Posted By: gree2056 5.2 Spinnaker rigged! - 11/03/07 09:28 PM
Here are a few photos of my 5.2 that i rigged an Inter17 spin on. So far it has worked very well, it made sailing today in winds that were almost drift conditions almost interesting. Of course I am still learning how to sail the spin, but it is definently is taking the old 5.2 to the next level.
If any other 5.2 owners have questions about how to rig the boat or any other boat owners feel free to ask.
Posted By: gree2056 Re: 5.2 Spinnaker rigged! - 11/03/07 09:38 PM
another, the wind was barely blowing so even the weight of the dousing line was messing up the shape of the sail but you get the idea
Posted By: gree2056 Re: 5.2 Spinnaker rigged! - 11/03/07 09:41 PM
Also here is a picture of both our boats ready to go.
Poor old H14, it is hull number 242 from 1967. The past owner painted her and it has all flaked off so she looks ugly but still fun when the wind is up.
Posted By: erice Re: 5.2 Spinnaker rigged! - 11/03/07 11:53 PM
thanks for those gree
for those of us like me who will probably only ever actually lay eyes on their own 5.2, getting such good pics of the same model helps greatly for comparing rigging etc
still set up for just the 1 on trap?
Posted By: gree2056 Re: 5.2 Spinnaker rigged! - 11/04/07 02:49 AM
Yeah, still just set up for one, I have the second set of wires but I am basically turing the boat into a poor man's I17 so I don't need them.
Posted By: Anonymous
Vernon:
Nice setup. Think I am going to add two eyelets at the bridle to run extra lines like you have. I have them now going to the end of hoop, but I think extra set will stabilize the pole more. It wants on come off pin now.
Doug
Posted By: gree2056 Re: 5.2 Spinnaker rigged! - 11/04/07 02:58 AM
Doug,
I don't have eyelets, I simply used a shackle to attach the bridle wires rather than a pin, it gives me a place to attach to and I know they are stable.
Re: 5.2 Spinnaker rigged! - 11/04/07 05:26 AM
Vernon:
Talking about on the pole itself. Had a new pole made from an old dingy mast. I will add some eyelets even with the bridle tangs and use a shackle and some line with a bowline to stabilize the pole more.
Doug
Posted By: pepin Re: 5.2 Spinnaker rigged! - 11/05/07 02:00 PM
I also sailed my spinnaker for the first time this week-end on my 5.2. It took me a long time to get there: the club being closed because of foot and mouth, and the pressure of family prevented me to hit the water for months! So this week-end I finished the install and flew it for the first time.
I use an generic aluminium pole, a stealth 16 snuffer and loop, a 17.5m2 hobie spi from unknown origin (a H16 maybe? Or a FX1?). It was mostly drifting winds yesterday but I decided to sail without the jib to remove some of the lines from the tramp. Bad mistake as going upwind without a jib is slow in 1o 5 knots of wind.
Anyway, downwind was fun, and the spi worked without a hitch. Pull a line it goes up, pull the other side and it parks nicely in its bag.
Questions:
* Where do you route your spi sheet? I have mine going to the bottom of the sidestay, rounding a block there, then rounding a ratchet block attached to the front beam where the jib tramp line attaches. Unfortunately the daggerboard is on the way and the sheet touches the board.
* How do you manage the sheet length and prevent it from going in the water all the time?
Posted By: Andrew Re: 5.2 Spinnaker rigged! - 11/05/07 02:13 PM
Hey Doug, if you do that, make sure that the eyelets are thru-bolted. Rivets are not strong enough and will tear out. On a similar rig I had on my old P-19, I just hog-tied a line so both tails came off the top of the pole, then used trucker's hitches to the forestay bridle tangs to set tension. This was about 4' back from the tip of the pole, and never gave a problem.
Pepin: on the I20, the spin sheet is a single line, cut so that when the kite is snuffed, the bight between the two turning blocks on the mainbeam will just touch the rear beam. There, it is passed thru a block on a long bungee which sucks the slack (most of it hehe) to the rear beam. Good luck to you both.
Posted By: pepin Re: 5.2 Spinnaker rigged! - 11/05/07 05:04 PM
Yes, same single line setup here. It's one line going from the kite sheet point, to block at the sidestay, to ratchet block at the main beam, through the other ratchet block, the other sidestay block and back to the kite. But my sheet line slack between the ratchets is way longer than what you describe when snuffed, but when the kite is up I need this length to get it to the rear corner where I expect I'll be sitting/trapezing when it's windy... I have 50 feet of the damn thing, and it's crowding my tramp upwind.
Posted By: bobcat Re: 5.2 Spinnaker rigged! - 11/05/07 05:10 PM
One of the F16 lads came up with this
SOLUTION. Scroll down the post and look at the picture. It is a system to gather up the sheets sooner, as the spinnaker is doused.
Posted By: gree2056 Re: 5.2 Spinnaker rigged! - 11/05/07 07:12 PM
My blocks are rigged just like yours only the blocks on the side stays are pretty long and give me about 1 inch of clearance from the daggerboard. If it won't hurt your angle you might try adding another shackle between the block and the stay, that would get it out further and maybe miss the board.
As for lines, my tramp can get pretty cluttered when I have all the sails up, but such is life.
