New England 100 2018
by brucat. 07/22/18 06:03 AM
do you carry one of these?
by brucat. 07/21/18 08:59 PM
F16 Effect Crew Weight Solo and 2 Up
by samc99us. 07/20/18 01:12 PM
CL258 and CL259 Clamcleats for Trap Harness
by samc99us. 07/20/18 01:11 PM
Aussie Nacra Nationals 2018-2019
by JeffS. 07/20/18 04:27 AM
What happened?
by Gato. 07/18/18 09:46 AM
W22 Trimaran
by Gato. 07/17/18 02:17 PM
Recreational A-Cat
by mmadge. 07/13/18 06:40 AM
Where did everyone go?
by DennisMe. 07/10/18 09:48 AM
Help locating Center Boards
by TexasTuma. 07/05/18 04:28 PM
Boyer hull moulds have to go
by 11Damo70. 07/01/18 07:33 PM
Hobie Getaway rudder assmbly problem
by David Parker. 06/25/18 04:08 PM
Great Lakes long distance event Around PEC
by pitchpoledave. 06/24/18 06:43 PM
Cat Trax Tire Valve #77453
06/10/06 07:13 AM
06/10/06 07:13 AM
Strafford, New Hampshire, Unit...
tonyfallon Offline OP
I've a tire whose valve is leaking.
Is there any way to fix the valve or do I have to replace the tire?
Re: Cat Trax Tire Valve [Re: tonyfallon] #77454
06/10/06 12:29 PM
06/10/06 12:29 PM
“an island in the Pacific....
hobie1616 Offline
hobie1616  Offline
You could try Slime. Available wherever fine mountain bikes are sold.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Cat Trax Tire Valve [Re: tonyfallon] #77455
06/10/06 03:33 PM
06/10/06 03:33 PM
If it's the inflation needle type and leaking from the center hole, you could try what I did when that happened:
Take an old inflation needle (plastic ones work best) and fill it with glue. Once the glue sets, insert it all the way into the valve and leave it there like a stopper.
Re: Cat Trax Tire Valve [Re: mbounds] #77456
06/10/06 04:47 PM
06/10/06 04:47 PM
The valve is probably pretty standard. Take the wheel/tyre assembly off of the cat-trax and bring it to any place that does tyre repair. The valve will cost a couple of dollars, and probably another couple of dollars to dismount, and re-mount the tyre on the wheel. Have them replace it with a standard schrader valve type valve. Don't use slime. It makes a mess if you ever do have to replace the tyre.
Re: Cat Trax Tire Valve [Re: mbounds] #77457
06/17/06 03:44 AM
06/17/06 03:44 AM
The stopper idea sounds good. I did take it to two tire places and both said no dice. It did pump up fine, but once the needle came out, it deflated. Thanks.
Re: Cat Trax Tire Valve [Re: tonyfallon] #77458
06/21/06 11:31 AM
06/21/06 11:31 AM
O
ottos Offline
ottos  Offline
O
Is the valve like a standard car valve? I'll look at mine next time I'm there - but if it is, just take it to a bike store and they should be able to replace the inner workings of the valve for a couple of bucks. If you have a friend who is a cyclist, he probably has the tool to do this.
Re: Cat Trax Tire Valve [Re: ottos] #77459
06/21/06 11:46 AM
06/21/06 11:46 AM
Syracuse,N.Y
pbisesi Offline
pbisesi  Offline
Syracuse,N.Y
You mentioned a needle, so I assume it is the basketball/football style fill valve. Take a plastic golf ball marker and trim the head to the size of the valve. (3/16" or so). Fill the tire with a ball hand pump and pop in the golf marker. I have this in all of my roleez wheels and they don't leak anymore. You can take them out in the spring for a top up and put back in.
Pat Bisesi Fleet 204
1 registered members (Isotope235), 27 guests, and 234 spiders.
Mikeylikesit, Beata, PiratesCoveCat, knussy, reiser5
7809 Registered Users
brucat 9
JeffS 4
Gato 3
Beata 1
Topics22,313
Posts266,617
Members7,809
Most Online554
May 12th, 2017
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
