self tacker innovations
Posted By: WindyHillF20
self tacker innovations - 12/20/06 03:56 PM
Ok, so I'm bored at work. Received the jib from Rick last night and ready to install the system. I know many of you have tweaked your set-ups and am curious what you like best, what doesn't work and any diagrams of blocks, lines etc. Again this is going on a TheMightyHobie18 with curved beam. Would like to keep it as simple as possible and as clean as possible. I have seen self tackers but never sailed with one so please inform me!!! I have the new style system from an '06 I-20.
Posted By: acceleratedchaos
Re: self tacker innovations - 12/20/06 06:05 PM
check the end bolts at the outboard end of the track. They were tapped and screwed in on the one I got, and on day three of sailing with it, it stripped and the car came off of the track and through a brand new jib. The jib was replaced and I thru-bolted the end screw on each side, and have no complaints! A really easy fix for a potential problem that could be avoided. Not sure if this is a specific problem to me, or if it has happened to anyone else.
Chris
accelerated chaos
Posted By: dave mosley
Re: self tacker innovations - 12/20/06 08:55 PM
Im curious to see how it fits on a curved beam....hummmm...
Bring it to CSC New years, we will assemble it around the fire with beer....should work GREAT!
Re: self tacker innovations - 12/20/06 09:24 PM
Great idea, lets do something no one has done before and lets drink while at it. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Actually its not a bad idea to get several experienced sailors to look at it and give their ideas. I know Jake would be helpful with this. Maybe I can just send the boat, you guys install everything and then I could pick it up. That sounds good to me. I will be in Myrtle over New Years, kind of a tradition. Great partying can be had in Myrtle.
Posted By: TEAMVMG
Re: self tacker innovations - 12/20/06 09:26 PM
Windy
i take it that you have got a new jib. Have you changed the mainsail too? Do you think that a square top would work on the 'soft' diamond rig of the TheMightyHobie18?
I find that you only need 2 track positions on a self tacker - In a bit from the end for flat water or right out for rough/windy.
Re: self tacker innovations - 12/20/06 09:40 PM
TEAMVMG,
Have Tiger jib now. Allready running Tiger ST main and chute. Put SX mast on, running 500lbs in the diamonds to pre-bend a little. The comptip is certainly an issue with the squaretop. The 18 jib disturbs the main and spin so changing to a self tacker with Tiger jib.
Posted By: Dlennard
Re: self tacker innovations - 12/21/06 07:12 PM
I would think that the Tiger self tacker would have worked better. The one I had you could side the post along the track to help fit the beam and you also could cut the post off to help fit the curved beam. On the N20 self tacker the post do not move and cuting them and making the post fit back in the bracket will be harder. Bring it to CSC over new years I have some battery drills and we all know how I like to drill holes in boats. Maybe Jake can bring a welder
Re: self tacker innovations - 12/21/06 07:53 PM
Dave,
I would say you are right. I got quite a deal on this unit as it had been damaged on Trey's new boat. The legs do not slide but can be attached in different areas. I'm not sure if they could be cut down or not. Mt thoughts were that the center recieved less load than the outside so moving the feet to the outer ends and resting the center on the crossbar would work. My S.C. plans for New Years are not set in stone but the spouse, that doesn't want me to race anymore, would have to give the green light. I'm not so confident about that happening.
Posted By: NCSUtrey
Re: self tacker innovations - 12/22/06 02:48 AM
I'll also have all my parts and equipment with me in Columbia to do this kind of retrofit. Drills, a rather large rivet gun, and a box of toys.
Posted By: MauganN20
Re: self tacker innovations - 12/22/06 03:38 AM
Trey is lying.
You know why?
Because he's a redneck
and rednecks' toolboxes only have two things.
Duct Tape for things that don't stick that ain't stickin
and
WD40 for things that stick that don't need to be stickin
Hope you like duct tape :P
Posted By: NCSUtrey
Re: self tacker innovations - 12/22/06 03:45 AM
Hey, if you can't duct it, f**k it.
Re: self tacker innovations - 12/22/06 04:53 PM
Where I'm from its called Racin' tape. Can hold on at 100mph or better. I've requested the time off to attend this event, don't have clearance yet. When will you guys arive? Where are you staying? I would think its going to be too cool to camp. And is the race one day only? Should I come in Sat or Sun?
Posted By: davidn
Re: self tacker innovations - 12/22/06 07:27 PM
Motto from the Duct Tape Council of America:
"Duct tape, because nothing in life is permanent."
David
now A cat and starting over on the learning curve.
Posted By: Tony_F18
Re: self tacker innovations - 12/22/06 08:02 PM
Speaking of tape, anyone have experience with this stuff(Gorilla Tape)?
Its looks impressive
Posted By: hobie1616
Re: self tacker innovations - 12/22/06 09:32 PM
If you're really good at using duct tape you can enter a contest. This would be good for junior sailors as there's scholarship money awarded.
http://www.ducktapeclub.com/contests/prom/
Posted By: NCSUtrey
Re: self tacker innovations - 12/23/06 07:07 PM
I'll be there on Friday sometime to set up the N20. I will probably leave sometime on Sunday evening, possibly Monday morning. So....try to be there all weekend if you can.
I'll be camping regardless of weather.
Posted By: Jake
Re: self tacker innovations - 12/24/06 05:57 PM
Wait! what if the distance racing is on Monday! You going to leave me boatless?
Re: self tacker innovations - 12/24/06 08:36 PM
Uh oh the natives are restless! :P
Posted By: NCSUtrey
Re: self tacker innovations - 12/25/06 02:22 AM
NEVER! I don't have to be back at NC State until the 10th...
Posted By: LuckyDuck
Re: self tacker innovations - 12/26/06 11:57 PM
Man you guys will hijack a thread in a heartbeat. I was looking for the thread on the CSC New Years Regatta when I found this so I'm jumping in here. Weather looks good. Not much breeze but good temps. I'm hoping to get on down there if I don't have to work and if y'all don't mind someone from this close to the Mason Dixon line murking up the spring fed lake down there. Ed
Posted By: arbo06
Re: self tacker innovations - 12/27/06 02:03 AM
Duct tape, WD and Vise Grips... All set.
Re: self tacker innovations - 12/27/06 01:16 PM
Crewdog, come on down, if you have any questions call me. I will pm you my number. What kind of boat are you sailing?
Re: self tacker innovations - 12/27/06 02:40 PM
How about some details on this event! Anything on seacats? CSC site? Need to sell the spouse and so far you guys have given me nothing, except your excellent offers to help with my boat. When, what festivities? Free beer? New Years party? Whats up!!!!!!!!!!!!!!!
Re: self tacker innovations - 12/27/06 04:56 PM
www.columbiasailingclub.org has details about the party sunday night, I dont think Im going to it, we usually have our own party and campfire/fireworks on the beach either sat or sunday night. Bring something to grill and some fireworks, and RSVP to the CSC party if you want to go there. Either way will be fun. The Racing will be up to us, were not following thier schedule, but we usually eat the chili and hang out around the fireplace after the racing. I think its like $5 for the racing and chili. I'll buy your beer(if you limit it to 1!)
© 2024 Catsailor.com Forums
