| Re: Platform Weight
[Re: ncik]
#98851 02/14/07 05:39 AM 02/14/07 05:39 AM |
F16 Hulls : typically 22.5 - 25.5 kg
With the new commercially produced hulls often coming out at 23 kg or lower and therefor being lighter then the orginal Taipan hulls were (23.5 kg on average). THAT is quite an achievement.
| | | Re: Platform Weight
[Re: rictorn]
#98857 03/12/07 12:18 AM 03/12/07 12:18 AM | Anonymous
| Anonymous
Unregistered | Hi Rictorn,
are you intending to run twin forestays or a bridle? From my experience altering a A class to F16 with a bridle, the hulls need to be heavier than what you are describing. Horizontal strength ahead of the main beam is essential as the bridle loads try to pull the bows together. <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
I would say that the framing inside is probably more important than the plywood skin, which is the only thing you have given info on. So what is inside?
Regards Gary. | | | Re: Platform Weight
[Re: phill]
#98863 03/13/07 12:05 PM 03/13/07 12:05 PM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | I was thinking of adopting dual forestays on my new Stealth as I wont be using a Jib, but decided against it due to the additional friction on the spinnaker sheets during a gybe. In light winds there's quite a bit of friction on a single forestay set up I wouldn't like to imagine how difficult it could be to gybe with the sheets being pulled across two stays. MP*MULTIHULLS | | | Re: Platform Weight
[Re: NickS]
#98865 03/17/07 06:25 AM 03/17/07 06:25 AM |
Posts: 461 Victoria, Oztralia | Gday Nick
I've just built one, I can't say I'd be worried about taking it or another one out in a blow.
Anything can be made stronger, theres a heap of little tricks that aren't in the plans that I have learnt from a couple of different sources, one being Phill Brander who has built nearly a handful of them.
I will build another one, using some of the tricks I missed out on the first time.
The earliest Taipans are still doing the rounds with the latest factory built boats and still posting top placings.
Regards
Matt Harper
Homebuilt Taipan 4.9
| | | Re: Platform Weight
[Re: NickS]
#98866 03/17/07 10:32 AM 03/17/07 10:32 AM |
Go back to that Yvonne sailor and tell him that he is talking nonsense.
Plain and simple.
| | | Re: Platform Weight
[Re: valtteri]
#98868 03/17/07 02:26 PM 03/17/07 02:26 PM |
Phills prototype hulls were 25 kg if I remember correctly.
| | | Re: Platform Weight
[Re: NickS]
#98869 03/18/07 09:49 PM 03/18/07 09:49 PM |
Joined: Mar 2003 Posts: 943 East Gippsland, Australia Tim_Mozzie
Posts: 943 East Gippsland, Australia | Hi NickS
The Taipan is a brilliant cat but if you really are going to sail regularly in 20-25 knots, maybe you need a modern Mosquito with a spinnaker, rather than a Taipan. The smaller rig will make life easier and allow you to enjoy the use of a spinnaker. Of course if there are Taipans to sail against where you are, then go for it!
I agree with Wouter, the Yvonne sailor is talking rubbish.
Tim Shepperd Mosquito 1775 Karma Cat
564
guests, and 48
