Posted By: Krisu13 I20 Dagger board trunks cushion tape - 08/13/08 08:25 PM
I’m looking for the “cushion tape” (for the lack of better word) used in dagger board trunks in I20. I looked in online store on this website and Murray’s and I can not find one.
Thanx
Posted By: ksurfer2 Re: I20 Dagger board trunks cushion tape - 08/13/08 08:43 PM
I went to a local hardware store and purchased a roll of Velcro tape. Used the fuzzy side in the trunk on my N20. Works great!
Posted By: scooby_simon Re: I20 Dagger board trunks cushion tape - 08/13/08 08:44 PM
Is your stuff the same in Laser Daggerboard trunks? If so look for Slegel tape (it might be Schlegel tape)
I've used it in my inter 17 with no problems
Posted By: Anonymous
Re: I20 Dagger board trunks cushion tape - 08/13/08 09:18 PM
i recently used 2 sided tape that has a soft foam center (almost sounds like an oreo ad) about 1/8" of thickness to cushon my centerboards.
i simpy left the tape on one side. it works perfect, but not sure if my discription will explain what the tape is... or if it will help you in your application.
Posted By: Jake Re: I20 Dagger board trunks cushion tape - 08/13/08 09:51 PM
I use regular cheap-o carpet from a home improvement box store, cut a strip, and glue it in with Windshear (that stuff glues anything). I tried contact cement and it makes it impossible to install properly and doesn't hold well if you put it in all wet and gooey.
Posted By: TEAMVMG Re: I20 Dagger board trunks cushion tape - 08/13/08 10:12 PM
I used a strip of fuzzy draught excluder that goes between the sliding sections of a UPVC patio door!
Posted By: Ventucky Red Re: I20 Dagger board trunks cushion tape - 08/13/08 10:43 PM
Posted By: Krisu13 Re: I20 Dagger board trunks cushion tape - 08/14/08 12:16 AM
Thanx everyone for the fast reply.
I will go with boars carpet form
http://www.apsltd.com/Kris
Posted By: _flatlander_ Re: I20 Dagger board trunks cushion tape - 08/14/08 03:22 AM
We used carpet at the top and
this stuff at the bottom
