Posted By: Rusty How do I remove N5.8 front cross bar? - 06/09/07 07:56 PM
I took off the straps but the cross boar won't come loose. Is there somethingn I am missing? I need to take the tramp to be sewn and it seems the only way to remove it is with the front cross bar taken off.
I think the cross bar may never have been taken off. I tried giving it a few good strong taps with a rubber mallet but it didn't budge.
Thanks in advance for any and all information.
Rusty
Posted By: NaCl H20 Re: How do I remove N5.8 front cross bar? - 06/10/07 12:25 AM
My Nacra isn't a 5.8, but there is another bolt just inside the front crossbeam, hidden by the cap. The 5.8 is the same I think
Posted By: hobiekite Re: How do I remove N5.8 front cross bar? - 06/10/07 01:48 AM
i had to replace the straps on my 5.8 and the crossbeam
were loose when i took the old one's off. there is no other
bolt on my boat.
bernd
Posted By: Ventucky Red Re: How do I remove N5.8 front cross bar? - 06/10/07 01:54 AM
Yeup - take off the end caps and there it is - I beleive it is a 3/8" bolt
Posted By: Rusty I found the bolts inside. the cross beams......... - 06/11/07 12:29 AM
One came out pretty easy, the other is having to soak in Liquid Wrench to loosen up.......Rusty
Posted By: carlbohannon Re: I found the bolts inside. the cross beams......... - 06/11/07 01:48 PM
Before you put the bolts back in, coat them with anti-sieze. I like the nasty grey grease looking stuff sold by NAPA and almost every other commercial auto parts store.
Posted By: Krisu13 Re: How do I remove N5.8 front cross bar? - 06/11/07 02:53 PM
See if you can get torque wrench. Do not strip your threads
16-18 ft lb is max force that you should use to tide bolts.
When you put your straps back it is a good idea to put some electric tape between beam and straps. That way straps do not cut into beam.
just my 2c
Posted By: DHO Re: How do I remove N5.8 front cross bar? - 06/12/07 02:46 AM
I always thought that the straps on NACRAs was a goofy way to do things. It doesn't look like it would give a good, solid, rack-free joining, but apparently it gets the job done.
D. HO
TheMightyHobie18 1067
