Catsailor.com Big time repair advice sought
Posted By: davefarmer Big time repair advice sought - 08/11/09 05:05 AM
Epic day Saturday! 4 or 5 hours of drivin' the Stealth hard in 20 knots, two foot chop over a developing swell on Flathead Lake. I got this boat from Gary F early this spring, and I've been sailing it most every weekend for the last four months, and this was the first time I felt truly hooked up with it solo in big water. Can't seem to bury that lee bow! Hard to know whether it's the foiled rudders or the tall bows, but I sure like it!
Well, on a downwind run under spin, I hear this loud(and sickening)CRACK! I throttle back to investigate, and thirty seconds later another one just like it. I finally looked over the outside of the windward hull to see the daggerboard at a peculiar angle. Thought maybe the board snapped, and was concerned about saving the remains. But about then I noticed how low in the water the hull had become, so the focus quickly shifted to the shortest distance to shore. Which fortunately wasn't too far. Lucky, since I'd been as much as 3 or 4 miles offshore at times over the course of the afternoon. Hull was pretty full by the time I got to land.
Turns out the dagger tore aft thru the bottom of the boat, busting the daggerboard well too. So, gotta put it back together, hopefully with some input from you guys!
I'll post pics soon. The first question is where and how big of a hole to cut to allow me access to the daggerbd well. My thought is to carefully remove a 10" x 10" section of the inner wall of the hull, and flange it on the inside when the repair is done. Is that too big a hole? Can I make it bigger? Is this the least stressed section of hull to open up? Other spots to consider?
The daggerbd well actually broke quite cleanly, about midway down, and separated from the bottom of the hull cleanly as well. The upper section is intact and still attached to the deck. And all of the bottom of the hull, including the daggerbd exit profile is there still. So if I can get sufficient access, I think I can push/place all the bits back into place and sufficiently reinforce it all to ride another day.
So, thoughts on weights and types of cloth? I'm comfortable with West System products, and I have a vacuum pump if needed. Flight Risk has given me a fair amount of practice with these materials! I'm willing to spend $s on carbon if it's appropriate, but is S glass sufficient in this application? What weight cloth?
Anybody know the allen wrench size(mm?) of the bolts securing the beams to the hulls? I wanna buy the highest quality wrench I can find, 'cause this boat(2002) has seen a lot of salt water before coming to me, and I don't expect them to break free without a struggle. It doesn't appear that there's much chance of getting penetrant onto the threads. Any tips here?
I plan to run this by John Pierce(the builder), but all advice and encouragement is welcome. These's lots of season left and I'd like to float her again soon. Help me out boys! Thanks!
Dave
Posted By: TheManShed Re: Big time repair advice sought - 08/11/09 05:48 AM
Yes you are on the right track make a window to see inside then glue it back in place with a layer of glass over it. Pound around to make sure you don't cut into bulkheads. Make the cut on the inside face of the hull not as bad to fix if you aren't good at faring and blending or want to rush. Use west system or other epoxies and don't use auto body filler it will pop with time. Ask the builder for their advise. You may have to make several windows and make them big enought to work through.
Posted By: scooby_simon Re: Big time repair advice sought - 08/11/09 09:43 AM
Get hold of John P at Stealth for advice. THere may be a better way as the boat is clamshell construction.
http://www.stealthmarine.co.uk/I would phone first (yes a little expensive) and then follow up via email.
Might save a lot of hassle!
Posted By: DennisMe Re: Big time repair advice sought - 08/11/09 10:20 AM
You could use voipbuster or a comparable service to get free calls. Getting up early is the worst part! Works great for me! I am not associated with them, I just use them to call around the globe for free. (I own a hardware internet phone, but in a pinch I have used my laptop as a phone too.
Posted By: TEAMVMG Re: Big time repair advice sought - 08/11/09 11:42 AM
The manufacturer should always be your 1st point of call.
Posted By: mbounds Re: Big time repair advice sought - 08/11/09 12:42 PM
Skype. 2.4¢ / minute to the UK, incl VAT. Get a headset/microphone for your laptop and Bob's yer uncle.
