Posted By: Anonymous
Nacra mainbeam and dolphin striker - 03/31/08 08:36 PM
I have recently reassembled the main beam on my Nacra 5.8. The original mast bolt was bent and needed replacing. I need to know how to tension the striker and what torsion should the main beam have. Anyone know?
Posted By: P.M. Re: Nacra mainbeam and dolphin striker - 04/01/08 01:14 AM
According to the factory, 3/8 inches of prebend on the front beam.
Re: Nacra mainbeam and dolphin striker - 04/01/08 01:19 AM
Thanks for the reply mummp.
Where did you get that information? Since I am reassembling the cat, I would find that source valuable.
How would you measure a prebend of 3/8"?
Posted By: jcasto1 Re: Nacra mainbeam and dolphin striker - 04/01/08 04:12 AM
Make a straight line from end to end of crossbeam, without mast in place. The ends of crossbeam should be lower than middle by amount of prebend.
Posted By: P.M. Re: Nacra mainbeam and dolphin striker - 04/01/08 01:50 PM
Tobin,
Keep it simple, with no load on the beam your beam should be level and/or "straight", then simply screw the lower nut up 3/8 in. and then tighten your upper nut. Just curious, after you straightened the rod, did you put a compression tube back inside the beam? If you did I hope you marine greased the snot out of it. . .
Re: Nacra mainbeam and dolphin striker - 04/01/08 08:23 PM
I didn't, but i reassembeled it just a week ago and haven't tightened it yet. Where should I grease the snot out of it? And why?
Posted By: JACKFLASH Re: Nacra mainbeam and dolphin striker - 04/01/08 09:58 PM
Where the stainless sleeve comes into contact with the aluminum crossbar due to electrolosys (sp) that will occour there.
Posted By: catman Re: Nacra mainbeam and dolphin striker - 04/01/08 10:17 PM
And this is the best stuff to use.
tefgel Posted By: P.M. Re: Nacra mainbeam and dolphin striker - 04/01/08 11:24 PM
. . . . and also the inside of the compression tube.
