Kickup T foil rudder
Posted By: grob
Kickup T foil rudder - 05/09/07 11:43 AM
What do people think of this kickup T foil rudder setup?
The system is very simple. The T-foil is attached to the bottom of the main rudder blade, and is allowed to pivot freely. Referring to the sectioned plot below, the T-foil is also attached to the rudder box via a line that runs through the rudder blade. When the rudder blade is in the vertical deployed position the line pulls the T-foil tight against the bottom of the rudder blade holding it in a horizontal sailing position. When the rudder blade is released to swing to the horizontal position the T-foil is also automatically released.
Although this is currently shown on a Dotan stock (as this is what I use) it can be retrofitted to any existing kickup rudder system.
Gareth
Posted By: Wouter
Re: Kickup T foil rudder - 05/09/07 12:34 PM
Not enough distance difference as a result of the pivoting to pull the T-foil in tight.
The radius from the fullcrum to the point where the line enteres the rudder boards is too short.
Maybe have a pully on the stern and a clear on the rearbeam so the skipper can activate and deactivate the T-foil ? (an idea I had for the F12) But still have the problem of the line stretching resulting is a flapping T-foil possibly damaging the rudder board itself.
Posted By: Jake
Re: Kickup T foil rudder - 05/09/07 12:46 PM
Interesting thought. I would first be concerned about flutter of the foil if it kicks up while the boat is moving at any decent speed...that is, unless you built in some imbalance stability into the foil - but that would result in undesirable drag during normal attitude. I know first hand that control surface flutter can be violent and result in the death of a model airplane!
The geometry between the pivots and the line seems to be a bit off - but that might actually take care of the potential for flutter if it can be arranged put the foil at a slight bit of a "down plane" attitude when it is released.
Posted By: Timbo
Re: Kickup T foil rudder - 05/09/07 01:04 PM
Why not just improve the lifting mechanisim on the present casette type T foil rudders? Personaly I like the idea of only having half the rudder, or less, down when coming in to or departing the beach. You will still have a lighter helm than with a kicked up rudder, which can be hard to steer in big wind and waves. And it would seem the casette type system would be lighter, less moving parts to break, etc.
Could someone who uses the present T foil rudders please post a close up picture of the headstock and the rudder in both the up and down possition, and tell us how it works? Thanks.
Posted By: Special_Treat_P182
Re: Kickup T foil rudder - 05/09/07 01:12 PM
I'm curious... Why foil the rudder? We're not talking about foiling the entire boat to raise it out of the water, just the rudder. What does creating lift on the rudder accomplish other than raising the transom a bit? I don't see it as improving helm performance or balance. So if you want to raise the stern, why not simply move crew forward? At least on my Prindle, if the crew is near the front crossbar, I can raise the stern quite a bit.
It just seems as though it's a complicated design which introduces another point of failure (and expensive failure at that) for very little gain or at least a gain that be gotten from simply repositioning the crew on the boat.
Posted By: MauganN20
Re: Kickup T foil rudder - 05/09/07 01:24 PM
Its supposed to keep boats with not enough bouyancy up front from pitchpoling.
As the muscle car guys say, in my opinion,
"There's no replacement for displacement (in the bows)"
Re: Kickup T foil rudder - 05/09/07 01:30 PM
So again, is this an overly-complicated solution to a rare problem? I know of Hobie and Prindle 16's that were more prone to pitchpoling, but most modern cats aren't. I installed the cheap anti-pitchpoling foils on the bows of my old Hobie-16 and they seemed to work very well for a hundred bucks. Afer that pitchpoling the 16 required a serious mistake on my part.
Posted By: Krisu13
Re: Kickup T foil rudder - 05/09/07 01:48 PM
If you are not going to do any backward sailing - just eliminate the line going through rudder blade.
Posted By: Timbo
Re: Kickup T foil rudder - 05/09/07 01:55 PM
The guys who have them like them, I think the Stealth (F16 type) has them, they say they really smooth out the ride and keep you from nose diving in a windy gibe. The Jurry is still out on wether they are "faster" or not, but swimming is slow.