Posted By: bvining Re: Big time repair advice sought - 08/11/09 02:17 PM
Dave,
Go ahead and cut her open, thats the hardest part. Once she's opened up you should be able to figure out how to fix it pretty easily. Making her watertight is pretty easy and straight forward, making her look like she hasnt had major surgery is harder. I would fix it and sail her now, and worry about pretty this winter.
When you close the hulls back up, that repair should mirror the original construction as closely as possible, so if the boat was made with S glass and vinylester, use that in the repair of the hull when you close it back up. Epoxy will stick to vinyl, but not the other way around, so its better in the long run to stick with what the builder used. Vinyl is more toxic so follow the directions and dont breathe it or smoke around it. Most boats these days are made with Vinyl, its cheaper than epoxy. You also dont want to create a hard spot in the hulls, or a spot that doesnt flex the same way the rest of the boat does, so use the same material as the rest of the hulls if you can.
If you add carbon to the daggerboard wells, I would add it to the whole part. Again, you dont want to create a hard spot, or a spot that doesnt flex like the rest of the part. So adding carbon just at the break might transfer the load to the spot on the daggerboard well with no carbon on it.
I'm curious why the daggerboard well broke in the middle, was the top of the board half way down the trunk? Or do you think you flexed the hulls top to bottom?
Bill
Posted By: scooby_simon Re: Big time repair advice sought - 08/11/09 03:21 PM
Dave,
Bill
Talk to John P first.
Posted By: davefarmer Re: Big time repair advice sought - 08/11/09 03:29 PM
Yeah Mike, that's what I had in mind for cutting the window. And I can see inside pretty well from below, so I know where the bulkheads are.
Bill, I will talk to John about vinylester vs epoxy for the repair. And I understand about wanting to avoid creating hard spots. I'm still curious about how the failure occurred, I didn't feel an impact, although there is some debris on the lake. There was no visible damage to the daggerbd itself, but it's pretty stout. It seems like the daggerbd may have dropped deep into the well, but I'm not sure how that would have happened. But as is visible in the 3rd pic, the upper half of the daggerbd well is still intact. Hit a big fish?
Thanks for the great response guys. Thoughts on cloth weights and number of layers? I'll keep you all posted as the repair progresses.
A few more shots:
1st one shows the remaining intact upper section of the dggrbd well,
viewed from below.
3rd one shows the lower section of the dggrbd well, it's just loose inside the hull now.
Dave
Posted By: bvining Re: Big time repair advice sought - 08/11/09 04:13 PM
Either 1 or more of the following happened:
1. The board slide down to far in the trunk (best case and most likely)
2. You ran over something (doesnt look like that happened)
3. The trunk/hull failed under the stress of sailing on a windy day (worst case)
It looks like the board slid down to far and the loads on the daggerboard increased and the trunk didnt have enough structure to hold the top of the board in the middle of the trunk, and it sheared off the trunk and then the second crack was the bottom part of the trunk tearing away from the hull.
Or you ran over something, which pulled the board aft, and the trunk sheared in the middle and then delaminated off the hull. I doubt this happened because the top of the trunk would most likely be damaged as well, and the board would be banged up too. Most of the time when you run over something the board takes most of the abuse, followed by the trailing edge of the trunk/hull. The impact usually james the trailing edge of the board backwards into the hull like a knife. It doesnt look like that happened.
I'm betting the board slide down to far, you didnt notice it and the loads from the board being to deep sheared off the bottom of the trunk.
If thats the case its good news, just glue it all back together and make sure the board cant fall below the deck in the trunk.
If the board didnt slide down into the trunk, and you didnt run over something, I would be really worried. If thats the case it means the trunk failed under normal sailing conditions. Thats a pretty serious design/build issue.
Posted By: Tony_F18 Re: Big time repair advice sought - 08/11/09 04:28 PM
How did it happen? Too much pressure on the board?
Do you have a pic of the board as well?
Good luck with the repairs.
Posted By: ThunderMuffin Re: Big time repair advice sought - 08/11/09 04:56 PM
Looks to me like its time for a new hull.
Good luck with that.
