| Re: chainplates
[Re: vannote]
#60381 11/07/05 01:32 AM 11/07/05 01:32 AM |
Posts: 493 Minnesota | I'd leave them in place, and try to make them look pretty.
If you are DESPERATE to remove them, I'd go the physical route and leave the heat and chemical method behind. After removing the threaded bolt, I'd try punching it out. Put a punch on the end of the rod, then hit the punch swiftly with a heavy hammer.-It's the old 'pull the tablecloth out from under the dishes' trick. If you do it quickly, inertia will leave the dishes behind. Hopefully, just some gelcote will be stuck to the epoxy, but no guarentees.
255
guests, and 10
