Posted By: claus
How to taper main sheet? - 10/08/08 06:12 PM
I would like to improve my stock 8:1 mainsheet on the Tiger.
I have already found information in an older post on this forum about how to do obtain a 10:1, adding a 5er upper 57 block and another 40 block on the lower end to obtain 10:1.
I also would like to taper the mainsheet, say some 5mm (is this enough?) dyneema stiched into my old sheet. I could not find any guide about how to stich the two sheets together. How do you make shure it holds? What about the transition from thick to thin? Do you know any guide how to do this?
This is the system I found in another post, I would only need to add a single block at the lower end and get the 5er block. BTW, my system is the older one not the ratchamatic
