| Hull finish #96545 01/18/07 08:18 AM 01/18/07 08:18 AM | Anonymous
| Anonymous
Unregistered | What is the fastest hull finish? Is there any science out there we can believe? What do they do on the America's Cup Boats? What do they do in Australia?
Regards Chet | | | Re: Hull finish
[Re: ]
#96546 01/18/07 08:55 AM 01/18/07 08:55 AM |
Posts: 902 Norman,OK | Paint it orange!!! that will be really fast!!
| | | Re: Hull finish
[Re: Rolf_Nilsen]
#96549 01/18/07 01:08 PM 01/18/07 01:08 PM |
Joined: Sep 2006 Posts: 613 New Hampshire, USA windswept
Posts: 613 New Hampshire, USA | Well the sanding of the hulls first of all needs to conform with the flow of the water. From bow to stern. Will it make that much difference between 600 and 1600 grit sanding. No it will not, but it may make the sailor faster. Kind of like wet sanding a ACC boat with 1200 every morning before sailing, if they still do that. Psychologically it does wonders. If you think that the boat is faster, it makes you feel faster and therefore you tend to be faster. Awlgrip is the finish on my boats. 600, 800, 1000 then sprayed the top coat. You do not want an absolutey mirror or glass finish on the boat. There needs to be some roughness in the finish. 600-1200 grit doesb this well enough.
Tom Siders A-Cat USA-79 Tornado US775
| | | Re: Hull finish
[Re: ]
#96552 01/18/07 04:42 PM 01/18/07 04:42 PM |
Joined: Jun 2001 Posts: 975 South Louisiana, USA Clayton
Posts: 975 South Louisiana, USA | What is the fastest hull finish? Is there any science out there we can believe? What do they do on the America's Cup Boats? What do they do in Australia?
Regards Chet How well do you sail? This is not a rhetorical question as my point is, make sure your boat is in good shape and learn to sail extremly well first. Once you have exhausted all you need to learn on making the boat go fast then work on the .005 knots you will increase with the finish on the boat. A fast boat does not make you a fast sailor! JMO... <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> Clayton | | | Re: Hull finish
[Re: Clayton]
#96558 01/19/07 05:29 PM 01/19/07 05:29 PM |
Joined: Nov 2005 Posts: 337 Victoria, Australia C2 Mike
Posts: 337 Victoria, Australia | How well do you sail? This is not a rhetorical question as my point is, make sure your boat is in good shape and learn to sail extremly well first. Once you have exhausted all you need to learn on making the boat go fast then work on the .005 knots you will increase with the finish on the boat. A fast boat does not make you a fast sailor! Clayton
Very true but..... As others have said the psychology of "I think and therefore I am" does play some part. If you are sailing a boat that you perceive as being inferior then your own performance will be at least some part effected. If you are sailing what you believe is the fastest boat in the fleet this will have the effect of better feeling of wellbeing in your own mind and you will sail somewhat better. Probably isn't going to take you from last to first but it might possibly win you a few places that you otherwise may not have got. Tiger MIke Oh and all scientifically based tests I have seen conclude that smooth polished boats will have less resistance thru the water than it's un-polished counterpart. | | | Re: Hull finish
[Re: Rolf_Nilsen]
#96561 01/20/07 04:19 PM 01/20/07 04:19 PM |
Joined: Apr 2005 Posts: 473 Panama City, Florida Redtwin
Posts: 473 Panama City, Florida | What do you guys think of a rough surface to reduce friction such as orange peel texture or even a fine gritty surface like those neet-o new swimsuits from the olympics.
-Rob V. Rob V.
Nacra 5.2
Panama City | | | Re: Hull finish
[Re: Redtwin]
#96563 01/20/07 04:35 PM 01/20/07 04:35 PM |
Posts: 6,049 Sebring, Florida. | You guys ever read the book, High Performance Sailing by Frank Bethwaite? He has a whole chapter on smoothness. The short answer, as stated above, cleaner and smoother has less drag. You don't see airplane racers or glider pilots out there with 600 grit sandpaper. They rub and polish until it looks like glass, then they will smack you if you touch it... <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" />
But during the America's Cup some years ago, Dennis Conner tried some kind of ribbed stick on stuff on his boat to somehow reduce drag by keeping the boundry layer attached or something like that. I think he eventually ditched the idea. <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" />
I like to polish my boat with Teflon until my hand just slips right off, boards too. Makes it tough to climb back on after a crash though! <img src="http://www.catsailor.com/forums/images/graemlins/shocked.gif" alt="" />
Blade F16 #777
600
guests, and 45
