CL258 and CL259 Clamcleats for Trap Harness
by Beata. 07/20/18 10:04 AM
Aussie Nacra Nationals 2018-2019
by JeffS. 07/20/18 04:27 AM
What happened?
by Gato. 07/18/18 09:46 AM
W22 Trimaran
by Gato. 07/17/18 02:17 PM
Recreational A-Cat
by mmadge. 07/13/18 06:40 AM
Where did everyone go?
by DennisMe. 07/10/18 09:48 AM
Help locating Center Boards
by TexasTuma. 07/05/18 04:28 PM
Boyer hull moulds have to go
by 11Damo70. 07/01/18 07:33 PM
Hobie Getaway rudder assmbly problem
by David Parker. 06/25/18 04:08 PM
F16 Effect Crew Weight Solo and 2 Up
by tback. 06/25/18 08:56 AM
Great Lakes long distance event Around PEC
by pitchpoledave. 06/24/18 06:43 PM
self tacker innovations #92969
12/20/06 10:56 AM
12/20/06 10:56 AM
Graham, NC
WindyHillF20 Offline OP
Graham, NC
Ok, so I'm bored at work. Received the jib from Rick last night and ready to install the system. I know many of you have tweaked your set-ups and am curious what you like best, what doesn't work and any diagrams of blocks, lines etc. Again this is going on a TheMightyHobie18 with curved beam. Would like to keep it as simple as possible and as clean as possible. I have seen self tackers but never sailed with one so please inform me!!! I have the new style system from an '06 I-20.
Re: self tacker innovations [Re: WindyHillF20] #92970
12/20/06 01:05 PM
12/20/06 01:05 PM
Framingham, MA
acceleratedchaos Offline
Framingham, MA
check the end bolts at the outboard end of the track. They were tapped and screwed in on the one I got, and on day three of sailing with it, it stripped and the car came off of the track and through a brand new jib. The jib was replaced and I thru-bolted the end screw on each side, and have no complaints! A really easy fix for a potential problem that could be avoided. Not sure if this is a specific problem to me, or if it has happened to anyone else.
Chris
accelerated chaos
Re: self tacker innovations [Re: WindyHillF20] #92971
12/20/06 03:55 PM
12/20/06 03:55 PM
Columbia South Carolina, USA
dave mosley Offline
dave mosley  Offline
Im curious to see how it fits on a curved beam....hummmm...
Bring it to CSC New years, we will assemble it around the fire with beer....should work GREAT!
Re: self tacker innovations [Re: dave mosley] #92972
12/20/06 04:24 PM
12/20/06 04:24 PM
Graham, NC
Graham, NC
Great idea, lets do something no one has done before and lets drink while at it. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Actually its not a bad idea to get several experienced sailors to look at it and give their ideas. I know Jake would be helpful with this. Maybe I can just send the boat, you guys install everything and then I could pick it up. That sounds good to me. I will be in Myrtle over New Years, kind of a tradition. Great partying can be had in Myrtle.
Re: self tacker innovations [Re: WindyHillF20] #92973
12/20/06 04:26 PM
12/20/06 04:26 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Windy
i take it that you have got a new jib. Have you changed the mainsail too? Do you think that a square top would work on the 'soft' diamond rig of the TheMightyHobie18?
I find that you only need 2 track positions on a self tacker - In a bit from the end for flat water or right out for rough/windy.
Re: self tacker innovations [Re: TEAMVMG] #92974
12/20/06 04:40 PM
12/20/06 04:40 PM
Graham, NC
Graham, NC
TEAMVMG,
Have Tiger jib now. Allready running Tiger ST main and chute. Put SX mast on, running 500lbs in the diamonds to pre-bend a little. The comptip is certainly an issue with the squaretop. The 18 jib disturbs the main and spin so changing to a self tacker with Tiger jib.
Re: self tacker innovations [Re: WindyHillF20] #92975
12/21/06 02:12 PM
12/21/06 02:12 PM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
I would think that the Tiger self tacker would have worked better. The one I had you could side the post along the track to help fit the beam and you also could cut the post off to help fit the curved beam. On the N20 self tacker the post do not move and cuting them and making the post fit back in the bracket will be harder. Bring it to CSC over new years I have some battery drills and we all know how I like to drill holes in boats. Maybe Jake can bring a welder
Re: self tacker innovations [Re: Dlennard] #92976
12/21/06 02:53 PM
12/21/06 02:53 PM
Graham, NC
Graham, NC
Dave,
I would say you are right. I got quite a deal on this unit as it had been damaged on Trey's new boat. The legs do not slide but can be attached in different areas. I'm not sure if they could be cut down or not. Mt thoughts were that the center recieved less load than the outside so moving the feet to the outer ends and resting the center on the crossbar would work. My S.C. plans for New Years are not set in stone but the spouse, that doesn't want me to race anymore, would have to give the green light. I'm not so confident about that happening.
