Posted By: roccats
Rick White's Magnificent Pole - 05/01/08 04:05 PM
I recently aquired the Rick White Super Power Righting kit in the mail and was a bit confused as to how it is going to work.
The universal 3 axis joint for the pole seems to be free in all 3 axis. I assume the writing force is being taken by the line running to the "beam loops" rather than the pole. Is this correct?
If so what stops the line from running free ( or just slacking) and the pole from pivoting downards? Is it just the small stopped knot in the line? Are you then not able to dynamically adjust the angle of the pole since it is determiend by where the knot in the line is?
Is the righting line a single loop, starting tied off to one end of the pole, traveling through a beam loop, then across the cross beam, through the 2nd beam loop and then comming back to tie off on the pole again?
Any picture or even beter a schematic of the system would be a huge help. The pictures on catsailor are a bit hard to see exactly how everything is rigged.
Any help would be greatly appreciated!