Posted By: Jake
I hadn't thought of that - boy that would be really nice.
Posted By: Jalani
Re: Kickup T foil rudder - 05/09/07 02:11 PM
The German built Topcat uses a cassette system which is retained by stiff bungee so that if a down rudder hits an obstruction the rudder (and stock) kicks up. I've thought of engineering something similar for the Stealth.....
Posted By: Timbo
Re: Kickup T foil rudder - 05/09/07 02:15 PM
Thanks for the picture John, now, tell us about the ride with the T foils. (I know this was covered a year or so ago, any updates?)
Posted By: Jalani
Re: Kickup T foil rudder - 05/09/07 02:20 PM
The ride has been discussed at length, as you say, having sailed with them, I couldn't now imagine sailing without them! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Only update is the new Stealth (2006/7) T-foils are a fantastic improvement on the older ones. Small, lighter, stronger and much better engineered. Less drag IMO, but just as effective as the older, larger foils. John_P has done a really good job!
Posted By: Timbo
Re: Kickup T foil rudder - 05/09/07 02:35 PM
If I wanted to buy a pair to put on a US Blade, what would that cost, for the new ones? Rudders, heads, tillers and mounts?
Posted By: Jalani
Re: Kickup T foil rudder - 05/09/07 04:45 PM
Your best bet Tim would be to cantact John Pierce - either PM him (john p) or through the website: http://www.stealthmarine.co.uk
Posted By: warbird
Re: Kickup T foil rudder - 05/09/07 10:55 PM
I am in this camp. I used casset type a lot as a young mono sailor and always liked them more than flip up. Once you have the travelling tuned they are fast easy and can quickly be set at several heights without losing stearage. Extra moving parts creates possiblity for gear failure. But nice images.
BTW don't hit anything if they don't flip up! (we don't have big jellies here)
Posted By: Laruffa
Re: Kickup T foil rudder - 05/10/07 09:55 AM
Hi everyone,
Would like to ask you a question, after sailing 49ers I always ask the question why not!! rudders in a box system?? they have some good points 1)when you need to sail into or out of a beach with any seaway they would work well if you could just left them up to miss the bottom and still steer! 2)packing the boat for transport all you need to do is take them out and pack them into a bag like the centre boards! 3) they would never kick up under load or sailing in waters with things like jellyfish! 4)if anything fouled them like seawead you could still steer while lifting them free! 5)in conditions like high winds with flat waters you could lift them to reduce drag?? [color:"red"] [/color] disadvantages? 1)hitting a object or the bottom in shallow waters?? BUT would it be cover by the centre boards???? whats your thoughts!!!! Love allways MarkXX <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" />
Posted By: Rolf_Nilsen
Re: Kickup T foil rudder - 05/10/07 10:08 AM
I like them, and think kick-up rudders are a leftover from the rotating centerboard days. Today the daggerboard (unless you have skegs) will hit the ground before the rudders, so you will ruin your day anyway.
Posted By: Jake
Re: Kickup T foil rudder - 05/10/07 12:28 PM
Hi everyone,
I too like the idea of a cassette style rudder. Big jellies are not usually a risk to the structure of the boat but things like stumps or perhaps a rock outcropping might be. However, you could still have some sort of breakaway "fuse" at the gudgeon in the event you really did hit something hard.
Posted By: phill
Re: Kickup T foil rudder - 05/10/07 02:08 PM
Gareth,
Intersting concept.
Obviously it would need some work to refine.
Got me thinking could even replace the line with thin flat rod down the centre of the rudder.
When building the rudder a slot could be made down the centre to accomodate the rod.
Now if you can control the rod from the top you would also have the ability to adjust the angle of the
T foil while sailing.
Posted By: Glenn_Brown
Re: Kickup T foil rudder - 05/10/07 03:57 PM
Since drag is proportional to lift, the rudders would be prone to kicking up at speed... more so than conventional rudders.
