Posted By: FasterDamnit Carbon spin pole- repair how to? - 09/01/08 03:04 AM
We have an end snuffer pole w/ a clean break and some carbon cloth left over from Scollon Productions (mascot costumes.)
Can we use the same resin as for fiberglass? What would you use as internal piece to keep it aligned while the CF sets up?
Thanks.
Jim.
Posted By: warbird Re: Carbon spin pole- repair how to? - 09/01/08 07:42 AM
same resin.
use a binding cloth or tape to squeeze the carbon flat and tight to the surface. Squeezes out excess resin and strengthens job.
Posted By: Jake Re: Carbon spin pole- repair how to? - 09/01/08 01:30 PM
use epoxy resin (the same you would use with glass). Don't use polyester - it is a weaker material and it doesn't adhere to the carbon fibers as well. For squeezing the wetted fabric, use two layers of electrical tape. It will remove cleanly once cured.
I recently repaired my hotstick by making a jig to align the two broken pieces, then wrapping with several layers of wetted carbon (epoxy), taped with electrical tape, lightly perforated the electrical tape with a nail, and let it cure. (the perforations allow excess resin to seep out). A light sanding after removal of the vinyl tape is all that's needed.
Posted By: dave mosley Re: Carbon spin pole- repair how to? - 09/01/08 02:49 PM
Jim, what the hell are you making, and when are we going to see it?
Posted By: Breakwater Re: Carbon spin pole- repair how to? - 09/01/08 03:06 PM
Here's a good video instruction.
It's for building a spin pole new, but the principles are the same for repair.
http://www.youtube.com/watch?v=xblAy-lAN0E Posted By: FasterDamnit Re: Carbon spin pole- repair how to? - 09/01/08 03:08 PM
Dave,
Check the boat home building forum.
Just 18HT hulls w/ Gcat rig for now. If we don't make Catfest, we should make Outback.
It won't be pretty...
Posted By: dave mosley Re: Carbon spin pole- repair how to? - 09/01/08 04:34 PM
coming soon- 18 ft of "W*T*F?"
Thats funny, but who knows until it hits the water....Looks like TS Hanna may bring some good wind in for Catfest, we are scheduled to go at the moment....
Posted By: FasterDamnit Re: Carbon spin pole- repair how to? - 09/01/08 04:41 PM
So are you only racing the A these days?
Posted By: dave mosley Re: Carbon spin pole- repair how to? - 09/01/08 07:33 PM
its the only boat I have, other than my son's H14 and his Opti. I havent been able to sail much lately, but hope to be back on the water for a few Fall races.
david
Posted By: Timbo Re: Carbon spin pole- repair how to? - 09/01/08 07:40 PM
Is it an optical illusion or is that jib tack look way too close to the mast? I suppose you had to use the tangs already in the bows for the cross piece for the tack?
Why did you go with this rig instead of the original mast? Is it broken?
I have thought about putting up my H14 sail on my F16 when it's blowing 25+ but have yet to try it.
Posted By: FasterDamnit Re: Carbon spin pole- repair how to? - 09/01/08 08:35 PM
The jib is close, but it is a work in progress. We are starting with existing front stay mounts to set the cross bar since this does not require any modifications to the hulls. Also, the original G-cat rig did have a lot of jib overlap (damn near a genoa.)
The hulls came with just crossbars, tramp and traveler with the rest coming from our totaled G-cat.
This is phase 1. Long term it will have a square top main and high aspect jib w/ spin.
If it sails respectably with this rig, next step will be to get the spinnaker working.
Posted By: FasterDamnit Re: Carbon spin pole- repair how to? - 09/01/08 08:40 PM
david
Same here. Hope to see you there.
Posted By: dacarls Re: Carbon spin pole- repair how to? - 09/02/08 02:33 AM
Franken-boats are so much fun! Genetic engineering sometimes yield surprises!
Posted By: FasterDamnit Re: Carbon spin pole- repair how to? - 09/02/08 02:49 AM
True.
And honestly, the building is as important in this case as the sailing. Maybe more so...
Posted By: zander Re: Carbon spin pole- repair how to? - 09/02/08 01:42 PM
Hey Mosely. What's the word on the outback cup?
Posted By: dave mosley Re: Carbon spin pole- repair how to? - 09/02/08 04:47 PM
Outback is on, and I hear they have a great band lined up.....
Carraba's cooking friday night, Outback Saturday night...how could you go wrong or hungry?
Posted By: ThunderMuffin Re: Carbon spin pole- repair how to? - 09/02/08 04:59 PM
is it "Who's Bad"?
http://www.myspace.com/whosbadmusic(sorry for the shameless plug of my friends' band)
Posted By: zander Re: Carbon spin pole- repair how to? - 09/02/08 05:46 PM
We're used to you being shameless. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
