Catsailor.com Sail boxes
Posted By: NCSUtrey Sail boxes - 08/16/07 02:49 PM
Earlier this year I got a few people together to buy sailboxes. I have a guy here that makes them, and if we get an order of 5 or more, he cuts a pretty good deal. If you are up for getting a sailbox, please shoot me an email. I want to add another to my trailer, so if we can get 4 others, they'll be $550 each. They are all aluminum (diamond plate), and are made to the same dimensions as the standard fiberglass box. The rear door open down, and the front 5' of the top comes off.
JW, TBack, Joanna, did you like your boxes?
Posted By: tback Re: Sail boxes - 08/16/07 03:05 PM
Yes, and I get lots of compliments on it.
Only thing I added was a plastic insert for the flooring...the "wavy" kind used for screen enclosure roofing.
I am currently living in mine. Added a window unit and some nice berber. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Posted By: NCSUtrey Re: Sail boxes - 08/27/07 01:33 PM
Anybody else?
Posted By: Mary Re: Sail boxes - 08/27/07 02:19 PM
Anybody else what? Living with John in his sail box?
I do know that back in the early 1990's we did a seminar somewhere in the Midwest, like Kansas or Nebraska, and at least three people had sail boxes that opened up into camper tents right on the trailer. Really cool. <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> I probably still have photos somewhere.
Posted By: Joanna Re: Sail boxes - 08/27/07 09:00 PM
The box is wonderful!! If anyone needs one Trey is the one to get it from. Well built, good looking, lots of room and a great price.
Posted By: dsltrc Re: Sail boxes - 08/28/07 12:37 AM
hey trey... do you have any pics and dimensions of those boxes? i might be interested...
Posted By: NCSUtrey Re: Sail boxes - 08/28/07 02:36 AM
I don't have any pics, sorry. Maybe Oley or JW can hook us up. Dimensions are ~ :10' x 14" x 24"
Come to Catfest and you can see it.
Posted By: Brian_Mc Re: Sail boxes - 08/28/07 05:01 AM
Trey, I want to see pics of the interior of John's! If it was like Hakan's I'd buy one!
Posted By: Joanna Re: Sail boxes - 08/28/07 11:27 AM
Here is the only one I have. The front top opens and the back end drops down. Hope that helps.
Posted By: TeamTeets Re: Sail boxes - 08/28/07 11:28 AM
I would love to get two... but getting them to Ohio is a bit of a problem. Anyone traveling from NC to Ohio any time soon?
Posted By: Timbo Re: Sail boxes - 08/28/07 12:58 PM
I would like one, but 10' isn't long enough for my one-peice spinnaker pole, which I think is about 11'6", can they make one 12 feet long? There is a guy in Orlando whom I have called, he built some for the local Orlando guys, but he is burried in his regular job until October, and he wants about $1,200 for a custom 12' aluminum box...
Posted By: Jake Re: Sail boxes - 08/28/07 01:22 PM
buy 4" pvc tube, a 4" to 4" straight coupling, and a 4" cap. Cut coupling in two (to get two sleeves - table saw w/ fence works well). Cut hole in bottom corner / end of box (be sure to leave room for coupling - use inside of coupling as hole template from inside the box), slide one coupling onto tube, slide tube into hole in box, slide second coupling half onto PVC inside box, slather with 3M 4200, slide couplings tightly together against box side, drill and put in three small screws into each coupling, and lightly support the front of the tube...spinnaker pole problem solved.
Posted By: Joanna Re: Sail boxes - 08/28/07 01:42 PM
Jake idea works great..we did that and have plently of room for the spin pole.
Posted By: Timbo Re: Sail boxes - 08/28/07 01:55 PM
Joanna, I see you have your hull cradles lifted via blocks, was boat beam to toy box clearance a problem without the blocks? With the blocks, how much room do you have between the beams and the top of the box? Thanks.
Posted By: PTP Re: Sail boxes - 08/28/07 02:00 PM
brilliant! once again, you da man.
Posted By: PTP Re: Sail boxes - 08/28/07 02:03 PM
I am in if anyone is on their way to Florida (going to performance race week in Pensacola in Oct?).
Posted By: Jake Re: Sail boxes - 08/28/07 02:33 PM
That was actually a WWDLD with a light sprinkling of WWJKD.
Posted By: tback Re: Sail boxes - 08/28/07 03:25 PM
Timbo,
I've mounted mine directly on the trailer beams (used some weather stripping as a gasket) and have about 1" clearance below the dolphin striker. Enough room to open the box (with the boat on the trailer) and slide the top section back ontop of the box...still clearing the dolphin striker.
Posted By: bvining Re: Sail boxes - 08/28/07 03:28 PM
I want one. Any one else want on in New England?
