Blade Owners #80940
07/24/06 01:38 PM
07/24/06 01:38 PM
Stephen Offline OP
Stephen  Offline OP
Did anyone get a righting line with the Blade?
Stephen
Blade 718
Stephen
Phoenix Az
Re: Blade Owners [Re: Stephen] #80941
07/24/06 01:46 PM
07/24/06 01:46 PM
Edmonton, Alberta, Canada
bobcat Offline
bobcat  Offline
Not I.
Re: Blade Owners [Re: bobcat] #80942
07/24/06 02:37 PM
07/24/06 02:37 PM
Negative sir
Re: Blade Owners [Re: Robi] #80943
07/24/06 02:45 PM
07/24/06 02:45 PM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Ditto -- NO.
Only need about 12-15' of rope secured to your dolphin striker and tucked in your tramp' bag. On your first capsize you can determine where to tie a not in the rope to use on your trapeze harness hook.
USA 777
Re: Blade Owners [Re: tback] #80944
07/24/06 02:59 PM
07/24/06 02:59 PM
Ahhh, you guys must be joking !
Seriously ?
@&*&#@^E
this must be another proof of "If you want things done right then you have to do it yourself"
Re: Blade Owners [Re: Wouter] #80945
07/24/06 06:56 PM
07/24/06 06:56 PM
blade713 Offline
blade713  Offline
i did not get one either but was thinking of figuring out one of the "hawain righting rigs" for the blade so my 12 yr old would have a sheet to hold on to when trapped out. any ideas?
Re: Blade Owners [Re: blade713] #80946
07/25/06 02:36 AM
07/25/06 02:36 AM
You may also give your son the traveller sheet to hold on to.
Re: Blade Owners [Re: bobcat] #80947
07/25/06 05:19 AM
07/25/06 05:19 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
Not I.
Maybe they figured you’ll never need one or maybe they’re just being cheapskates…. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
Re: Blade Owners [Re: Buccaneer] #80948
07/25/06 07:25 AM
07/25/06 07:25 AM
Orlando, FL
tback Offline
tback  Offline
Orlando, FL
Not I.
Or more likely, personal preference of the skipper as to which style to incorporate.
USA 777
Re: Blade Owners [Re: tback] #80949
07/25/06 09:23 AM
07/25/06 09:23 AM
blade713 Offline
blade713  Offline
unfortunately the main sheet is the travelor as well on the blade so they cant hold onto that. btw, thanks for the links for the spi ball.luis
Re: Blade Owners [Re: blade713] #80950
12/04/06 08:16 AM
12/04/06 08:16 AM
M
Mirjam Offline
Mirjam  Offline
M
I've got a righting line on my Blade. I'm not sure if I should keep it in the trampoline pocket or use the ideas i've seen on this forum?
Mirjam
The Netherlands.
Re: Blade Owners [Re: Mirjam] #80951
12/04/06 10:52 AM
12/04/06 10:52 AM
It's a little quicker process if the line is already out of the bag. I've opted for a double line system, so that I can use one line to haul myself on the boat and one line to right.
0 registered members (), 465 guests, and 30 spiders.