Is the foil slapping the water's surface going to interfere with the Dotan stock operation?
Wear on the line/rudder entering the channel at an angle is an obvious concern. A steel rod bearing would help.
Wouter rightly pointed out geometry problems with the line/channel placement. These could be addressed simply by making the line ride a cam around the top axel, with the cam radius matching the bottom axel-line separation.
The "channel" through the rudder need not be parallel to rudder trailing edge.
You need some adjustment somewhere to get the line length just right. You probably need a little stretch in line line to so you can get the rudders down with tension on the line.
The hinge can only add drag, but kick-up eliminates the problem of cassettes scratching the foil, so you could possibly use a laminar flow foil section for less drag and make up for it.
Posted By: Timbo
Re: Kickup T foil rudder - 05/10/07 04:19 PM
Gareth,
Intersting concept.
I think the foiling Moths have a setup like that, where they can adjust the anlge of the rudder foil by tweeking something on the tiller.
Posted By: Jake
Re: Kickup T foil rudder - 05/10/07 07:22 PM
Gareth,
Intersting concept.
They used to twist the tiller to adjust the attitude of the rear foil - however, I believe they've all gone away from that and have found that a fixed rear foil works just fine and is less hassle.
Posted By: Darryl_Barrett
Re: Kickup T foil rudder - 05/11/07 02:35 AM
This system has obvious merit if a kick up system is required. The cassette system also works just fine. Any conceived concerns regarding a cassette system do not seem to be any problem in actual practice. The idea that hitting the rudder(s) on any solid object when they are in the cassettes is greatly over rated. We have used them now for some two years and sailed in some fairly suspect water depths with many solid underwater obstructions and although contact has been made with the rudders none have been broken whilst sailing. At the same time, during the same events we have seen more than one set of “kick up” rudders destroyed because the kick up release mechanism(s) have been set so tight to stop them releasing prematurely if and when they were to contact weed, muddy bottom etc, and as such, to all effects they become a permanent (whilst sailing) lock down system
The drag induced by T foils on the rudders has a negligible effect on the cat’s performance and any minor drag that may occur is greatly out weighted by all the positive benefits, (particularly pitch control), gained from the foils.
To understand the way in which T foils operate one has to view their effects as a global formula and not as a two dimensional concept.
Posted By: dacarls
Re: Kickup T foil rudder - 05/11/07 03:15 AM
The plain old conventional Hobie 14 castings used on the hydrofoiler rudders in my thumbnail pic worked pretty well and never broke. Neither did the rudders. They are on my boat, the only hydrofoiling Hobie 16 in the world. 8^)
Posted By: ncik
Re: Kickup T foil rudder - 05/11/07 03:52 AM
The current generation top end moths can still adjust the rudder T-foil angle of attack with the twist grip extension, but the whole rudder box now rotates using a screw drive type arrangement. Usually it is set for upwind or downwind and not played with otherwise. Essentially they're fixed most of the time.
Posted By: ncik
Re: Kickup T foil rudder - 05/11/07 04:03 AM
Darryl, do they also make it a bit more difficult to lift a hull in marginal conditions because of the down force they generate on the windward hull?
There are scaling problems with the following anecdote but...I have built and raced model trimarans (mini40) for awhile and have found that T-foils haven't been faster in most conditions. Upwind, the extra drag from them and extra drag from not being able fly the hulls was slow. They made it harder to sail downwind, which was when they were supposed to work, because the boat wouldn't accelerate as fast in a gust, which would load up the rig making it want to nose-dive.
As I said, there are scaling problems with the anecdote but the main problem I see with T-foils on multihulls in general is making sure you can still lift a hull, probably only a problem in marginal conditions.
Posted By: phill
Re: Kickup T foil rudder - 05/11/07 04:55 AM
Gero,
Interesting that you should mention lifting hulls.
Two things to note:
I believe John P has mentioned on the forum that the T foils dampened the affect of gusts lifting hulls upwind.
