Posted By: davefarmer
Technical assistance requested - 06/18/09 05:13 AM
The original main that came with my Boyer A cat has a ring attached to the head of the mainsail which engages a hook at the masthead. The small black foam block provides enough forward tension to allow the ring to move aft slightly as it hits the hook, and spring forward as it tops the hook, to engage. Works well. The sail is then forced up the luff groove(no hlyd), and the mast is rotated 90 degrees, and the sail pulled down to disengage from the hook. Pretty similar to many beachcats.
The newly acquired(used) sail has nothing to provide that slight forward tension. The ring hits the hook on the way up, is pushed aft, and stays there, not engaging the hook. I need a way to provide that small amount of forward pressure for the system to work properly. Ideas?
Dave
Dave
