Catsailor.com Bow design – Theory or Looks?
Posted By: TheManShed Bow design – Theory or Looks? - 07/26/09 09:30 PM
Here is topic for all sailors: Bow design – Theory or Looks?
Ok I’m baffled! What is the real skinny on this?
What is your though and is fact or Personal Preference?
Basically I see three schools on this:
The Classic Look – Bow at the deck level longer then the waterline with graceful curve to the water line.
Straight or slight taper – From the deck slightly longer then the waterline or straight.
Wave Piercing – I’ll call this A-Cat look the deck length is shorter the water line. So the there is a “reverse angle” from the classic look. Usually almost a straight line or a slight taper from the waterline back to the deck.
I can design the bows of the TMS-20 to any of these looks. Currently the design calls for a straight line on the main hull and a classic look on the ama’s.
Your thoughts?
Posted By: Robi Re: Bow design – Theory or Looks? - 07/26/09 10:11 PM
Wave piercer looks so much cooler.
Posted By: simonp Re: Bow design – Theory or Looks? - 07/26/09 10:14 PM
Definitely.
Posted By: simonp Re: Bow design – Theory or Looks? - 07/26/09 10:17 PM
Maybe look to the dollars spent on research and design for the America's Cup boats and leverage your design on that(without spending the same dollars).
Posted By: FasterDamnit Re: Bow design – Theory or Looks? - 07/26/09 10:50 PM
If you really want to dig into this-
http://www.boatdesign.net/forums/sailboats/wave-piercing-pitching-damping-marketing-18037.htmlBows with volume at the water line and finer at the top recover easier from submersion as the drag is lower as it rises vs. diving. Stick a conventional bow in that is wider at top, drag goes up faster, the bow slows down vs. the rig and over you go. The Bimare Javelin 2, 18Ht hulls are plumb, but have this configuration, volume low and skinny at the top. The N20 has tall bows for extra volume but are quite fine- different approach.
18HT
Ben Hall on his winged A cat-
bow shot of HT
Posted By: pepin Re: Bow design – Theory or Looks? - 07/27/09 12:07 AM
On my Stealth I have canoe bows. You forgot those in your list
I've never seen those on any other cat, they look funky, but like a canoe the buoyancy is at the bottom and the top is all skinny.
Posted By: ncik Re: Bow design – Theory or Looks? - 07/27/09 12:32 AM
Most significant effect of "wave piercing" bows on sailing multihulls is windage reduction..."wave piercing" benefits are marginal (and maybe negative, particularly if poorly designed)...I don't believe resistance will be less with the bow under the water...in my opinion.
I think it is more fashion over function in smaller boats.
Read comments by MalSmith in above boatdesign forum link.
Posted By: TheManShed Re: Bow design – Theory or Looks? - 07/27/09 12:57 AM
My main hull bow come to a fine point at the tip then grows wider. The bow height is the highest
point of the hull. Also it has a bowsprit on the starboard side of the bow for the screacher and spin.
I have a flair that starts just past the bows very slight at first then significant to the stern.
The family will be back from vacation, they took the camera, I hope to pull the foam out of the mold
again and get some shots of the half hull foamed out to show the shape of the hull and posted it on
the web site.
Today I laminated a foam strip to form the bow stem and started to bog the inside of the hull to fair
it out. What a job there are compound curves and the foam strips lay worse on the inside. The outside
will not be as bad to fair out. I also have a drawing of the ama lines to post I update the website next.
Posted By: Karl_Brogger Re: Bow design – Theory or Looks? - 07/27/09 02:58 AM
Your effectively making the water line longer as well. If the longest point is always in the air, its not doing anything usefull.
Posted By: DennisMe Re: Bow design – Theory or Looks? - 07/27/09 08:50 AM
TMS, what about utility?
After all you may want to be able to stand on the bow tips when docking (or, if push comes to shove, fend them off). What about being able to see how long you really have before you hit the dock etc? I can't offer any solutions, but you may want to think about the bow shape from a practical point of view also.