So in gusty conditions they made the boat more stable giving greater acceleration from the gusts as well as the additional affects of stabilizing the pitching motion allowing the sails to generate more power.
Someone using Darryl's T foils was telling me at a regatta that he was lifting the windward hull downwind and then moving a little further aft and resting the windward hull back down on the windward foil with the hull remaining clear of the water.
This allowed a slight bias in the downward loading of the hull making the boat more stable while still flying the windward hull. So he could keep the hull up in marginal conditions reducing the wetted surface drag as well as being able to drive the boat better with the added stability.
I think we still need to do a bit more experimenting, even so I expect T foils will find a permanent place in all progressive catamaran classes in time.
Now the next step could be independent adjustment of foils to help lift the windward hull in light conditions.
Interesting thought that would be fun to play with but unlikely it could be made simple enough to not cost more time through poor adjustment than gained.
But you never know until you give it a go.
Re: Kickup T foil rudder - 05/11/07 05:23 AM
Lifting a hull to windward is exactly the same with or without T foils. The only times that T foils produce ANY lift either up or down is when the hull pitches forward or back, therefore due to the forward motion of the hull, the lift generated by the foils is mostly directionally forward, and not simply up or down therefore there is virtually no extra loads on the transom, if the hull is level with the water surface then the foils are lift neutral and lifting the rudder and the hull offers only minute (not even noticeable) upward resistance
We have found that the great amount of pitch dampening by the foils lets the sails work almost to their optimum all the time instead of darting forward and then back at which time almost stalling in light choppy conditions half of the time. Since we put T foils on the Alpha F14 the increase in overall performance in all conditions (and particularly in the light) has been “exhilarating”. We sailed a point to point race in the Southern ocean last weekend in very light conditions against 20 odd cats all of which were larger than the F14 (F18’s, F16’s, 5.8 NACRA’s etc) and for a large part during the middle of the race two Alpha F14’s were leading all of them (actual). At the finish the first cat across the line was a Hobie tiger followed closely by an Alpha F14. On yardstick Alpha F14’s took 1st and 2nd by some minutes. Before the fitting of the foils that just would not have happened. Since fitting the T foils to two cats neither has ever “pitch poled” regardless of the conditions. Before fitting both had regularly pitch poled in heavy downwind legs under spinnaker.
Re: Kickup T foil rudder - 05/11/07 05:36 AM
QUOTE; The plain old conventional Hobie 14 castings used on the hydrofoiler rudders in my thumbnail pic worked pretty well and never broke. Neither did the rudders. They are on my boat, the only hydrofoiling Hobie 16 in the world. 8^)
VERY INTERESTING,how much wind does it take to lift the cat above the water surface, and does it have wand type variable foil adjustment to it's lifting foils (like the moth or to a lesser degree the Tri foiler)??
Posted By: Luiz
Re: Kickup T foil rudder - 05/11/07 08:06 PM
Agreed. And I guess cats would use L foils instead of T foils. They are more efficient. But, as you said, we will only know if we try.
Cheers,
Posted By: john p
Re: Kickup T foil rudder - 05/11/07 11:11 PM
Gero
We felt in testing that in gusty conditions the T-foil equipped boat was less 'flighty', in other words it was less prone to violent hull lifting in gusts, this is dificult to measure and was more a feeling, we put it down to the following effect.
When hit by a gust the non t-foil boat would accelorate at the same time as the hull lifted, this extra drive produces a small dip as the bows go down under acceleration.
On the T-foil equipped boat the bows don't dip because the T-foils hold the boat steady, but of course to do this they apply downforce , also as the rudder lifts it is no longer travelling horizontally but is sloping up, these 2 effects produce downforce on the rudder which on the windward one equates to an extra force resisting hull lift.
The net result of this is that it is just as easy to fly a hull and the same wind strength is required to do it either way, it is just that it dampens the effect of gusts, and lulls(because the reverse happens then).
Posted By: warbird
Re: Kickup T foil rudder - 05/12/07 05:41 AM
Darryl, I keep waiting to hear you are starting to get strong sales..