Posted By: HMurphey Re: Big time repair advice sought - 08/11/09 05:37 PM
Just a couple of lessons I've learned over the years ...
1) It's easier to work through a bigger hole then a too small hole
2) It's just as easy to repair a larger hole then a smaller hole cut for access.
3) Cut a access hole like you do when carving a "pumpkin" .... at a angle. I set my Bosch jig saw to a angle of 15degrees.
4) I mask off the area to be cut out w/ masking tape and draw lay-out lines to follow while cutting. This prevents chips and sloppy wiggly cuts. Use a new sharp blade!!!!
5) I drill two holes at opposite corners diagnally from each other just big enough for the jig saw's blade to fit into ...
6) Check w/ the builder BEFORE cutting and obtain any advise you can ...
From the pics' I think you will need two access holes ... one forward of the trunk and one aft as you need to be able to work on both sides of the trunk .....
Harry
Posted By: davefarmer Re: Big time repair advice sought - 08/11/09 07:19 PM
Yeah Bill, I'm also thinking the most likely scenario is that the top of the board somehow dropped below the deck level. The daggerbd well is very lightly constructed, just designed to keep water out of the hulls., I imagine. The deck and bottom of the hull were certainly designed to carry the loads. The board did slice aft maybe 5 or 6 inches, but I'm inclined to think that was collateral damage. When I first saw the board it was canted outboard, as would be expected for the windward hull if the board did indeed drop too far. I'll have to look closely at the boards, but I think the only thing preventing them from decending below deck level is the rope handles. Some sort of positive stop is certainly to be developed.
Thanks to all for the input. I've emailed John P, and I'll try the various Inet phone options suggested. Keep it coming, I won't start til I've heard from Stealth.
Dave
Posted By: ThunderMuffin Re: Big time repair advice sought - 08/11/09 07:54 PM
Vonage gets free calls to the UK.
Posted By: WindyHillF20 Re: Big time repair advice sought - 08/11/09 08:34 PM
I'm no expert on this but my Fox looked very similar when the hull blew up on it. On the Fox I was able to remove the top cap and get inside for the repair. I purchased a new topcap and dagger well and replaced them. My dagger had broken in the hull and sheared up at the break point. It would appear that the diagnosis of the board slipping into the well is the most likely cause of this damage if the board didn't snap. Does the Stealth have a topcap that could be removed instead of cutting a hole in the hull?
Posted By: bvining Re: Big time repair advice sought - 08/11/09 09:14 PM
Thats absolutely fix-able.
Dave,
How about making a collar for the daggerboard trunk. Can you get the bottom half out of the hull? If you can get the bottom half out, make a sleeve and then slide it back up onto the top half. Then glue the bottom part of the trunk back down to the hull.
The only tricky part is going to be getting some reinforcement on the inside of the bottom of the hull.
Think about using wire to pull everthing back into shape once its glued. And creating some internal backing structure that you can sandwich some glass in between the broken parts and the solid parts on the inside.
I'm trying to figure out if you could pull it all back together without cutting lots of big holes in the boat.
Bill
Posted By: TheManShed Re: Big time repair advice sought - 08/12/09 01:42 AM
I always like to think I hit something....even if I did not. From the repairs I've done a few holes big enough to put two hands in work well or space the holes one for each hand.
Big job repair work is harder then building a new boat just less work.
Posted By: Jake Re: Big time repair advice sought - 08/12/09 02:21 AM
I agree with Bill here. From the pictures, it looks like the board slid way down in the trunk. These trunks typically have very thin walls. Once it was down there, the board probably punched through the trunk and that was the first crack you heard. At that point, the board was probably not aligned well with the direction of travel and fighting the rest of the boat/rudders/boards with a ton of lift which caused the failure of the exterior/bottom of the hull - i.e., the second crack you heard.
5oz glass would be a good medium weight to work with. Epoxy is easy and very strong and bonds well with cured plastics. Vinylester resins approach the mechanical properties of epoxy but don't bond quite as well to cured plastics. polyester is very low cost, doesn't bond well, and has the least strong properties. If you intend to finish with gelcoat, use vinylester. you can gelcoat over epoxy but it's tricky to get a decent bond.