Posted By: Tony_F18 Re: Bow design – Theory or Looks? - 07/27/09 12:18 PM
You should checkout the discussion over @ SA about the BMWO bow-down pics and wave piercing amas:
http://forums.sailinganarchy.com/index.php?showtopic=93626 Posted By: waterbug_wpb Re: Bow design – Theory or Looks? - 07/27/09 08:57 PM
I thought AC boats were designed to a box or formula, which may influence their design. Maybe something like Open type boats, but those are monohulls designed with heel in mind.
Is there a class of trimarans not limited by some formula? ORMA 60's?
Posted By: Anonymous
Re: Bow design – Theory or Looks? - 07/27/09 10:38 PM
Only a self imposed box. BMWO's challenge document said their boat had LWL of 90' and a beam of 90' . The only constraints on the swiss is lwl<90' if a sloop or LWL<115' if its a schooner or ketch.
Posted By: ncik Re: Bow design – Theory or Looks? - 07/27/09 11:10 PM
"The Race" boats weren't restricted.
Posted By: ncik Re: Bow design – Theory or Looks? - 07/27/09 11:14 PM
Don't take too much technical stuff out of the SA discussion, it's more of a pissing contest between pro-Alinghi and pro-BMWO posters.
For the record, I don't like the look of those submerged hulls and Alinghi doesn't have a trim problem! hahahaha!!!!
Posted By: Tornado_ALIVE Re: Bow design – Theory or Looks? - 07/28/09 08:33 AM
Wave piercer looks better stationary
Nothing beats the sheet of spray that comes of a Tornadoes bow at pace.
Posted By: Luiz Re: Bow design – Theory or Looks? - 07/28/09 03:02 PM
Lots of spray = lots of energy wasted.
Posted By: Don_Atchley Re: Bow design – Theory or Looks? - 07/28/09 10:12 PM
Sailing Math
Lots of energy wasted < Looking Cool
Therefore:
Looking Cool > lots of energy wasted
And so furthermore:
Lots of spray = Looking Cool, and cancels out any concern for energy wasted
Re: Bow design – Theory or Looks? - 07/28/09 10:26 PM
I don't care what everyone says about you Don, you're a Genius.
Posted By: TheManShed Re: Bow design – Theory or Looks? - 07/28/09 11:47 PM
Wettest ride has to be a Supercat 20 I wear goggles and a snorkel
Posted By: TheManShed Re: Bow design – Theory or Looks? - 07/29/09 12:43 AM
Bow view and stern view. Remember this is the roughed in foam
Description: Bow View TMS-20
Posted By: TheManShed Re: Bow design – Theory or Looks? - 07/29/09 01:19 AM
Few more views with side laying flat. It's about 3 feet tall for an idea of the size
10762
10763
Description: Front view of bow on side
Description: Angle looking from bottom of hull towards side from bow position.
Posted By: simonp Re: Bow design – Theory or Looks? - 07/29/09 02:13 AM
Sailing Math
Therefore:
And so furthermore:
Love it!
The stingray has to be one of the coolest cats around then.
Not only does it have the tornado bow, but also a front beam. When the front beam touches the water at speed it produces a very spectacular cartwheel. And cartwheels are cool too right?
I remember my amazement at how the Nacra 5.8 handled differently to the stingray. Whereas the the stingray would go up and over the wave. Mostly. With enough wind the 5.8 would just say F#$% ^#F, and go straight through, just like a wave peircer should i guess.
Then moving to the Taipan, I found that it would slice through those waves so easily compared the 5.8.
I cant be sure, but I think my current boat, an ozBlade, needs a bit more energy than the taipan, but much less that the 5.8, to get through a wave. If it does dig in though, it definitely recovers much easier than both.
Posted By: TheManShed Re: Bow design – Theory or Looks? - 07/29/09 04:23 AM
The G-Cat 5.7 is great in the waves. I think that is why I kept it all these years. It was once given the “Cadillac of Rides” rating. There was a string about a boat to ride up on beach with. I went through 3 bottoms hitting the beach over the last 25+ years; each time I had to lay-up more glass on the fine V-Hull bottom, as the years of beaching would sand it away. When we (the boat and I) were younger I’d land on the beach flying a hull.
