Posted By: nutsy
spitfire gelcoat crack - 11/11/08 04:49 PM
Hi there,
Having sailed a plastic dart 16 for many years, i recently bought a spitfire, so am new to fibreglass boats.
The boat i bought developed during the handover a 4"ish long crack in the gelcoat at the seam where the two hulls join on the top of the starboard bow (in front of the trampoline.
The crack doesnt seem to penetrate any deeper than about 1 mm or so, so i think its just the gelcoat - however the gelcoat seems to have lifted slightly on the raised side of the crack for about 1cm or two, on the outside (starboard side of the hull).
Wondering what caused it, i took a closer look today and found a small circular area (about 2-3" diameter) patch of hull that flexed slightly more than the surrounding area (which was all solid). This was on the outside (starboard) side of the hull directly below the crack, about 6" away. All around the crack feels solid.
Photos are here : http://www.nutsy.co.uk/bekabean/v/Mike/temp/spitfire/
Could this be a dreaded soft spot? Is it likely to get bigger? What could have caused it? I was planning to tape up around the crack (to prevent water ingress) and go sailing this weekend, is that a good idea?
Boat is about 5 years old. Am i just being paranoid after being used to a nice bouncy plastic boat?
Thanks in advance for any help or advice!
