| Re: Prindle 19 rudder system
[Re: Bobby]
#84566 09/12/06 08:08 PM 09/12/06 08:08 PM |
Posts: 264 Long Island, NY | There is a small hole below the V jam on the arm. This is where the line that pulls your rudder down should be lead. You'll have to re-feed this line from where it leaves the rudder casting and enters the arm. Taping this line to a coathanger will help you to feed it through the arm. It should have a stopper ball at its' end.
G Gove
Blade #728
Long Island, New Yawk
[Re: aodhan]
#84568 09/13/06 12:29 PM 09/13/06 12:29 PM |
Posts: 1,203 uk | Lots of silicone spray on the moving parts and make sure that the rudder is fore/aft because any turning forces will hike up the friction.
| | | Another Prindle Rudder System Question
[Re: ferminj]
#84571 09/13/06 02:06 PM 09/13/06 02:06 PM | Anonymous
| Anonymous
Unregistered | Has anyone changed out the safty pin that holds in the rudder pins? It looks like a big safety pin. I go through 2 a year and it feel off in the last race. What else could I use? I never disassemble the boat, so it does not need to be convenient. | | | Re: Another Prindle Rudder System Question
[Re: ]
#84572 09/13/06 06:59 PM 09/13/06 06:59 PM |
Posts: 264 Long Island, NY | I tried those safety pins several years back. The starboard one fell out while sailing in about 15+ knots of breeze. The pintle fell down several inches causing the rudder casting to flop over 45 degrees and chip the gelcoat. It wasn't easy getting it together and back to shore. Since then I use a split ring with a curved end that makes it easy to attach and remove. I haven't had a problen in 10 years.
G Gove
Blade #728
[Re: aodhan]
#84573 09/13/06 07:07 PM 09/13/06 07:07 PM |
Posts: 264 Long Island, NY | The circular plastic shims work well. Murray's marine sells them. I'm not sure if Catsailor does. For recreational sailing I loosen the bolt where the rudder pivots slightly. This makes it easy to raise and lower. For a race I'll snug it up so that the rudder just barely falls under its' own weight while sitting on the beach. This makes it harder to raise and lower but it takes a lot of the slop out and improves helm response.
G Gove
Blade #728
[Re: gregP19]
#84574 09/14/06 07:42 AM 09/14/06 07:42 AM | Anonymous
| Anonymous
Unregistered | I tried those safety pins several years back. The starboard one fell out while sailing in about 15+ knots of breeze. The pintle fell down several inches causing the rudder casting to flop over 45 degrees and chip the gelcoat. It wasn't easy getting it together and back to shore. Since then I use a split ring with a curved end that makes it easy to attach and remove. I haven't had a problen in 10 years. Thanks, I will try split rings. I have almost the identical story to yours... What about using a cotter pin? Matt | | | Re: Another Prindle Rudder System Question
[Re: sruffner]
#84576 09/14/06 10:40 AM 09/14/06 10:40 AM |
Posts: 130 CA | | | | Re: Another Prindle Rudder System Question
[Re: ]
#84578 09/14/06 07:35 PM 09/14/06 07:35 PM |
Posts: 264 Long Island, NY | I used cotter pins when I had a P16 because there isn't much room to insert a split ring. A cotter pin would be fine for your use. I take my rudders off when I trailer the boat to races or when there is unusually nasty weather on the way when my boat is on the beach. I really don't like this type of rudder system. I've learned how to tweak it after all these years but would prefer any of the other systems available.
G Gove
Blade #728
586
guests, and 101
