| Re: old 16 project/re-paint/sail tube/tramp repair
[Re: skipper0802]
#86444 10/12/06 02:28 PM 10/12/06 02:28 PM |
Joined: Jul 2006 Posts: 17 Seattle, WA skipper0802 OP
Posts: 17 Seattle, WA | Hi All, The sailtube was made from 14" diameter, smooth-wall duct from a local A/C contractor. The endcaps were also obtained there. Banding to secure the tube is common 1/2" strap banding used in many warehouses. Steel rivets secure all the hardware. I used portions of a 6" hose clamp (for dryer duct) to fasten the banding to the clamps. (I now recommend using a heavier gauge clamp just for piece of mind - the metal in the current clamps is "soft"). The brackets I had bent-up in our sheet steel press at work. I allowed about 2" clearance for the tube diameter and used a metal-blade scroll saw to make the relief cut. I also used edge dressing from a local electrical supply shop so the bracket edge would not chew into the tube. Brackets are fastened to the trailer with (2) 1/4" diameter bolts each. I mounted the hatch hinge off-horizontal so the hatch would hang out of the way when I'm moving items in and out. The 14" diameter allows me to store the mainsail, jib, paddle, rudders w/tillers, tiller cross-bar, extra life jackets and other collateral gear. The hatch is self-draining by fit. There is plenty of clearance between the tube and the boat. The whole assembly is rigid during travel and should prove durable over time. I expect some oxidation but for me that's OK. You might want to cover the rivet tips inside with some type of plastic/rubber cap at the hinge and lock bracket to avoid marring any items inside whilst moving them in and out. This is a fairly general description, for details please contact me at skipper08022000 at yahoo dot com. In the message to follow I'll discuss the re-paint portion of the project.
Cheers, Eric
Eric Abbott Former Hobie 16 owner Seattle, Washington, USA
[Re: h77]
#86446 10/13/06 10:49 AM 10/13/06 10:49 AM |
Posts: 17 Seattle, WA | H77, Thanks for your message. The deck plate (or inspection ports) were purchased from "West Marine", ( www.westmarine.com). The instructions called for a 6-1/2" rough opening; so I routed my old openings to the appropriate fit. These plate do not have a flange surface which is designed for a curved hull mount so I used marine grade white silicon to form, seal, and fill the gap. Hobie hulls have an inner and outer surface of fiberglass with foam in between. I applied the silicon then fitted the port. I used a wetted finger to form the fillet between the flange and the hull; this turned-out OK as you can see in the picture. After the silicon had dried I used the correct drill size to open bolt holes through the sealant. I was careful not to disturb the silicon's integrity. The through-hull mounting bolts will not provide much of a structural benefit as they would just crush the foam as the nut/bolt is tightened. I used SS parts with a 5/8" plate washer and a nut with a nylon thread lock. I tightened them just enough to start compression on the hull. After installation was complete, I greased the o-ring and the port-cover threads with petroleum jelly per the instructions. The whole assembly feels solid and should provide many seasons of service. I plan to add port bags (also available from West Marine), in the future. I hope this was helpful. Cheers, Eric | | | Re: old 16 project
[Re: skipper0802]
#86449 10/24/06 01:12 PM 10/24/06 01:12 PM |
Posts: 251 beaufort, sc | i don't see any pics...is there an attachment or file somewhere? <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
marsh hawk
| | | Re: old 16 project
[Re: MudCat]
#86453 12/27/06 06:13 PM 12/27/06 06:13 PM |
Posts: 5,582 “an island in the Pacifi... | I am planning to install deck plates. Is forward of the front pylons the best location? I was thinking beteen the pylons would make sense. Any suggestions? First question is why do you want to install them. If it's for storage then between the pylons will work. If it's for repair work on the front pylon or a delaminated deck then you're probably looking at forward of the pylon. US Sail Level 2 Instructor US Sail Level 3 Coach | | | Re: old 16 project
[Re: MudCat]
#86455 12/28/06 02:08 PM 12/28/06 02:08 PM |
Posts: 5,582 “an island in the Pacifi... | Where's the best between the Pylon location to put the ports? I was thinking center or towards the rear pylon. I'd stay as far from where the stays attach to the hulls as possible. US Sail Level 2 Instructor US Sail Level 3 Coach | | |
326
guests, and 14
