Catsailor.com Aerodynamics and lift
Posted By: gregP19 Aerodynamics and lift - 12/31/07 11:20 PM
Today on science friday on NPR they were discussing lift as it relates to airplanes. The speaker said that Bernoullies principle doesn't completely account for the lift that the air flow over an airplane wing generates. He said that according to Bernoullies principle a commercial jet would have to achieve 400knots to generate enough lift for takeoff. He said that this idea is a point of contention among scientists but the lift generated is as simple as air flow over the top of the wing being enough to push downward towards the earth. He cited examples such as a helicopter and the fact that fighter jets mount missles under their wings because the air flow there isn't that important. Anyone out there familiar with this "controversy"?
Posted By: Karl_Brogger Re: Aerodynamics and lift - 01/01/08 12:14 AM
There is two theorys on flight. Bernoullie, and Newtononian. Newton says it's from the air particles hitting the bottom side of the wing. Bernoullie says it is from a difference in pressures. The air traveling over the top of the wing has farther to travel so it is moving faster creating an area of lower pressure. The pressure difference is what creates the lift. The reality is that they don't fully understand how the lift is produced, only how to manipulate it. I only have limitied exposer to lift from the handfull of aviation classes I took when I was going to school for ATC.
Posted By: Robi Re: Aerodynamics and lift - 01/01/08 12:16 AM
I think it has more to do with airflow than lift. When you get on the highway next time, put your hand out the window traveling at speed. Change the angle and see what happens. You hand is not creating lift, but, the angle of attack is high enough that the air flowing above and under your hand forces your hand to go up or down. This force is not lift, but airflow. This is all about elevators, flaps and trim tabs. I am sure TIMBO can instruct much better on this.
Just like a rudder, a rudder without water flow is NOTHING, just an object in the water. Once the boat starts moving the rudders start doing there job.
I cant believe I just replied to this. This is what RUMS does to you.
MERRY NEW YEAR! <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Posted By: Timbo Re: Aerodynamics and lift - 01/01/08 02:59 AM
There are many books and websites that go deep into details I have long since forgotten, and I'm not about to get too deep here, I have things to do, but when it comes to a comercial airliner getting off a runway, it's not only the lift from the wing, there is also some -push- (we call it thrust) from the 2 (or 3 or 4) engines. The basic equation is; Lift + Thrust > Drag + Weight. The Thrust is added to the lift, to overcome the weight plus drag.
In a large comercial airliner, on take off, as you pull the nose up, (at say, 150 kts) the engines are now pointing down, at the runway, and they are "thrusting" (no dirty jokes here) the jet into the air, that thrust adds to the lift of the wings and helps get the airplane into the sky. Also, at takeoff, the wing is in a "high lift" configuration, with leading edge devices and flaps, all of which add to the camber of the wing. As the airplane accelerates after getting airborne, the flaps and slats are retracted to the high speed configuration.
And no comercial airliner wings that I am aware of are rated to much more than 360 knots (I'm talking indicated airpseed, and not the old, faster, 727's that could go above 380, but the newer stuff, since the 757) so the "have to go 400 to get airborn" remark isn't valid, we never go near 400 indicated, even though the true airspeed at altitude is about 480knots, or Mach .83, our indicated airspeed is only about 250 at cruise (35,000').
You have probably seen the videos on YouTube of the fighters going straight up, doing all kinds of impossible aerobatics. That's usually done on thrust, not lift. If you have an engine that puts out 50,000 lbs. of thrust in a plane that only weighs 40,000 lbs. you can put it on a rack, point it straight up, and launch it. No lift coming off the wings at all. Throw a rock striaght up, see? All thrust, no wings or lift needed.
My Supersonic Aero instructor once said, "If you put a big enough engine on it, you can make a barn door fly...but they had to put two of them on the F4!" (The F4 was known as the lead sled, big engines, kind of heavy, stubby wings) Take a look at the F104 sometime too, one of the fastest fighter jets of it's time (Viet Nam era) All engine, tiny wings, fast as hell, all on thrust.
Even with the propeller type aircraft there are many unlimited competition type acro planes that can just about hang on their prop, suspended in mid air, no airflow over the wing yet it can still do all kinds of stuff, so flying isn't limited to lift generated by the wing. Thrust is a big factor. The Space shuttle on launch has no airflow over the wing as it lifts off the pad, yet it still lifts off the pad.
Posted By: mbounds Re: Aerodynamics and lift - 01/01/08 03:21 AM
Recommended reading:
Posted By: Timbo Re: Aerodynamics and lift - 01/01/08 03:27 AM
And I like Frank Bethwaite's "High Performance Sailing". He was a pilot in the RAF (is that what they call the Aussie AF?) as well as a competition glider pilot, and a great sailboat designer, racer, etc.
