| Grommets #63648 12/28/05 09:17 PM 12/28/05 09:17 PM |
Joined: Apr 2005 Posts: 473 Panama City, Florida Redtwin OP
Posts: 473 Panama City, Florida | I can't find alluminum or SS grommets anywhere. Will brass grommets work OK on a trampoline? I sail in salt water.
-Rob V. Panama City Nacra 5.2 Rob V.
Nacra 5.2
Panama City | | | Re: Grommets
[Re: Redtwin]
#63650 12/29/05 06:00 AM 12/29/05 06:00 AM |
Posts: 4,451 West coast of Norway | Sailrite used to sell SS grommets in smaller sizes, they probably still do. You need some special equipment to install larger SS grommets. Brass will do nicely in a trampoline, I had a homebuildt one for several years on an old Tornado (saltwater sailed, north sea). For sails, brass grommets are not strong enough for halyards, downhauls etc. If you decide to go for brass grommets, and install them with the tool and a hammer, take care to fill them with cloth and dont overdo it when you use the hammer. You will get a sharp edge on the inside, where the lacing runs, if you do.
| | | Re: Grommets
[Re: Rolf_Nilsen]
#63651 12/29/05 03:33 PM 12/29/05 03:33 PM |
Posts: 473 Panama City, Florida | Thanks for the information. That was the news I was hoping to hear. I can get brass pretty easily (cheaply). I'll be sure not to go overboard with the hammer.
Nacra 5.2
[Re: Redtwin]
#63652 12/29/05 03:42 PM 12/29/05 03:42 PM |
Posts: 1,187 38.912, -95.37 | Rob,
I bought the "cheap" brass grommet set of fifty, with tool, for something ridiculously low like $3.99 last fall when cutting up a "cheap" tarp for a winter cover. Boy did I get what I paid for! I'm going to double the grommets on the old 16 tramp but I'm seriously considering purchasing grommets from Hobie. Don't know if it was the tool or the grommets, but sure was winky, fine for a cover but not a tramp.
| | | Re: Grommets
[Re: Rolf_Nilsen]
#63653 12/29/05 06:49 PM 12/29/05 06:49 PM |
Posts: 1,449 | Rolf, When I first started making my own sails back in the 80s. I only had brass eyelets.
As you say, they are not strong enough by themselves. So I cut a very short length of stainless tube whose OD just fitted the ID of the eyelet. I then used the rounded head of the tool I put the eyelet in with to turn the edges over to make a stainless insert for the brass eyelet and that worked fine. So for anyone who is making a sail and can only source brass it may be an option.
Regards, Phill
| | | Re: Grommets
[Re: Redtwin]
#63654 12/30/05 12:28 AM 12/30/05 12:28 AM |
Posts: 111 NYC | www.mcmaster.com is an answer:-) Aluminum, SS, load rated grommets and tools to cut holes and set grommets. And thousands other tools, materials, glues and fabrics. Excelent service... | | | Re: Grommets
[Re: Redtwin]
#63656 01/03/06 01:31 PM 01/03/06 01:31 PM |
Posts: 1,200 Vancouver, BC | Be sure you get real brass grommets, not the el-cheapo brass plated(painted?) ones that seem to be everywhere these days.
Mike.
499
guests, and 29
