| Re: Cattrax
[Re: SoggyCheetoh]
#69507 03/17/06 02:34 PM 03/17/06 02:34 PM |
Posts: 1,187 38.912, -95.37 | Small diameter tires are a booger to get on and off rims. I'd take it to a tire shop and ask them to leak test it. If it is leaking somewhere other than at the bead, they should be able to patch it for a reasonable price.
| | | Re: Cattrax
[Re: _flatlander_]
#69508 03/17/06 02:39 PM 03/17/06 02:39 PM |
Posts: 833 St. Louis, MO, | I'd take it to a tire shop and have them put a tube in it. Cost me like $25 to have this done.
Mike Hill N20 #1005
| | | Re: Cattrax
[Re: SoggyCheetoh]
#69510 03/17/06 03:27 PM 03/17/06 03:27 PM |
Posts: 12,310 South Carolina | Sheesh...spray some soapy water on it to first fine the leak. A tire shop can put in a new valve stem for cheap. You can probably change the tire with a set of tire spoons for about the same as it would cost to pay someone to mount it....then you have the spoons for next time you need them.
Jake Kohl | | |
320
guests, and 35