Posted By: Timbo Re: Sail boxes - 08/28/07 04:04 PM
Well, I'm not in NE anymore but I want one too! And Jake, send me some PVC pipe! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Posted By: Joanna Re: Sail boxes - 08/28/07 04:17 PM
Timbo--The wood blocks on the trailer are actually so that the boat clears the fenders. (Oley built the trailer himself) The dolphin stricker clears the box by about 8 inches and the boat by about 16. Hope that helps.
Every time I hear a story like this I wonder if someone else found some "Cycle-Campers" in the corner of a warehouse.
In the 80's there was a company in that general area that made a tiny popup camper designed to be towed behind a motorcycle. It did not sell very well and the company went under.
These things were the perfect size to fit between the hulls of a catamaran. I knew a couple of people who did that. I bought one from a dealer real cheap, with the intent of mounting it on my trailer. A friend begged a lot and I sold it to him to mount like a tool box in the bed of his pickup.
We later found these things did not like water. They would fall apart if you got them wet launching your boat.
I have not seen one in years, I suspect they fell apart when people parked them outside like they were real trailers.
Carl
Well Mary, I know you're refering to the seminar held at Lake Perry (Kansas) but for the life of me I've don't recall any of these campers. Carl, you're probably right they must have been junk.
I've been scheming on a quick/safe way to put the double stack rails on an old pop-up trailer. The tent thing is getting old (or wait, maybe that's me getting old).
Posted By: dsltrc Re: Sail boxes - 08/30/07 12:07 AM
TREY
i'm game for a box.... just let me know when you need payment and how long should it take?
Posted By: NCSUtrey Re: Sail boxes - 08/30/07 12:40 AM
Call me.
Posted By: dsltrc Re: Sail boxes - 09/07/07 11:46 PM
trey need your addresss so i can mail the check to you....
Posted By: NCSUtrey Re: Sail boxes - 09/09/07 09:07 PM
Check your messages.
Posted By: arbo06 Re: Sail boxes - 09/10/07 02:21 AM
Send the check to 472 Barbri Avenue,,, Dave Fl. 33377
Posted By: NCSUtrey Re: Sail boxes - 09/10/07 11:41 AM
Ha ha ha
Posted By: dsltrc Re: Sail boxes - 10/09/07 11:09 PM
hey trey,,,
so how r those boxes coming? give me a shout... <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
Posted By: rexdenton Re: Sail boxes - 04/25/08 03:07 AM
I do. Motivated. Who makes them? I know this post isn't so timely, but I am hunting all over the country for just this thing. Take my money! Please!
Rex Denton
Posted By: NCSUtrey Re: Sail boxes - 04/25/08 03:18 AM
Shoot me an email: velocitytrey (at) gmail.com and I'll fill you in.
Anybody else want in? I've got to get 5 people before I will run the order.
Posted By: Tri_X_Troll Re: Sail boxes - 04/25/08 11:30 AM
How much do they weigh? My pvc sail tube weighs in at something like 180...too heavy.
Posted By: Clayton Re: Sail boxes - 04/25/08 12:56 PM
180? Is that loaded? My PVC tube (12" schedule 40 not the light stuff) weighs less than 1/2 that! Just a little less than my aluminum box I made.
Clayton
Posted By: bullswan Re: Sail boxes - 04/25/08 01:49 PM
These units for camping have intrigued me. They are Australian and my cousins all have them there. Seem to be very well built.
3 dog camping Greg
Posted By: wildtsail Re: Sail boxes - 04/25/08 02:14 PM
I picked up BVining's box for him a few months ago from Trey's house.... I could not believe how light they were! It can easily be moved my one person (although two is nice because of the size). I think Trey said it was only about 25-30 lbs!
If my wishlist wasn't already so long i'd be getting a box myself for sure.
Posted By: NCSUtrey Re: Sail boxes - 04/25/08 02:15 PM
These boxes weigh in somewhere between 30-40 lbs. They are extremely light, but they are still pretty stiff. I've laid on top of mine before.
Who else wants one?
Posted By: Timbo Re: Sail boxes - 04/25/08 02:20 PM
What we need to develop is a sailbox that when fully opened, turns into a tent and a bar, for the regattas! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
the lunchboxes are the best trailer box you can currently find on the market. Not only because of their quality, but because of the cost compared to its inferior products.
Its on my shortening list of "things".
Posted By: Timbo Re: Sail boxes - 04/25/08 02:40 PM
I got one from Trey last year, love it...but no bar installed...yet. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Posted By: NCSUtrey Re: Sail boxes - 04/25/08 03:03 PM
Tim, I told you to check the box to add the bar options, but noooooooo...you just wouldn't listen. Crazy 16ers...
Posted By: Anonymous
Re: Sail boxes - 04/25/08 04:27 PM
Is there one with a pull out couch option?
Posted By: NCSUtrey Re: Sail boxes - 04/25/08 05:53 PM
No, only a recliner option (lazy-boy style).
I keep trying to get Trey to merge with Krantz Enterprises LTD to get a margarita machine built into the front.