It was easier to sail up the beach then to pull those dual knife-edges through the sand. I have never pitch poled the boat even when buried up to the center beam front tramp and all. I’ve done a few cartwheels with it though.
Posted By: CaptainKirt Re: Bow design – Theory or Looks? - 07/29/09 06:37 AM
Agree with the smooth ride on the G-cat 5.7 AND the "joy" of trying to pull that sucker up a fine sand beach! IMO the Nacra 5.0 and 5.7 also are pretty smooth (fine/deep hulls) but not as smooth as the G-cat. Heard Hans is back building boats??
Kirt
Posted By: Tornado_ALIVE Re: Bow design – Theory or Looks? - 07/29/09 11:49 AM
Sailing Math
Therefore:
And so furthermore:
Thank you sir, could not have said it any better myself
Posted By: bvining Re: Bow design – Theory or Looks? - 07/29/09 11:53 AM
Mike,
The wave piercing bow is the end result of moving more volume down to the waterline while keeping surface area constant (or reducing it.) The Acat designs did this because once you've moved the volume down to the waterline you need to remove surface area or you will end up with a boat that is too heavy for the box rule. Other designs moved volume down to the waterline in an effort to reduce wetted surface area that generally results from loading up traditional multihull shapes. Traditional multihull shapes have always suffered from adding weight as the surface area increases quickly as compared to a traditional mononhull shape.
So the net effect of moving volume down to the waterline is a pear shape with the topsides being thinner than the waterline. Once you take this shape to the bow, your classic bow shape is upside down and becomes what is being referred to as a wave piercing bow. That description is a bit misleading because even though the bows may seem to pierce a wave, the rest of the boat doesnt actually pierce the wave and the boat if affected by the wave at some point in a way thats pretty much the same as a boat with regular bows. The designers were/are more concerned with the waterline shape/volume than the bows and the bows are really just the end result of moving the volume down to the waterline.
The side benefit (and I own a wave piercing Acat) is that you can submerge the bows and the boat wont pitchpole as easily. See the recent BMWO trimaran shots for illustration. Sailing around with submerged bows like BMWO probably isnt fast, but if this happens in a gust, or during a bear away its a nice feature to have the bows keep moving underwater with little or less drag than traditional flat top bows. The boat doesnt really pierce a wave, the wave affects the boat in basically the same way. Think about a H16 and how the bows slow dramatically when they are submerged, this is what the wave piercing bows resist/avoid.
The downside of a bow with a pointy topsides is that you lose a bunch of utility, you cant walk on it, you cant attach hardware to it easily, etc.
So when you ask the question, you really need to talk to the designer and see what he thinks, and look at how he has the volume in the ama's and what the whole picture looks like. Having ama's that dont pitchpole as easily is a good idea for a 20 ft tri and something that I would consider having.
Deciding on the bow shape should be done in concert with the rest of the hull shape and boat design and not as a separate design decision.
Bill
Posted By: bvining Re: Bow design – Theory or Looks? - 07/29/09 12:20 PM
Nice work by the way.
Re: Bow design – Theory or Looks? - 07/29/09 01:26 PM
Yes, last year he built a 35' g-cat power boat... (its for sale)
He is now building a few F-16's for this years nationals.
He has been doing some pretty cool R&D last weekend too...
Re: Bow design – Theory or Looks? - 07/29/09 01:29 PM
Thats amazing... I have seen several G-cats pitchpole... and i sail with a guy who says if you get his more than 3 or 4" above the decklid... over you go.
dont forget the flippers!
Posted By: FasterDamnit Re: Bow design – Theory or Looks? - 07/29/09 01:53 PM
Such as??
Re: Bow design – Theory or Looks? - 07/29/09 02:25 PM
hydrodynamic flow controls
Posted By: Rolf_Nilsen Re: Bow design – Theory or Looks? - 07/29/09 04:41 PM
Hope he gets them done and tested before the Global Challenge at Gulfport Yacht Club running from 9th till 14th November. Would be great to have a new design there.
Posted By: TheManShed Re: Bow design – Theory or Looks? - 07/29/09 10:38 PM
Andrew maybe he was a small guy....;-) to pitch pole.