I'm not sure if you should cut the hole in the deck of the side...though I'm thinking the side may be the way to go. Mike showed a good trick to replace the 'window; you cut out by glueing plates of fiberglass to the inside of the hull - and that should work well. I have also use a similar technique by bonding popsickle sticks to the inside of the hull and clamping until they cure. Then glue the window back in place. Then using a dremel, I grind through the entire perimeter of the seam to the inside glass. I glass in a few layers of 5oz on the inside layer, then I fill with Ultimate Bondo (yes, bondo - I've had it work very well...just ask Tad...but use the ultimate version), sand a nice taper on the outside glass layer, and put a layer of glass again on the oustide...fair to finish with ultimate bondo, and gelcoat to finish.
With mike's fiberglass plates, if you get them all the way around the hole, you may be able to save the step of grinding to the interior layer of glass.
Posted By: gregP19 Re: Big time repair advice sought - 08/12/09 02:43 AM
I did a similar thing last summer with my new Blade. I hit a submerged rock with my daggerboard. It barely slowed me down even though I was on a broad reach in only 10 knots of breeze.It twisted in the trunk and caused the hull to fill with water. A good friend helped me repair the dammage. We ground off the deck plate to make it easier to get inside for the repair. There are a lot of guys on this forum with a lot more experience with fiberglass than me. My only suggestion is that you make sure you glass in the new daggerboard trunk correctly. A small error may make a big difference in the orientation of a high aspect daggerboard.
Posted By: davefarmer Re: Big time repair advice sought - 08/12/09 04:21 AM
From what I've seen it looks like the hulls are built of 2 sides, seamed top and bottom, no top cap.
Bill, sleeving the daggerbd trunk should work well. I do understand wanting to minimize cutting up good panels. But the bottom seems pretty broken up, needing a fair amount of reinforcement, which I'd prefer to do inside as much as possible. I'm pretty comfortable that I can do a strong job opening up the hull somewhere, I just want to do it in the least stressed area.
I do appreciate your and other's encouragement that it is indeed fixable.
Dave
Posted By: davefarmer Re: Big time repair advice sought - 08/12/09 04:50 AM
Jake,
Your analysis of how this came apart seems apt. Thanks for the reccomendation on glass weight. S glass preferred here? I use West stuff regularly and will probably use it for this repair. The boat's been painted, and I'll probably strip and repaint it this winter. Yeah, Mike's plates around the perimeter look good, along with angling the jig saw blade for the cut. The Ultimate Bondo tip is appreciated, fairing with West fairng fillers always leaves me with pinholes, that takes a lot of primer to fill.
Anyone reccomending carbon cloth for any part of this repair? Overkill? Hard spots?
Dave
Posted By: davefarmer Re: Big time repair advice sought - 08/12/09 05:05 AM
Gregg,
Good advice on preserving the orientation of the dggrbd well. Fortunately, if I can push all the bits of the bottom back into place I think I'll have the original positioning.
Dave
Posted By: scooby_simon Re: Big time repair advice sought - 08/12/09 08:27 AM
DO NOT DO ANYTHING UNTIL YOU TALK TO JP.
AS stated above, these boats are made in 2 parts and then bonded together along the keel/deck.
Talk to JP FIRST. He builds them, he's the expert!
Posted By: Jake Re: Big time repair advice sought - 08/12/09 08:21 PM
Jake,
Dave
As far as the glass type goes, I would see what the manufacturer used originally and try to match that. I use S-glass when possible. Carbon would simply be overkill and as someone else mentioned above, it would create some sharp stress points where the carbon would flex differently than the glass and you could end up with hairline cracks (or worse). I've got a couple of really good online sources for glass and resins with good service and great prices so if you don't have these already;
www.uscomposites.comwww.fiberglasssupply.com Posted By: davefarmer Re: Big time repair advice sought - 08/12/09 10:11 PM
Thanks Jake, I have been using Fiberglass Supply, and have been pleased with their prices and speedy shipping.
