and each state you drive through will require one, except Ohio
And they are only good for one trip on specified highways.
Used to be in the heavy machinery trucking business and we had a department devoted to nothing but acquiring oversize permits.
Rick
Rick White
www.onlinemarinestore.com
Re: enclosed trailer ideas [Re: RickWhite] #58029
09/26/05 11:43 AM
09/26/05 11:43 AM
Toronto, Ontario
Toronto, Ontario
In Ontario they are easy to get, and they are good for the whole calender year.
Re: enclosed trailer ideas [Re: pitchpoledave] #58030
09/26/05 11:54 AM
09/26/05 11:54 AM
Re: enclosed trailer ideas [Re: pitchpoledave] #58031
09/26/05 12:45 PM
09/26/05 12:45 PM
pkilkenny Offline
pkilkenny  Offline
G. Wicke's website. Click on Gallery and Trailer for step by step description (w/ pics.) of enclosed 49er trailer (looks very doable w/ some mods. for cats)...
www.49ersailing.de/
pk
Re: enclosed trailer ideas [Re: pitchpoledave] #58032
09/26/05 01:30 PM
09/26/05 01:30 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Dave,
I hate trailering something that sticks out on either side of the car/truck. My idea was to turn the boats on their sides and slide them in. You have a lot more room to go up vs across.
Bill
Re: enclosed trailer ideas [Re: bvining] #58033
09/26/05 01:43 PM
09/26/05 01:43 PM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Dave,
Bill
Just make sure they are adequately supported - letting the outside of the bottom hull take all the bounce loads may not be a good thing...
Re: enclosed trailer ideas [Re: RickWhite] #58034
09/26/05 04:11 PM
09/26/05 04:11 PM
Toronto, Ontario
Toronto, Ontario
Annual Permits
An annual permit is valid for 12 months from the date of issue on all [color:"red"] King's [/color] highways. The annual permit also allows travel on Highway 407 ETR provided that the commercial vehicle has a valid transponder. The maximum dimensions permitted on an annual permit are as follows:
Single vehicle:
length 12.50 m, including a maximum rear overhang of 4.65 m
weight as per the Highway Traffic Act
Combination vehicles:
length 25 m, including a maximum rear overhang of 4.65 m
to obtain overweight privileges up to 63,500 kg, contact an MTO office
Note: rear overhang may be greater than 4.65 m with the Weight & Load Engineer's approval.
Width:
3.70 m on two lane highways and 3.85 m on multi-lane highways (standard for both single and combination vehicles)
Height:
4.26 m (standard for both single and combination vehicles)
Re: enclosed trailer ideas [Re: Keith] #58035
09/26/05 05:13 PM
09/26/05 05:13 PM
Atlanta
bvining Offline
bvining  Offline
Atlanta
Keith,
I agree you need to support the boat so that loads dont end up on on side of the hull.
You could hang the hulls on the sides of the trailer, making some nice wide, padded cradles would be easy.
Or if you wanted to get fancy you could create a sliding support system that would accept the boat and help tip it 90 deg and then slide in.
Bill
0 registered members (), 550 guests, and 24 spiders.