Posted By: TheManShed Re: Bow design – Theory or Looks? - 07/29/09 10:58 PM
I'm sticking with the original (modified) design for the TMS-20 we have a lot a re-design time and $$'s invested. I could change my mind if I get overwhelming evidence but it seems to be more of personal taste.
I have Mark’s A-Cat at the shed and looking at the design I see the lower and “flat” waterline carried forward to the bow.
I spoke to Hans some time ago and he was messing with the F16’s but I’m not sure he is following through with it. He is fish farming and doing very well. The power cat has been around for some time and first started as a sailboat I think he is messing with the power cat some on the side.
Few years back my buddy and I where flying air-borne off of short stacked 6-8 footers off of Smathers Beach in Key West during an annual spring break spring camp out. I went block to block as we launched. We ended up digging into the face of the wave in front of us instead of landing on the crest. Forty-five degree bow first clear up to front beam at about 15 knots. The boat, not us, the boat stopped and popped backwards, surfaced and took off again surfing the wave trying to pitch pole. I’m standing on beam climbing up and back to cut the main sheet. Good thing the crew was hooked up but not out. I went flying like a rag doll body slammed him hard. It’s nice to have a good crew!
Posted By: David Parker Re: Bow design – Theory or Looks? - 07/30/09 03:02 AM
It would probably be best to re-post this under its own thread but I'll start it here.
Like Andrew, I've seen Hans working out details on his new F16 project. Now he is quite vocal that he will be producing as many as 5 GCat F16s in time for the Global Challenge in November in Gulfport, FL. If you visit his
www.g-catmultihulls.com website and go to News you will find that he is looking for
TEST PILOTS for his new boats! Whether or not you think a boardless boat can compete with a Blade or Viper, here's a chance for Florida sailors to warm up on Hans' new ride and help him out with your opinions. Experienced only need apply.
GCat F16 press release Posted By: Robi Re: Bow design – Theory or Looks? - 07/30/09 03:19 AM
I did not see an email to submit information for test skippering.
Ooops nevermind.
Posted By: David Parker Re: Bow design – Theory or Looks? - 07/30/09 03:28 AM
Robi, you'd be a good choice. You know the F16s, F18s, the local waters, and you need a chance to rebuild your karma with the GCat. Good or bad, Hans is staking his money on his design. Find some big air and rip it up!
Posted By: FasterDamnit Re: Bow design – Theory or Looks? - 07/30/09 03:36 AM
Wow. Hans is making some some pretty big claims. If he can match current daggerboard F16's I would think that would be quite an accomplishment.
Not so sure about the lack of spray claim. The 5.7 on a reach in over 15 knots created a fire hose straight up the side of the hulls as you went over every wave. I was trapped out, wearing an old Douglas Gill dingy foulweather, one piece suit and the spray was hitting my ankles hard enough to soak me up the legs to my chest.
Posted By: Robi Re: Bow design – Theory or Looks? - 07/30/09 03:42 AM
I sent an email. I proposed to Hans to bring one down to GYC to compare against the F16 fleet there.
Posted By: davefarmer Re: Bow design – Theory or Looks? - 07/30/09 04:21 AM
Mike,
Bill
Excellent description of the theory involved Bill! Thank you!
Dave
Posted By: Wouter Re: Bow design – Theory or Looks? - 07/30/09 08:02 AM
Yeah, what Bill said !
All the other talk about the "wave-piercer" bows is just BS.
Posted By: TheManShed Re: Bow design – Theory or Looks? - 07/30/09 02:34 PM
Looks like Hans is on the move again. Great news it will be interesting to see an new era for G-Cat.
You sail the old G-Cats a little different in good wind it does not need the dagger board with the full knife-edge of the keel you may loose a few degrees - maybe but on a reach, off wind, chop, waves and the rest of the points of sail it's fast and cuts though the water. No bouncing, slapping, and pounding. You sail speed not the rhumb line.
So with an updated model that will be competitive with current market boats it will make for great chat on the web.
Just a thought I wonder how many of the current State of the Art cats will be around still sailin' in 28 years like the G-Cat 5.7?
Description: Harem Haul 08
