Hull damage #84034
09/04/06 10:50 AM
09/04/06 10:50 AM
f1jqcart Offline OP
f1jqcart  Offline OP
Hi everyone. I am brand new to the board, and new Hobie 16 owner. Unfortunately my boat was on the wrong side of a 'hit and run'. The port hull was the only thing damaged. A 1 foot section of the hull (about 8 inches from the bottom of the hull) was torn. The hull doesn't cave in completly but would more than likely take in water. I'm not too interested in seeing my boat will sink, because I think it will. Since this is the first boat I have owned I was wondering if this is something I can have fixed at a boat repair shop or if I will have to order a new hull for the boat. It is an older boat, 1978, so it has the yellow hulls. Does the hull color make it more difficult to fix it? Is it even possible to order a new yellow hull or do they only come in white now? Thanks for everyones help. I wish I could have started off my posting with a happier question, but at least I was able to have some good times on the boat for about a month before this happened.
Re: Hull damage [Re: f1jqcart] #84035
09/04/06 11:23 AM
09/04/06 11:23 AM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
It can be repaired. I got speared by a port tacker once and probably had more damage than you describe. Find a boat repair shop that can handle foam core construction and all should be good. The only real problem you may run into is matching the yellow. The color has probably faded a bit after 28 years.
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Hull damage [Re: hobie1616] #84036
09/06/06 05:38 PM
09/06/06 05:38 PM
Coopersburg, PA
V
Vinny_M Offline
Vinny_M  Offline
V
Coopersburg, PA
Yeah, I would go to a boat repair shop and also have inspection ports installed. They are great to have and provide a nice view of the hulls to check-up on repairs and leakage.
~vinny~
Re: Hull damage [Re: Vinny_M] #84037
09/07/06 08:53 PM
09/07/06 08:53 PM
Minnesota
hititmaestro Offline
Minnesota
Does anyone know of a good shop in the metro area of Minnesota?
When i was your age Pluto was a planet Blake Johnson 1973 hobie 16 sail 2663
Re: Hull damage [Re: hititmaestro] #84038
09/08/06 11:56 AM
09/08/06 11:56 AM
California
mmiller Offline
mmiller  Offline
California
Good shop? One of the best Hobie dealers in the country is right there. Hi Tempo. They should be able to help or identify a repair shop that can in the area.
HI TEMPO SKI AND SAIL
3959 N. HIGHWAY 61
WHITE BEAR LAKE, MN 55110
Phone: 1-651-429-3333
E-mail: brad@hitempo.com
Hobie Cat Forums
Matt Miller
Hobie Cat Company
0 registered members (), 268 guests, and 25 spiders.
