Welcome Forumla 16 HiTechers #656
07/11/01 08:51 AM
07/11/01 08:51 AM
Good luck in your endeavors. This Forum should be of great interest too a good many folks!
<br>Thanks for using Catsailor.com
<br>Rick White<br><br>
Re: Welcome Forumla 16 HiTechers [Re: ] #657
07/11/01 01:31 PM
07/11/01 01:31 PM
Where is there more info on the formula 16. I did notice Performance has a new 16 footer, could it be in this class?<br><br>
637- (137 downloads)
F16 and F16 HT #658
07/12/01 06:11 AM
07/12/01 06:11 AM
Thank you Rick, for your swift reply. Much appreciated.
<br>
<br>Announcer ; There is more info on your Nacra blast and the probably To-be-F16 class at
<br>
<br>http://www.multihulls-world.com/maj/essG_852.asp
<br>
<br>The nacra blast is not expected to make the F16 HT class. It will probably fall inside the box rule but be unable to keep up with the other (grandfathered) F 16 HT designs.
<br>
<br>More info on F16 HT on :
<br>
<br>http://www.geocities.com/kustzeilen/F16HT.html
<br>
<br>and
<br>
<br>On the F16 HT webpage at :
<br>
<br>http://www.geocities.com/F16HTclass/index.html
<br>
<br>Regards,
<br>
<br>Wouter<br><br>
Re: F16 and F16 HT [Re: Wouter] #659
07/12/01 08:15 AM
07/12/01 08:15 AM
Hi Wouter,
<br>Glad to help. You can make it easier for readers by making the URL addresses simple and easy hot links. First, click on FAQs at the top of this board, and about the second or third item down shows how to use markup. It uses brackets [ ] for the instructional part of the mark up.
<br>You can also add images, smile faces, etc. the same way.
<br>Just a little tip here!
<br>Rick White
<br>Admin<br><br>
648- (159 downloads)
0 registered members (), 651 guests, and 82 spiders.
Posts267,056
