| Re: Hobie 16 Setup
[Re: mako]
#81770 08/07/06 12:32 AM 08/07/06 12:32 AM |
Posts: 44 Minnesota | the rolling jib will be the easist, fastest. the hook is hard for everybody so dont feel bad about it. i have no ideas about the boom i sail in lakes all day with no canals
When i was your age Pluto was a planet
Blake Johnson
1973 hobie 16
sail 2663
| | | Re: Hobie 16 Setup
[Re: hrtsailor]
#81776 08/10/06 10:12 PM 08/10/06 10:12 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | As far as moving the hook goes. Be careful. If you move it low it might interfere with the jib which would tear up the leech of the jib. Moving it lower than the jib will put in a spot that could hurt someone. Imagine falling on it or flying into it during a pitchpole.
| | | Re: Hobie 16 Setup
[Re: catman]
#81777 08/13/06 05:39 PM 08/13/06 05:39 PM |
Posts: 56 | i was going to start a new thread but then i saw this and i guess ill just ask my question here. I finally got the boat in the water, hobie 14, and i was noticing that it seemed to want to burry the hull more than i remember. I pitchpoled last year and i dont really want to that again. Does this mean i have to much rake or too little? I can't rember what to do(or even if that soles the problem).
Anthony-----H14
| | | Re: Hobie 16 Setup
[Re: yankyfan2000]
#81778 08/14/06 08:07 AM 08/14/06 08:07 AM |
Posts: 56 | sorry for my last post, posted twice in a differnt thread by accident.
Anthony-----H14
| | | Re: Hobie 16 Setup
[Re: mako]
#81781 08/18/06 02:06 PM 08/18/06 02:06 PM |
Posts: 306 St. Louis, MO | May I suggest this for a solution.
Get the furler system for the jib. Much easier and very handy when you want to depower in a hurry.
For the main sail and boom I would do the following.
Near the end of your boom rivit a padeye on both sides of it about 3 inches in from the end.
When rigging the boat get the mainsail started in the track a few inches. Have the foot fully insterted into the boom. Don't tighten the downhaul. At the padeyes now on the end of your boom, tie a line about 12" long onto both of them forming a "handle". Use no more than 1/4" dia line. Attach the end of the main halyard to this handle with the shackle. Using the halyard, raise the end of the boom to the desired height and cleat.
Next, move the main traveler to the center and sheet in until the end of the boom doesn't swing side to side very much.
Now, flake the main sail onto the boom and fix with gaskets. Flaking is when you fold the sail onto itself in a zigzag pattern so when you raise it, it unfolds like an accordian.
All you have to do to finish raising the main when you are out of the canal is to undo the gaskets, move the main halyard end to the tack of the sail, loosen the main sheet, raise the sail, tighten the down haul, and unfurl the jib. You are now ready to sail in about 2 minutes. Reverse teh process for coming back in.
Nick
Current Boat Looking for one
273
guests, and 54