Posted By: Inter_Michael Re: Aerodynamics and lift - 01/01/08 02:36 PM
You guys are all wrong! It's very simple: Money ($), and lots of it, make an airplane fly. <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
Posted By: Luiz Re: Aerodynamics and lift - 01/01/08 04:25 PM
Read chapter three of the free online book
"See How It Flies" by John Denker. It has the information you want and demonstrates why some common misconceptions are wrong.
Posted By: Timbo Re: Aerodynamics and lift - 01/01/08 05:56 PM
My favorite quote in regards to money and aviation, "How do you make a million dollars in Aviation? Start with 10 million..."
I was out flying a little plane last week, the fuel is up to $4.56/gallon for 100LL. Yikes! We need to get on that coal-to-jet fuel conversion thing right away!
Posted By: Rolf_Nilsen Re: Aerodynamics and lift - 01/01/08 06:02 PM
Coal to jetfuel.. Or:
http://en.wikipedia.org/wiki/Gossamer_Albatross <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Posted By: Timbo Re: Aerodynamics and lift - 01/01/08 06:09 PM
What I would really like to see is an electric motor powered type of glider, the wings covered with solar panels. Self launched using the electric motor and a batery, climb up above the clouds, fly around up there for ever, or until you have to pee... <img src="http://www.catsailor.com/forums/images/graemlins/blush.gif" alt="" />
Posted By: Karl_Brogger Re: Aerodynamics and lift - 01/01/08 06:52 PM
I used to buy av gas for $2.50/gal for my race quad. What a tradgedy.
Posted By: Wouter Re: Aerodynamics and lift - 01/01/08 07:40 PM
I'm paying 7.5 US/gallon for my car. You guys ain't seen nothing yet !
Posted By: Karl_Brogger Re: Aerodynamics and lift - 01/01/08 08:38 PM
Yeah, you also pay 90% taxes
Posted By: pitchpoledave Re: Aerodynamics and lift - 01/01/08 09:17 PM
Karl why don't you do your homework first before posting
Posted By: mbounds Re: Aerodynamics and lift - 01/01/08 10:52 PM
From Wikipedia:
"Netherlands
The sale of fuels in the Netherlands is levied with an excise tax. A 1995 excise was raised by Dutch gulden 25 cents (€0.11), the Kok Quarter (€0.08 raise per litre gasoline and €0.03 raise per litre diesel), by then Prime-Minister Wim Kok is now specifically set aside by the second Balkenende cabinet for use in road creation and road and public transport maintenance. The 2007 fuel tax was € 0,684 per litre or $ 3,5 per gallon. On top of that is 19% VAT over the entire fuel price, making the Dutch taxes one of the highest in the world."
I would venture to say that the fuel taxes in NED are more than 90% of the base cost of the fuel.
You should do your research before posting, Dave. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Posted By: Tony_F18 Re: Aerodynamics and lift - 01/01/08 11:20 PM
And if that wasn't expensive enough, in July diesel tax will go up another 3 cents. <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
Posted By: Karl_Brogger Re: Aerodynamics and lift - 01/02/08 12:08 AM
From Wikipedia:
"Netherlands
HAAA HAAA.
Bout pee'd my pants. Thanks Matt.
Posted By: HMurphey Re: Aerodynamics and lift - 01/02/08 03:25 AM
Guys,
You are getting off track, my compliments to "TIMBO" on his explination. If only my Professor for "GasDynamics" at Drexel Univ could have explained it so simply. Instead it took alot of chaulk dust and calculus with Greek symbols to get it through our young and impressionable minds.
Question: do you think the cats (if used) for the AC Regetta will have rotating masts so as to promote aerodynamics/lift at the higher boat speeds and apparrent wind velocities that a (90')? multihull could theroretically reach???
Harry
Posted By: Mark P Re: Aerodynamics and lift - 01/02/08 09:21 AM
Every once in a while a revert back to this article to remind me about sail shapes etc.
http://www.northsailsod.com/articles/article6-1.html Posted By: RobLyman Re: Aerodynamics and lift - 01/02/08 12:15 PM
The Newtonian explanation often falls short in explaining how lift is created when the foil is at low or zero angle of attack. What I have read lately seems to explain things well. A properly shaped foil will impart a downwash even at zero angle of attack. There is some "suction" created by the low pressure. This has been measured in studies with sensors above a wing. However, one misconception is that the fluid MUST join the stream at the same speed aft of the foil. Many studies show that the flow continues to move downward or toward the HIGH pressure side for some time/distance past the aft edge of the foil.
