I got about 3/8" into the bolt and now ,my progress has slowed dramatically. Easy outs can't seem to get enough bite and round out,plus I'm deathly afraid of breaking one off in the hull. Any pearls of wisdom would be greatly appreciated.
Tawd
Todd,
Having many years of expience with race cars and mechanical stuff in general....easy-outs usually only work when the bolt is not very tight in its hole.
Keep in mind that the extractor is usually smaller in diameter than the bolt that is stuck and that broke off to start with.
Once the extractor breaks, you are in much deeper s..t!
There are several techniques that
might work. All are risky.
My first choice would be to make sure you have brand new drill bits. Try to get a small hole started dead center in the old bolt.
It is best to drill all the way though and then keep drilling larger and larger holes until you get to the minimum diameter of the theaded hole.
Usually by then, you can get a proper tap started and rethread the hole.
Another method that sometime works is to drill a pilot hole and the get a left-hand bit that is slightly smaller than the bolt minimum thead diameter. Often before you get too far the old bolt comes right out.
Left hand drill bits are available from the Snap-On or other tool trucks and certain hardware specialty stores. Also on line.
Once out, if the threads are damaged, you can repair the hole with a HeliCoil insert.
The key is to go slow and keep the drill centered and lubricated.....and SHARP.
We've all been there boy!