Re: self tacker innovations [Re: WindyHillF20] #92977
12/21/06 09:48 PM
12/21/06 09:48 PM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
I'll also have all my parts and equipment with me in Columbia to do this kind of retrofit. Drills, a rather large rivet gun, and a box of toys.
Trey
Re: self tacker innovations [Re: NCSUtrey] #92978
12/21/06 10:38 PM
12/21/06 10:38 PM
Trey is lying.
You know why?
Because he's a redneck
and rednecks' toolboxes only have two things.
Duct Tape for things that don't stick that ain't stickin
and
WD40 for things that stick that don't need to be stickin
Hope you like duct tape :P
Re: self tacker innovations [Re: MauganN20] #92979
12/21/06 10:45 PM
12/21/06 10:45 PM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
Hey, if you can't duct it, f**k it.
Trey
Re: self tacker innovations [Re: NCSUtrey] #92980
12/22/06 11:53 AM
12/22/06 11:53 AM
Graham, NC
Graham, NC
Where I'm from its called Racin' tape. Can hold on at 100mph or better. I've requested the time off to attend this event, don't have clearance yet. When will you guys arive? Where are you staying? I would think its going to be too cool to camp. And is the race one day only? Should I come in Sat or Sun?
Re: self tacker innovations [Re: MauganN20] #92981
12/22/06 02:27 PM
12/22/06 02:27 PM
chesapeake bay
davidn Offline
davidn  Offline
chesapeake bay
Motto from the Duct Tape Council of America:
"Duct tape, because nothing in life is permanent."
David
now A cat and starting over on the learning curve.
Re: self tacker innovations [Re: davidn] #92982
12/22/06 03:02 PM
12/22/06 03:02 PM
Speaking of tape, anyone have experience with this stuff(Gorilla Tape)?
Its looks impressive
Re: self tacker innovations [Re: MauganN20] #92983
12/22/06 04:32 PM
12/22/06 04:32 PM
“an island in the Pacific....
hobie1616 Offline
hobie1616  Offline
If you're really good at using duct tape you can enter a contest. This would be good for junior sailors as there's scholarship money awarded.
http://www.ducktapeclub.com/contests/prom/
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: self tacker innovations [Re: WindyHillF20] #92984
12/23/06 02:07 PM
12/23/06 02:07 PM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
I'll be there on Friday sometime to set up the N20. I will probably leave sometime on Sunday evening, possibly Monday morning. So....try to be there all weekend if you can.
I'll be camping regardless of weather.
Trey
Re: self tacker innovations [Re: NCSUtrey] #92985
12/24/06 12:57 PM
12/24/06 12:57 PM
Wait! what if the distance racing is on Monday! You going to leave me boatless?
Re: self tacker innovations [Re: Jake] #92986
12/24/06 03:36 PM
12/24/06 03:36 PM
Uh oh the natives are restless! :P
Re: self tacker innovations [Re: Jake] #92987
12/24/06 09:22 PM
12/24/06 09:22 PM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
NEVER! I don't have to be back at NC State until the 10th...
Trey
Re: self tacker innovations [Re: NCSUtrey] #92988
12/26/06 06:57 PM
12/26/06 06:57 PM
Annapolis Md.
LuckyDuck Offline
LuckyDuck  Offline
Annapolis Md.
Man you guys will hijack a thread in a heartbeat. I was looking for the thread on the CSC New Years Regatta when I found this so I'm jumping in here. Weather looks good. Not much breeze but good temps. I'm hoping to get on down there if I don't have to work and if y'all don't mind someone from this close to the Mason Dixon line murking up the spring fed lake down there. Ed
F-16 Falcon #212
1 registered members (Beata), 30 guests, and 281 spiders.
Mikeylikesit, Beata, PiratesCoveCat, knussy, reiser5
7809 Registered Users
JeffS 4
Gato 3
mmadge 1
Topics22,312
Posts266,605
Members7,809
Most Online554
May 12th, 2017
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