This effect manifests itself as wake turbulence (not the vortices at the tip, but downwash), helicopter downwash, "ground effect" and even in sailing in the form of a "safe leeward" position which actually backwinds the boat behind and a bit upwind of the lead boat while sailing upwind.
Posted By: Anonymous
Re: Aerodynamics and lift - 01/02/08 12:52 PM
Now that the experts are assembled, perhaps a conundrum can be resolved. My fancy, and expensive, new sails have thick threads running through them. They're really quite rough. What ever happened to smooth?
Don't we exalt smooth, seek smooth, lust for smooth? Is the world gone mad?
Regards
Chet
Posted By: Karl_Brogger Re: Aerodynamics and lift - 01/02/08 01:47 PM
A smooth golf ball doesn't fly as far or as striaght. A tennis ball with out fuzz won't go as fast with the same amount of force. Turbulant boundry layer? I think is what it is called. A small amount of air "clings" to the surface acting like a bearing for the rest of the air to move over. At least that's what I remember from physics.
Posted By: mbounds Re: Aerodynamics and lift - 01/02/08 02:43 PM
Regards
Chet
Karl is basically right - there are two basic types of boundary layers, laminar and turbulent.
Flows across sails start as laminar and transition to turbulent at some point:
Laminar flow has less friction, but is unstable. Turbulent boundary layers are more stable and less likely to separate from the sail.
The transition from laminar to turbulent depends on the viscosity of the fluid, the speed of the fluid and the roughness of the surface.
The bottom line is that the stitching and seams on a sail are within that viscous sublayer that's at the bottom of the sail's turbulent boundary layer that starts on the mast in all but the lightest windspeeds.
Re: Aerodynamics and lift - 01/02/08 03:05 PM
This laminar flow sounds great. Why don't I promote laminar flow on my hull and stop waxing the damn thing?
Regards
Chet
Posted By: Timbo Re: Aerodynamics and lift - 01/02/08 03:06 PM
Sooo...what about that Teflon Spray, (McLube?) does it help reduce surface friction over the sails, hulls and foils to spray that stuff all over your boat and sails? I've heard some of the mono guys do this. In Frank Bethwaite's High Performance Sailing, he tow tests two hulls, one polished to a high sheen and one not, and the polished hulls had less drag.
I know the guys who race airplanes at Reno wax the snot out of their wings to reduce drag, but the boundry layer is supposed to be about 1/16th of an inch, which would be more than the layer of wax, so does it really help reduce friction?
Talk amongst yourselves... <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Posted By: Inter_Michael Re: Aerodynamics and lift - 01/02/08 03:12 PM
When I last fueled, it was around $5.50/ Gallon, plus prist (Jet A). Our company has various accounts at different airports we frequent and can get as much as $1.50 off.
Back to lift. Is there not a difference between 'flying' and 'projectile'?
Sure, you may throw a rock and it 'flies' thru the air, but with no control. A missile also flies thru the air, with very little control. Rockets the same. Your comparison to the 'missile with a man in it' F104 is accurate, with enough thrust, you do not need a pressure differential. Aircraft of old, that had very little excess thrust/ power had very large, 'airfoil' shaped wings.
I am no engineer, but I think it is a blend of both principles that achieve flight. With smaller 'GA' aircraft, it is pressure difference as a result of wing shape, with newer business jets, its excess thrust, more efficient wings/ airfoils.
Ok, I think that is my 2 cents. BTW, check out this plane, radical design, excellent speed/ range, and very fuel efficient.
http://www.piaggioaero.com/en/products/aircraft/p180/showcase/showcase.php Posted By: Tornado Re: Aerodynamics and lift - 01/02/08 05:47 PM
Here's a good read on bottom smoothness:
Slip Sliding Away Sooo...what about that Teflon Spray, (McLube?) does it help reduce surface friction over the sails, hulls and foils to spray that stuff all over your boat and sails? I've heard some of the mono guys do this. In Frank Bethwaite's High Performance Sailing, he tow tests two hulls, one polished to a high sheen and one not, and the polished hulls had less drag.
Posted By: Luiz Re: Aerodynamics and lift - 01/02/08 07:27 PM
...with enough thrust, you do not need a pressure differential.
You need it.
In order to fly, a plane needs a force to counteract gravity. It also has a surface that you can't get rid of. As a consequence, a pressure differential will exist whenever the plane is flying in equilibrium.
In the case of thrust equal to (or greater than) weight, the thrust exerts a positive pression downwards that creates a pressure gradient in relation to the atmospheric pressure.
The correct expression would be something like this:
"A pressure gradient is required to counteract weight and achieve unaccelerated flight. The gradient may be provided by any onboard device, including an airfoil flying at an angle of attack, a rotating airfoil at an angle of attack, an internal combustion engine with its propeler, a turbine, a rocket, etc."
