Rudder Alignment
Posted By: PeelSkid
Rudder Alignment - 06/18/08 10:16 PM
How do you do a rudder alignment?
If rudders make a lot of whinning noise is this because of alignment or just going fast?
Posted By: SurfCityRacing
Re: Rudder Alignment - 06/18/08 10:49 PM
If rudders make a lot of whinning noise...
Sometimes this will help:
Posted By: Tornado
Re: Rudder Alignment - 06/19/08 03:45 AM
Rudder hum at speed means you;re going slow <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" />
since your blades are shedding vortices off their trailing edges. You need close to 1/16" to completely remove hum and minimize drag.
Lots of production cats do not come with blades properly faired...it's easier/cheaper to make a blade with a fatter trailing edge than a high quality thin one.
I recommend fairing down the last 1/3 of the blade with progeressively finer grain wet/dry sanding. Ideally, you don't want an obvious angle right at the last 1/2" from the edge...but if that helps and you're not too concerned with getting ultimate performance, then go ahead and use the scissor method.
Mike.
Posted By: Ventucky Red
Re: Rudder Alignment - 06/19/08 04:06 PM
Think of it this way; noise = vibration, vibration = friction and friction = drag - and that's a drag!!!
Posted By: walkefmb
Re: Rudder Alignment - 06/20/08 01:36 PM
I found my vibes in the bearing or washers between the rudder and the head. The damn sand wore enough of the material away to create a bit of play and thus a very annoying hummmmmmmmmm.
© 2024 Catsailor.com Forums
