| Re: new to Hobies
[Re: lakeleaper]
#83821 09/05/06 12:02 PM 09/05/06 12:02 PM |
Posts: 306 St. Louis, MO | It's a breather hole. You will see one on the other hull as well.
Nick
Current Boat Looking for one
| | | Re: new to Hobies
[Re: warbird]
#83825 09/05/06 07:37 PM 09/05/06 07:37 PM |
Posts: 1,246 Orlando, FL | Warbird,
You don't take on much water thru the hole in the inspection port on a capsize or turtle?
USA 777
| | | Re: new to Hobies
[Re: tback]
#83827 09/06/06 02:07 AM 09/06/06 02:07 AM |
Posts: 9,582 North-West Europe | I use the same trick and it works well. But I don't have the cords, just 1.5 mm diameter holes.
| | | Re: new to Hobies
[Re: bvining]
#83830 09/06/06 09:39 AM 09/06/06 09:39 AM |
Posts: 371 Michigan, USA | Bill,
This is a simple system. The tube goes from the top of the transom down to the bottom of the inside of the hull. If water does not cover the end of the tube on the bottom of the hull, then the hull vents freely. When water covers the end of the tube, then pressure is allowed to increase until it reaches a point where water is pumped/pushed out the vent hole at the top of the transom. When the water no longer covers the end of the tube at the bottom of the hull, pressures will equalize. I think this would be excellent to evacuate the water inside the hull as long as the tube in the bottom of the hull is positioned where the water gathers while resting on the beach. I don't believe it to be particularly effective while sailing, as motion of the hull would periodically allow the low end of the tube to not be submerged and vent all pressure.
Les Gallagher
| | | Re: new to Hobies
[Re: Rolf_Nilsen]
#83831 09/06/06 11:19 AM 09/06/06 11:19 AM |
Posts: 12,310 South Carolina | Do you have any pictures of this Bill? Very interesting solution!
I am not an engineer, but the question sounds like "how much pressure do you need to a lift a 1/8 water column the distance from the bottom to the top of the transom". If the answer is more than the hull can withstand, or the pressure finds another hole to vent trough, you have a problem <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> The diameter of the water column doesn't have any affect on the amount of pressure required (since, as the diameter of the tube increases, the amount of surface presented to the applied pressure also increases equaly). To raise a column of 12" in a round tube requires a little less than 1/2 psi. (.34 bar for 30 cm) - that's not much pressure. It does make me wonder though, if the water came in from somewhere other than the tube, there is a hole somewhere else in the hull. This hole would tend to bleed off the pressure before the tube could push out the water. I'm not sure what you've gained with the tube when it comes to getting water out of the hull.
Jake Kohl | | | Re: new to Hobies
#83832 09/06/06 03:40 PM 09/06/06 03:40 PM |
Posts: 4,451 West coast of Norway | The diameter of the water column doesn't have any affect on the amount of pressure required (since, as the diameter of the tube increases, the amount of surface presented to the applied pressure also increases equaly). *boggle* I believe you Jake, but I have to let that mature a bit. It is easier to accept if the mass of water stay constant, while diameter of the column varies? Our Marstrøm Tornado hulls are pretty airtight (even with the venting holes in the inspection port lids), but we still get half a cup of water in them from time to time. I suspect that the water comes from condensation.. Same might happen with Steve C's hulls. | | | Re: new to Hobies
[Re: Rolf_Nilsen]
#83834 09/06/06 09:05 PM 09/06/06 09:05 PM |
Posts: 12,310 South Carolina | I know...that's a weird one to grasp.
Suppose you have 1psi (pound per square inch) of pressure (sorry for the English measurements) inside the hull. You also have two tubes of different size with water in them. The amount of force pushing the water up the tube is calculated by multiplying the pressure (psi) by the cross-sectional area of the inside of the tube (the exposed surface of the water that the pressure would push on).
If you have a tube that has 1 square inch of area (cross-section), at 1 psi, you have 1 lb of force pushing up the water.
If you have a tube that has 2 square inches of cross-sectional area, it has it has exactly twice the amount of liquid in it - right? If you apply the same 1 psi to this tube, you have twice the area...again you multiply the area (2 square inches) by the pressure (1psi) and get 2 lbs of force...exactly twice the pressure exerted on the 1 square inch tube - and you have exactly twice the amount of water...same lift.
Jake Kohl | | |
261
guests, and 45
