| Re: formula 16 plans? sail plan? dimentions? bits?
[Re: rictorn]
#99858 03/01/07 03:56 AM 03/01/07 03:56 AM |
Posts: 1,382 Essex, UK | Hi Rich, Take a look at www.formula16.org All the information you need should be there (although having just tried the site it doesn't seem to be up at present....Paul?) I don't quite understand what you mean by getting the sails 'in the right place'? EDIT: Just checked again and it's working fine.
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: formula 16 plans? sail plan? dimentions? bits?
[Re: rictorn]
#99859 03/01/07 04:47 AM 03/01/07 04:47 AM |
Posts: 1,449 | Rictorn, It may be worth talking to John P of Stealth as he is in the UK. Stealthmarine@tiscali.co.ukHe may be able to help you out with mast and other stuff. Good luck. Regards, Phill
[Re: phill]
#99860 03/01/07 09:05 AM 03/01/07 09:05 AM |
Joined: Feb 2006 Posts: 207 couldn't resist it Codblow
Posts: 207 couldn't resist it | Jp is your man font of knowledge ,builds boats , very helpfull and may have some bits for you. If you plan to use a unicorn main though , you could only use a unicorn mast , they are unlike any other cat mast sailing in existence --- very , very , very bendy !! and sail cut accordingly http://www.stealthmarine.co.uk/ | | | Re: formula 16 plans? sail plan? dimentions? bits?
[Re: Jalani]
#99861 03/01/07 10:10 AM 03/01/07 10:10 AM |
Posts: 465 Oxford, UK | Take a look at www.formula16.org All the information you need should be there (although having just tried the site it doesn't seem to be up at present....Paul?) EDIT: Just checked again and it's working fine. Hmm - wretched thing. We've got some bizarre problems on that server, which we're looking into. In the meantime, I've pointed the DNS back to another server. This should fix it, but if you've tried to look at the site in the last few hours, your computer may have cached the DNS results and you'll get pointed to the broken server. Paul | | | Re: formula 16 plans? sail plan? dimentions? bits?
[Re: rictorn]
#99863 03/02/07 03:44 AM 03/02/07 03:44 AM |
Posts: 1,382 Essex, UK | What are the hulls that you have Rich? Can you post a picture?
A measurement of main beam position measured from the bow would also be a help...
There is already a very successful F16 modified from an A Class in the class. It is called Altered. You can do a search on this forum for the story behind her. I don't know whether or how Gary calculated the main beam position (I know he took about 18" off the bows and 6" off the sterns) but the result is very successful.
[Re: rictorn]
#99865 03/02/07 06:58 PM 03/02/07 06:58 PM |
Joined: May 2006 Posts: 954 Mumbles Y.C Wales U.K Mark P
Posts: 954 Mumbles Y.C Wales U.K | From past experience I wouldn't take Cat measurements from the bow as they vary so much. I have it from good authority that the main beam, centreboard casings etc are better measured from the transome as this is a definfinte point. P.S Good luck with the project and keep us all informed. MP*MULTIHULLS | | | Re: formula 16 plans? sail plan? dimentions? bits?
[Re: Mark P]
#99866 03/02/07 07:13 PM 03/02/07 07:13 PM |
Posts: 954 Mumbles Y.C Wales U.K | I forgot to mention that F16's are up to 16'5" long. As for main beam location the length of your mainsail foot will be a significant factor as the longer it is the further forward the main beam will have to be moved. So as previously mentioned have a quick check on the F16 website for sail dimensions (I hope you'll find them). <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> MP*MULTIHULLS | | | Re: formula 16 plans? sail plan? dimentions? bits?
[Re: rictorn]
#99868 03/03/07 04:11 AM 03/03/07 04:11 AM |
Posts: 9,582 North-West Europe | My mainsail has a luff length (full tensioned) of 8.00 mtr and an area of 14.80 sq. mtr. With this I have an aspect ratio of 4.31 and a foot length of 2.10 mtr. The length of my squaretop is 580 mm.
My mainsail was made in 2003 and it reflects the standard then. Currrently the squaretops have grown to about 800 - 850 mm in length and the max allowed F16 area is now 15 sq. mtr with a max luff length of 8.10 mtr. I estimate the foot lengths to now be just over 2.0 mtr, as in 2.05 and such. This leads to an aspect ratio of 4.37.
Pretty much F16 mainsails have aspect ratio's between 4.25 and 4.40 depending on how the individual sailmakers cut their sails.
I hope this helps.
[Re: rictorn]
#99869 03/03/07 01:10 PM 03/03/07 01:10 PM |
Posts: 915 Dublin, Ireland | Hi Rich, I am not an expert on this, Maybe Wouter or some of the others can help, but if you have hulls from a Quatro or a similar cat, a full F16 rig just might be too much for that platform. I am not sure that the buoyancy would be there. When the others see the photos, I am sure that they will comment.
Dermot Catapult 265
255
guests, and 10
