nacra 450 vs hobie #95574
01/09/07 06:14 PM
01/09/07 06:14 PM
M
mikewi Offline OP
mikewi  Offline OP
M
I have had a hobie wave several years and would like to move up a step in performance. I am in my early 50's, weigh about 215 lbs, usually sail solo on an inland lake, and do not race--just like to tool around. The Hobie Getaway and 17 seem a little big for a single person to right. On paper, the Nacra 450 looks about the right size. Nearest Nacra dealer is 10 hrs away, so I'm concerned about getting repairs. (Hobie dealer is 3 hrs away.) Anybody have any feedback on Nacras regarding reliability? Anybody with a 450 have any comments on performance and stability? Any other suggestions? Thanks
Re: nacra 450 vs hobie [Re: mikewi] #95575
01/09/07 07:42 PM
01/09/07 07:42 PM
If I'm able to right the H17 at 170lbs, you could do it for sure.
Re: nacra 450 vs hobie [Re: MauganN20] #95576
01/09/07 08:21 PM
01/09/07 08:21 PM
Mike:
Keep the Wave and add this!! You will have a giant killer that is light to move:
http://store.catsailor.com/tek9.asp?pg=products&specific=jmnrkomnk0
Doug
Re: nacra 450 vs hobie [Re: mikewi] #95577
01/09/07 08:44 PM
01/09/07 08:44 PM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
I do not know if you are planning to buy a new one or a used one. If you are planning on a new one you make just consider getting a used Formula 16 instead. You do not have to sail it with a chute or even a jib and it is very easy for one person to right. I think that Rick has an ad for one at less than $9000.
A Nacra 500 performs about how a Hobie 16 does. I was just involved with a youth multihull clinic. We had a couple of Nacra 500s about 6 Hobie 16s and an SL16. I would guess that the 450 being about 2 feet shorter would perform more along the lines of a Hobie 14. I would say that is just barely a step above the wave.
What are you trying to accoplish with this purchase? For tooling around the Wave is a good boat. For more performance, non-racing of course, then...?
Another easily righted boat would be an A-Cat. Sometimes you can find them for under $10K and that is a ride!
Later,
Dan
Re: nacra 450 vs hobie [Re: ] #95578
01/09/07 10:11 PM
01/09/07 10:11 PM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
Isn't the whole hooter on a wave thing a case of 1 foot itis? Why not just get a f17, f16 or A class?
Re: nacra 450 vs hobie [Re: pitchpoledave] #95579
01/09/07 11:06 PM
01/09/07 11:06 PM
He says he sails solo and doesn't race. Why does he need a race boat? For a about $2200 he would have a fast boat he can handle and move by himself.
Just my 2 cents.
Doug
Re: nacra 450 vs hobie [Re: ] #95580
01/09/07 11:13 PM
01/09/07 11:13 PM
Norman,OK
gree2056 Offline
gree2056  Offline
Norman,OK
The wave looks fun and with the Hooter it could be a blast. Isn't that wave a little slower than the 14? I bet with the hooter you would be smoking them and other small cats.
Re: nacra 450 vs hobie [Re: mikewi] #95581
01/10/07 01:30 AM
01/10/07 01:30 AM
Central California
ejpoulsen Offline
ejpoulsen  Offline
Central California
The nacra 450 is too small for you. Instead, look at the nacra 500 (or nacra 5.0) or even a hobie 16; you could still right either. The nacra 450 hulls have less volume than the Wave (they're longer but narrow).
Eric Poulsen
A-class USA 203
Ultimate 20
Central California
Re: nacra 450 vs hobie [Re: mikewi] #95582
01/10/07 02:47 AM
01/10/07 02:47 AM
I would put a roller-furling Hooter on the Wave. It makes it a whole different boat in the lighter winds that predominate on a lot of lakes in the summer. I would also install a traveler track for the mainsail, and add the optional trapeze (just for fun in heavier air). <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
Re: nacra 450 vs hobie [Re: Mary] #95583
01/10/07 03:26 AM
01/10/07 03:26 AM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
For the cost of that re fit he could get a Hobie 17 and then sell on the Wave.
Re: nacra 450 vs hobie [Re: warbird] #95584
01/10/07 03:50 AM
01/10/07 03:50 AM
Well, the Hobie 17 is probably heavier to move around and harder to right and takes a lot longer to rig than a Wave.
Plus, I don't know where he sails, but if it is on United States midwest or northeast inland lakes, summers have notoriously light wind, and ANY boat is going to be slow and boring. If that is the case, he is going to want a hooter on the Hobie 17, too.
Plus, his weight won't particularly affect boat performance with the Wave, whereas it probably will with the Hobie 17, which has a lot less buoyancy.
And at his age, the Hobie 17 might be a little more athletic than he wants -- is he going to want to trapeze off the wing if it is windy? Especially when he is solo sailing and probably pretty much alone out there on the lake as far as other sailors watching out for him?