What would you charge for a set of the rudders and stocks?
Posted By: Buccaneer
Re: Kickup T foil rudder - 05/12/07 05:52 AM
The rudders normally come up after and go down before the boards so they are of course more susceptible but with the kick up function that is not an issue. For example I pull the boards up and surf in until I’m in about knee deep water. If I misjudge the tide then once in a blue moon I hit a rock and a rudder kicks up. No big deal. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" /> Maybe better to build a cassette with a simple kick-up function (not unlike top cat) as insurance against ripping the stocks off on the reef? <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Posted By: Wouter
Re: Kickup T foil rudder - 05/12/07 09:56 AM
Bob,
Darryl tested his T-foil rudders as plain kick-up rudders. Meaning you use the exact same stock as you are using now but not with rudderboards with the little foils attached to the their ends.
He reported that there is no issue hitting the bottom, the T-foil rudders will kick up just the same as the normal rudders do. The T-foils won't break as they need to be strong enough to withstand the normal operating forces anyway. and maybe apart from some extra drag that slows the boat down nothing else happens. This may all not be a bad thing when landing.
The only issue left is leaving the beach with the rudders kicked up. I don't fancy working my way through the surf like that, but experimentation might proof otherwise. Afterall the T-foil rudders aren't that large in area. Also if you don't have to launch through the surf but can walk the boat in to sufficiently deep water and put the rudders down then there is no issue left at all. Then you can just have T-foils added to your current rudderboard design and use all the old kick-up hardware.
Again Darryl sailed the F14's like that for a long time now and everything is still fine. I think they even didn't modify the rudder pintle setup from what the quick snap on system they had on there. Apparently the forces generated on these part are relatively small and it is the large leverage they have there in the back of the boat that does the major part of the work.
I have no experimentation money left otherwise I would order a test rudderboard like that and just fit is to my current ruddersystem and find out what really is a problem and what isn't. The Taipan is one of the hull designs that could really benefit from the T-foils.
I was very impressed by them when I sailed the Stealth a few times.
Ohh, and there is another principle that is of interest here. John Alani expressed a while back how he approaches a landing site with the cassette rudderstocks.
When he approaches shallow water he pulls out the retaining pin, now the rudderboard can slide up and down through the cassette depending on the vertical forces produced by the T-foils. In effect he can lower the rudderboards by moving his weight forward and putting the hull in a small bow down angle. And he can raise his rudderboards by moving his weight back and putting the hull in a bow up angle. He uses this phenomenon to lower and raise his boards when leaving the beach or landing. Just before the rudders are about to hit bottom he apparently moves his weight back and thus have them lift themselfs clear. This way he covers the last stretch of water and then steps off.
This phenomenon may even be an advantage of the cassette tape rudderstocks, because you can always get as much rudderboard in the water as you need/can without having the large tiller loads or having to use your hands or go to the back of the boat ! Your hands are now free to hold the sheet and tiller. Once through the surf you can head up into the wind and fit the retaining pins and go sailing.
I think there is some excellent development to be had with the T-foil rudders and I truly believe that we will see them fitted to beach cats more and more. Especially in the range where hull length are relatively short. Personally I'm planning on using them on the F12 design and I would love to have them on my F16.
Re: Kickup T foil rudder - 05/14/07 12:54 AM
There is the old adage for any design, K.I.S. (keep it simple) and there is a lot to be said for the absolute simplicity of the cassette system. No cams, no pivoting points, virtually no wear points, never any necessity for fore and aft adjustment for tuning, etc, and their sheer simplicity overcomes a lot of potential (and real) problems that are inherent in all other rudder systems. I was initially doubtful about using the cassette system, considering it “old fashioned” but after extensive testing and use now, I actually prefer them to a “kick up” system
Posted By: ncik
Re: Kickup T foil rudder - 05/14/07 01:54 AM
Ditto! There's something to be said for set and forget, and the KISS principle.