Posted By: Luiz Re: Aerodynamics and lift - 01/02/08 07:37 PM
I thought your link would send us to Victoria's Secret website...
Posted By: Smiths_Cat Re: Aerodynamics and lift - 01/02/08 08:17 PM
Hi Greg and all,
actually there is no controvery between Newtons and Bernoullies laws. The formulas which describe the behaviour of fluids are called Navier Stokes equations. One part of them are Newton laws. You may look in Wikipedia to see these equations. With some assumptions, you can simplify the Navier Stokes equations to Bernoullies law.
I guess that the speaker in the TV just wanted to explain, that you need more formulas then just Bernouilles law.
...fighter jets mount missles under their wings because the air flow there isn't that important.
It is true, that the upper surface is more sensitive than the lower surface. Hence it is better to have the spi halyard on the lower (pressure) side of the sail and not on the suction side.
In fact the boundary layer of our mast and sails is turbulent due to roughness, contamination and oscillation,
but it may be usefull to fix the separation point, i.e. have a mast with roughness at the leading edge to prevent early separation.
Cheers,
Klaus
Posted By: Delane Re: Aerodynamics and lift - 01/03/08 11:58 AM
Hello All,
While researching information on Hydrofoils for my project I came accross and interesting web site that forever supper explains wing lift theory in a simplified manner just when I thought I knew most of it. Check out " A Physical Description of Flight" by David Anderson & Scott Eberhardt or web site
http://home.comcast.net/~clipper-108/lift.htmLet me know what you think!
Delane
Posted By: Timbo Re: Aerodynamics and lift - 01/03/08 03:45 PM
Why are we talking about flying on a sailing web site anyway?? There are tons of flying web sites for that. Can we at least talk about hydrodynamics or something, hull shape, lifting hull shapes, foils, etc. Calling Pete Melvin, HELP!
I think the "next big thing" speed wise, in the world of sailing is going to be foils, not wings, (sorry Ben) and if we have nothing better to discuss (it being the dead of winter up here in the Northern Hemi, even here in Florida it is only 30 degrees out right now!) how about we discuss that?
I am really impressed with what Rohan Veal has done with the Moths. I think the same could be done with cats and it would yeild a more stable, faster craft than the Moth. I liked Dave Carlsons inverted A foils on his Jackalope. Dave, more pictures! <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Posted By: FasterDamnit Re: Aerodynamics and lift - 01/03/08 03:48 PM
What about canting rigs? If the mast can pivot it can also lean...
A continuous line stay to stay, decent amount of purchase, change it on each tack. Reduce heeling moment significantly.
Posted By: Timbo Re: Aerodynamics and lift - 01/03/08 03:51 PM
I think some of the high tech tri's and mono's are doing that now, helps lift the boat up out of the water a little bit, kind of like a windsurfer, tilted upwind (towards the high side of the boat).
I don't see why we couldn't do it on our cats, just need to work out the details. Have any of the A cat guys tried this or is it outlawed?
Posted By: fin. Re: Aerodynamics and lift - 01/03/08 04:03 PM
Something else to break! <img src="http://www.catsailor.com/forums/images/graemlins/frown.gif" alt="" />
Posted By: Timbo Re: Aerodynamics and lift - 01/03/08 04:19 PM
Here's what I'm thinking: Take the daggerboards, move them forward near the main beam, and mount the slot on a 45 degree angle, tilted inwards, so the boards slide in towards under the boat, not outwards, put some T's on the rudders, Voila, lifting boat! Not so much to add, just move the daggers and add T's to the rudders, which has already been done on the Moths and 18'skiffs. All we need is someone with the time and money to work out the details. No, I don't have any spare time, or money!
Posted By: FasterDamnit Re: Aerodynamics and lift - 01/03/08 04:21 PM
Posted By: Luiz Re: Aerodynamics and lift - 01/03/08 05:54 PM
...just move the daggers and add T's to the rudders, which has already been done on the Moths and 18'skiffs. All we need is someone with the time and money to work out the details...
If you mean something like this...
...my test sails will start in a few days. Those "details" are not as simple to work out as it would seem at first sight.
Posted By: Tornado Re: Aerodynamics and lift - 01/03/08 06:02 PM
Congrat Luiz!
I know it's been a long, hard struggle!
Get more photos and tell us how she goes...
Mike.
Posted By: Timbo Re: Aerodynamics and lift - 01/04/08 02:34 AM
Luiz, yes, just like on the Amas there, only on a cat, with T rudder foils to lift the back end. Please keep us informned of your progress!
Posted By: Jake Re: Aerodynamics and lift - 01/04/08 03:05 AM
A FEW DAYS! Wow! Please tell us how it goes! A lot of blood in that one!
