| Weight of capsized rig #80207 07/14/06 05:50 PM 07/14/06 05:50 PM |
Posts: 55 Wilmette, IL | Capsized last weekend solo and had a chance to see if I could right it solo. No go. I was in the mist of trying the garbage bag over the shoulder, but didn't have enough water in it. By then, I had one motorboat, a H16 and the beachstaff jetski offering help, so with a lift of the mast, my experimenting with the bag was over.
After the fact, I'm thinking I probably needed at least 5 gallons of water to make it work.
I'm trying to do the math, but I'm not sure of the weight and moment of a capsized Blade. My guess is 20 Kg at 14 feet. To offset that, I have 138 Lbs at 3 feet. It just seems like I need quite a bit of water at 5 feet to make it work. Anybody know what weight and moment I should be using for the rig?
I'd prefer not to have to install a righting pole, but I definitely need to do something, because on weekdays, no one may see me and it's a long way across the lake. | | | Re: Weight of capsized rig
[Re: Jamie]
#80208 07/15/06 02:33 AM 07/15/06 02:33 AM |
Posts: 9,582 North-West Europe | 138 lbs body weight (63 kg) ?
You are a light fellow.
I'm more heavy myself but I think 70-75 kg persons can right the F16's with alu masts.
In your case about 5 gallons of water (19 kg) should do it for sure, total 82 kg. I'm guessing that about 3-4 will be sufficient though.
Probably best you can do is get a pully setup and a specilized bag that is easy to fill to the required amount. I refer to other for this as I never needed it. I'm about 85 kg.
[Re: Wouter]
#80209 07/15/06 06:35 AM 07/15/06 06:35 AM |
Posts: 1,246 Orlando, FL | I find a canvas bag works best (or a pillow case -- yes it'll leak, but not so quick that you can't use the water within). The plastic garbage bags don't work as well because they'll burst as you pull them over your shoulder with any substantial amount of water.
USA 777
[Re: tback]
#80210 07/15/06 08:43 AM 07/15/06 08:43 AM |
Posts: 2,718 St Petersburg FL | The plastic garbage bags don't work as well because they'll burst as you pull them over your shoulder with any substantial amount of water. Thats right, been there done that. Good thing my body weight can bring it up, but I do need some wind to do so. Jaime, you remember when I capsized at the seminar? Barely enough wind to help me bring the boat up. Try one of those righting bag rigs or like Terry said a Pillow case. | | | Re: Weight of capsized rig
[Re: waynemarlow]
#80218 07/24/06 04:02 PM 07/24/06 04:02 PM |
Posts: 1,382 Essex, UK | The early windsurfer rig 'pull up' lines were stretchy polyester and I found them comfortable and easy to use. Although I do recall that once the sail overcame the 'stiction' it came out of the water pretty quick. By contrast, when on holiday last year in Greece, the uphauls on the boards available were all prestretch. I know I'm getting older, but I had a hell of a time trying to pull up a 6.0m sail!!
Your post, Wayne, has just given me a 'eureka' moment - now I think I know why it was so difficult compared to what I remember <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
John Alani ___________ Stealth F16s GBR527 and GBR538 | | |
298
guests, and 46