Dave
Posted By: davefarmer Re: Big time repair advice sought - 08/12/09 10:20 PM
Here's the correspondence I've been having with John:
The bolts take a 8mm allen key, you should be able to fit the repair panel into the hull via the centreboard slot, no need to cut a hole.
Thanks John, I follow you direction on using the 1" foam to repair and reinforce the bottom. Where do you suggest I cut into the hull to do this work?
Do you know offhand the size of the
Allen(hex) head bolts that secure the beams to the hulls?
Dave,
I would grind out the joint either side of the case and glue it back together with epoxy.
Then I would take out the top bit of daggerboard case.
I can't tell from the pictures if the flange that the daggerboard case is glued to is still there if it has gone then it needs rebuilding.
It looks like it is intact on one side and cut away on the other, so i would cut away that sideways rip to good material, then I would laminate up some 1 inch foam to make a sandwich, then make a panel 4 inches wide and 18 inches long, I would bond this into the inside of the cutaway side so that it covers the cutout and one half of the board slot, put a couple of screws into it and elasticate them to something to hold it in place whilst gluing.
I would then fill and fair this side before cutting out a new slot, I would then bond a new case in, fill fair and paint.
A new case will cost you £90 + carriage.
regards
John
Thanks John, here are the pics.
The daggrdbd well sheared pretty cleanly about midway down, the upper half is still attached to the deck, the lower half is intact, floating around inside the hull. Should be easy to sleeve at the break and re attach at the bottom. The bottom of the hull is all there, but pretty broken up, will need serious reinforcement.
Your advice is most welcome. Thanks for your time!
Dave
Dave
I can't see the pictures can you email me them, my pnone number is +44 1994 240822, call me this evening about 8.00pm uk time, don't cut anything yet!
john
Hey John,
Been having a ball with the Stealth, but I broke it Sat. Can you check out my post and pics on catsailor.com(bigtime repair advice sought), open forum, and shoot me you phone # and good times to call. I'd love to have your input before beginning the fix.
Thanks so much!
I can't say that I follow everything he's suggesting. I have some trouble envisioning doing the whole job from the upper and lower daggerbd openings. What do you guys think?
Dave
Posted By: ncik Re: Big time repair advice sought - 08/13/09 01:59 AM
My general advice...
Work in glass and epoxy only.
Cut out ALL the damaged stuff.
Repair the bottom first from inside and out. See photos of OneWorld ACC boat repair online. Use single skin construction around the bottom of the case.
Install daggerboard. Can be from old parts if they are undamaged. Ensure good alignment.
Replace deck.
Posted By: davefarmer Re: Big time repair advice sought - 08/16/09 04:09 AM
OK men, I've been contemplating all the valued advice rendered, and spent a fair amount of time peering thru the daggerbd openings, and here's what I'm thinking currently.
As I see it, I've got 3 areas to repair. Build a foam sandwich panel to clamp/screw/bog on the inside of the bottom of the hull to pull all the remaining pieces of the bottom back into plane, and reinforce(inside and out).
Bond and fillet into place the lower section of the daggerbd well. And wrap/sleeve the break in the middle of the daggerboard well.
John P and a couple of others are recommending doing all this without cutting an access hole on the inside of the hull. And I can envision how this might be done, but with my skills, I think I can do a better/stronger job with the better access provided by cutting a hole on the inside of the hull, flanging it on the inside and a 5 oz layer of S glass on the outside.
So unless you guys flame me overwhelmingly for this decision, I plan to proceeed. The materials just arrived, and I'm anxious to get her wet again soon. Thanks again to all who've offered advice!
Dave
Dave
Posted By: waynemarlow Re: Big time repair advice sought - 08/16/09 03:40 PM
Dave before you go hacking into the hull, from experiance of a similar repair on my Stealth ( hit a submerged fishing pot line with the dagger board whilst at top speed with the spinny up, nothing is going to survive except a kick back dagger board ) its far far far easier to fit a complete dagger board case and then do the local repair at the bottom from the outside.