On the other hand, in lighter air, the wing is more comfortable seating for us older folks -- I have thought about putting some kind of lawn chair on my Wave. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: nacra 450 vs hobie [Re: mikewi] #95585
01/10/07 04:54 AM
01/10/07 04:54 AM
Thailand
Buccaneer Offline
Buccaneer  Offline
Thailand
All three ARE RIGHTABLE under the right conditions. At 215 the 4.5 will be the only one of the three you could right in all conditions without the use of a bag.
The 450 is also bullet proof and most of the parts are ronstan (readily available and cheaper then Hobie) and it’s simple to repair fiberglass. The 450 like the 5.0 both have very good handling characteristics.
The Gateway is the slowest of the three and made from plastic similar to the wave so it’s also the heaviest of the three as well. Advantage of plastic being impact resistance and not weight and speed.
The H17 is the fastest and most powerful of the three and uses center boards so will tack/ turn easier but you’ll need to bring along a righting bag as it’s heavier with a longer mast then the 4.5 (the N5.0 is actually lighter then the H17).
Buoyancy wise the 450 was approved in AUS for up to four persons. <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Re: nacra 450 vs hobie [Re: mikewi] #95586
01/10/07 10:33 AM
01/10/07 10:33 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
Here's two that nobody has mentioned, but I've always thought about for just your purpose (single handed fun sailing):
Taipan 4.9 uni
Nacra/Inter 17, regular or R
Both boats have a great level of performance for the single handing sailor. Both boats can handle taking an extra person along for a ride. Both boats have the option of using a spinnaker when you're ready to try that (believe me, once you do you'll be hooked).
Nacras are pretty darn reliable. Most things you may need a dealer replacement for could be shipped to you.
Re: nacra 450 vs hobie [Re: Keith] #95587
01/10/07 11:02 AM
01/10/07 11:02 AM
Mike:
If you go 17 route. I will show you how to make it fast and fun in heavy or light air.
Doug
dsnell4 at houstom dot rr dot com
Re: nacra 450 vs hobie [Re: Buccaneer] #95588
01/11/07 11:43 AM
01/11/07 11:43 AM
M
mikewi Offline OP
mikewi  Offline OP
M
Thanks for all the replies, it's appreciated. When I compare the 450 to the Wave I see a boat that is 2 ft longer, 1 ft wider, weighs 280 lbs vs. 245, has jib blocks on the front beam instead of the tramp, and a portsmouth rating of 77.5 vs 93.4. A big jump for not much weight or size. The 500 is another 2 ft longer, and weighs 340 lbs. The Getaway is 390 lbs. I do remember a post by Danno where he had a leak in a hull on his 450. That concerns me. The rotomolded hulls on the Hobie have been darn near torpedo proof. I do wonder how much less bouyant the 450 is. On my lake there are some lowrider 16's when 2 good size adults are aboard. BTW another poster mentioned NACRA's "uninspiring" website. Amen to that! Thanks to everyone for your input.
Re: nacra 450 vs hobie [Re: mikewi] #95589
01/11/07 11:49 AM
01/11/07 11:49 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
We had a fellow in our club racing a 500 - very nice little boat, and worked very well for him both single and double handed. I would tend to try to go as large as you can and still be comfortable with moving it around.
Out of the boats I've had, the NACRA hulls have been the best.
Re: nacra 450 vs hobie [Re: mikewi] #95590
01/11/07 02:23 PM
01/11/07 02:23 PM
If you want a rotomolded boat that also performs like a true beach cat then the best options are to found here.
Dart 16 (standard)
Dart 16 (X-version)
The Dart 16 X versions looks alot more modern and it probably a quite pleasant and performant beach cat.
The pricing is very acceptable as well, as so far I can compare them to EU pricing for nacra's and hobie.
I think this Dart 16 X-version should have been the youth boat over the SL16 if ISAF had actually followed their own design goals as defined during the youth selection proces. The difference with the SL16 ? Rotomolded hulls.
Re: nacra 450 vs hobie [Re: Wouter] #95591
01/11/07 02:33 PM
01/11/07 02:33 PM
Dart 16 (standard)
Dart 16 (X-version)
I suspect the Dart 16X is Laser's knee-jerk response to the announcement from Topper of the new Topaz 16C, designed by Yves Loday and Rob White, which coincidentally is also available in two versions of similar spec to the two Darts. Surprise, surprise! They're the 16C and 16CX! <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" />
The main difference is that the 16C looks more modern and is claimed to be nearly as fast as a Spitfire according to one of the salespeople on the Topper stand at the London Boat Show.
The fast version is the one in the background.
Re: nacra 450 vs hobie [Re: Jalani] #95592
01/11/07 04:17 PM
01/11/07 04:17 PM
San Diego
H
hokie Offline
hokie  Offline
H
San Diego
I think 340lbs for the Nacra 5.0 might be an overestimate, I have heard that they are more like 320. The Nacra feels very lively when sailing and is much stiffer than a getaway. These other roto boats may have improved.
Re: nacra 450 vs hobie [Re: Jalani] #95593
01/11/07 07:08 PM
01/11/07 07:08 PM
The only letter missing is the "F" <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
0 registered members (), 687 guests, and 134 spiders.
Posts267,056
