| Re: Rear mast Cradle
[Re: Mike]
#83662 08/28/06 04:15 PM 08/28/06 04:15 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | I have the same set-up. Try here magic tiltYou might want to call them and ask. I got mine from a local Hobie dealer. One other thing, my strut is longer than your buddy's so you might keep that in mind if ordering sight unseen.
[Re: Mike]
#83663 08/28/06 05:47 PM 08/28/06 05:47 PM |
Posts: 248 Colorado | That looks like a pretty simple setup made from easy-to-find parts. You can probably take that picture and a few measurments to a metal fabricator and have it custom built for your situation.
H-20 #896
[Re: drbinkle]
#83666 08/29/06 07:28 AM 08/29/06 07:28 AM |
Posts: 3,293 Long Beach, California | Heya Derek - I'll get a better shot e-mailed if you need one - basically had the 2-inch welded to a plate at the bottom with four holes for U-bolts. Add a 2-inch wide flat "Y" at the top with carpet contact-cemented onto it to hold the axle. These stands are two-feet high, which I would have made shorter if I were doing this again.
[Re: waterbug_wpb]
#83669 08/29/06 10:16 AM 08/29/06 10:16 AM |
Posts: 12,310 South Carolina | Uhm, J dub... Is that boat really baby blue in color? I believe that's a spandex cover.
Jake Kohl | | | Re: Rear mast Cradle
[Re: John Williams]
#83670 08/29/06 01:13 PM 08/29/06 01:13 PM |
Posts: 2,718 St Petersburg FL | Heya Derek - I'll get a better shot e-mailed if you need one - basically had the 2-inch welded to a plate at the bottom with four holes for U-bolts. Add a 2-inch wide flat "Y" at the top with carpet contact-cemented onto it to hold the axle. These stands are two-feet high, which I would have made shorter if I were doing this again. When did you get a blade? <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> Now that is a sexy boat cover! Question, seems like that trailer is pretty darn long, how long more or less is that trailer of yours? | | | Re: Rear mast Cradle
[Re: Robi]
#83671 08/29/06 03:09 PM 08/29/06 03:09 PM |
Posts: 3,293 Long Beach, California | I spec'd it at 23-feet from ball to rear - needed the tongue length to keep from hitting the bows on the motorhome in a tight cut, and because the mast can't extend forward past the hitch. 2,300-lbs capacity for double-stacking. Whole package with stands and extra lights cost less than a Trailex with half the load capacity. I had to add the cradles, though.
#83673 08/29/06 07:11 PM 08/29/06 07:11 PM |
Posts: 12,310 South Carolina | Awww man...I wondered why I didn't get a response to my post. The image didn't come through! What I said waaaaas...."I believe that's a spandex cover".
#83674 08/29/06 08:04 PM 08/29/06 08:04 PM |
Posts: 3,293 Long Beach, California | Oh, it came through alright. Both times. I was, and continue to be, speechless... and that's really difficult for someone like me. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
668
guests, and 142