Get a very sharp screw driver and slowly prise the dagger board case away from the hull by chiselling off 1 or 2 layers of the trunks glass layers starting from the middle section, you will quite quickly just delaminate the damaged trunk away from the hull leaving a very neat pefectly intact top section and 3/4 of the bottom section to simply slide in the new case and epoxy in. Then slide in and epoxy in a new repair section where the damage is on the bottom, fill with foam and then lay in a suitable chamfered in top layer.
If you need further help or questions then PM me.
JP is the master in this as he has done many similar repairs and has developed a repair method which is quickest and strongest, he will give good advice.
Posted By: davefarmer Re: Big time repair advice sought - 08/18/09 03:47 PM
At the risk of offending those of you who counselled against cutting into the hull, I've gone ahead and done it. Clean cut, should be easy to reassemble. It gave me great access to the badly torn up bottom. Ground off anything loose, pushed pieces back into place, laid down one layer of saturated 5 oz S glass, then bog w/ hi density filler, followed by a 4" x 18" piece of 1/2" foam that I'd previously vacuum bagged with the same glass to both sides of. Wax paper on the outside of the hull and atop the foam board, then a piece of 3/4" plywood outside of both, and used drywall screws to provide the clamping pressure to suck it all up. Worked very well, The bottom is almost back into it's orginal plane, and it's all very solid.
Tonight I'll cut the excess out of the daggerbd opening and bog the lower 1/2 of the well back into place, leaving the repair of the middle of the well for the following day.
Dave
Posted By: davefarmer Re: Big time repair advice sought - 09/01/09 12:09 AM
Ok, I'm into it about 2 weeks now. I've got 2 or 3 hrs after work before it gets dark, been pecking away at it for 4 days, then running off to Flathead for 3 days of sailing, and then return for work and more boat repair.
Once the bottom was back in plane and solid, I could clean up the daggerbd opening and slip the lower half of the dggrbd well into position, duct tape the opening, flip the hull upright and just pour some slightly thickened epoxy around the perimeter. Next night I wrapped the joint at the center of the well with a couple of layers of 3" fiberglass tape and compressed it with peel ply. Could of used a larger opening in the side of the hull, or two small ones strategically placed, but it worked ok. The walls of the well lined up pretty nicely, and I only had a little work to do from the inside of the well to make sure it was watertight.
Laid up some 2" wide strips, 3 layers of 5 oz. glass, to form the flanges to support the reattachement of the access panel. Screwed them into place, drilled the access panel for screws, and test fit it. Bogged it all up, laid the panel in the opening and sucked it all together with more drywall screws. Pulled the screws, filled the holes, sanded, and vacuum bagged a single layer of 5 oz S glass over the repair.
Thickened some more epoxy with West's finest fairing filler, laid it over the repair on the bottom, and last night by headlamp I took the newly constructed longboards to it. Looks great, will do the access panel tonight, hope to have her ready for water by the weekend.
Posted By: davefarmer Re: Big time repair advice sought - 09/01/09 12:11 AM
Posted By: davefarmer Re: Big time repair advice sought - 09/01/09 12:12 AM
one more, for now.
Posted By: TheManShed Re: Big time repair advice sought - 09/01/09 12:29 AM
Dave looks like you are making good progress.
Are you going to repair the dagger board and trunk?
Posted By: davefarmer Re: Big time repair advice sought - 09/01/09 03:41 AM
Mike,
The daggerbd was undamaged. The upper half of the well was still in place, I mated it up the undamaged lower half, and wrapped it in place with a few layers of glass. It's done, I'm just making it look pretty now.
Thanks for your input, I usually need a little encouragement to get started.
Dave
Posted By: Jake Re: Big time repair advice sought - 09/01/09 03:52 AM
And, uhhh... you were asking US for advice? Dude, you've got that under control!
Posted By: SurfCityRacing Re: Big time repair advice sought - 09/01/09 04:46 AM
I was thinking the same thing. Nice work.
Posted By: TheManShed Re: Big time repair advice sought - 09/01/09 07:07 AM
Dave
Keep up the good work I'll let you vacation in Florida this winter at the man shed and work on the TMS-20
Jake - Jeremy must have been our advise!
