TILLER EXTENSIONS
CST Tiller Extensions combine the properties and appearance of carbon fibres, aramid fibres and heat cured epoxy to produce what we think is the best tiller extension yet for dinghies like the 49er, laser... the list goes on.
We couldn't see the point of having a tiny tube with added padding - we've made ours 22mm untapered so it's easier to grip. Also the fibres aren't unidirectional -by orienting fibres off axis we've engineered a little bit of bend and improved the durability. The final layer is an open weave spiral helix in aramid (Kevlar) fibre which further improves damage tolerance and grip. It also aids to keep the extension in one piece even if the carbon fibres are broken. This could be the difference between a finish and a DNF...
Suitable for Optimist, Cadet. MJ, Sabot, Flying ant, Laser, Finn, 470, 420, NS14, I14, B14, 49er, Hobie, A-Class Cat, 18' Skiff, and more....
Construction: Carbon and Aramid fibres in heat cured epoxy matrix.
Production Method: Computer controlled filament winding.
The tiller extensions below are supplied with end cap and fitted polyurethane universal unless otherwise stated.
