Nacra line specs? #81744
08/04/06 05:32 PM
08/04/06 05:32 PM
White Bear Lake, MN
h17racer Offline OP
h17racer  Offline OP
White Bear Lake, MN
Anyone know of a Nacra reference guide for various sheets/lines/shock cord size and length specs? I am soon to be the proud new owner of a 5.5 Uni and find the factory documentation lacking a bit(i.e., state the length but no diameter, etc.).
A bit ago, there was a discussion regarding frustrations with the rudder pull down line and cleat. I have searched for that thread to no avail. Anyone recall it who could point me?
Thx, Tom G
Re: Nacra line specs? [Re: h17racer] #81745
08/04/06 07:02 PM
08/04/06 07:02 PM
Tom - great boat! I think you will be pleased.
I have heard all the grumbling about the pull down cleat but I never had a problem with either of the Nacras I owned (5.2 and 6.0). There is a trick, however, and that is to purchase cheap polyester 12 strand knobby line from a hardware store to use for your rudder hold downs (their regular 1/4" line - Lowe's has it white with a red tracer). This stuff grabs really well in the v-jam cleats and I never had a problem with it including several distance races (two with over 20 hours straight on the water). My rudders never eased at all. I probably wouldn't use that line anywhere else except to tie auxillary stuff to the trailer in a pinch.
I think people run into problems when they use a slick high-tech line and it's too hard and slickery to hold fast in the v-jam cleat.
Re: Nacra line specs? [Re: Jake] #81746
08/05/06 04:29 PM
08/05/06 04:29 PM
White Bear Lake, MN
h17racer Offline OP
h17racer  Offline OP
White Bear Lake, MN
Hi Jake, thanks for the line tip. Anything else Nacra wise will be appreciated.
Sail fast, Tom G
1 registered members (Damon Linkous), 2,593 guests, and 166 spiders.
