Posted By: Twister Dart 18 specs - 07/28/10 03:42 PM
Anyone with a Dart 18 know the distance between the center point of the holes for the tiller arm pins on the rudder crossbar? Trying to make a new one.
Thanks
Posted By: dartfast Re: Dart 18 specs - 07/28/10 11:53 PM
Print DR 250 only states "1950 Max" cross barlength of rod and holes to fit DR 237 pins "to fit assembly". Mine measures bar at 72 5/8 inches with hole centers at 69 5/8 inches.
To firm and minor adjust Stu made two 1.75" long wood dowel inserts with through holes for the pins and slides the dowels inside the cross bar ends and uses a screw to make the dowles firm. Reduces play and wear.
Terry
Posted By: HMurphey Re: Dart 18 specs - 07/29/10 01:16 AM
Hi,
Find Mark Schnieder ..... send him a PM ....
Oh, Mark's origonal sailing nickname .... "Dartman"
And he still has his .....
Harry
Posted By: Twister Re: Dart 18 specs - 07/29/10 12:40 PM
Thanks
Thats a great idea.
Posted By: TEAMVMG Re: Dart 18 specs - 07/29/10 04:23 PM
Had a wander around the boat park today, there is usually at least one slacker on a Dart 18 that can't be bothered to take his rudders off. But, wouldn't you know it, no rudders to be seen!
no use - sorry!
Posted By: Twister Re: Dart 18 specs - 09/08/10 04:34 PM
Are the backing plates and hardware for the chainplates and bridle attachment points glassed in place from the inside.
I am wondering since I am planning on refinishing the hulls and would like to remove these fittings unless they will be difficult to replace.
Posted By: Smiths_Cat Re: Dart 18 specs - 09/08/10 07:21 PM
If I remember right, the baking of chainplates on bridle attachment are not glassed. I had serial number 6913.
Cheers,
Klaus
Posted By: Twister Re: Dart 18 specs - 09/08/10 07:29 PM
Is there anything holding the backing plate and hardware in place, like epoxy? There are no inspection port access, so I dont want to have any hardware dislodge when I remove them.
Posted By: scooby_simon Re: Dart 18 specs - 09/08/10 11:11 PM
DO NOT undo any of the fittings unless you are planning to take the decks of the boat off too. They are NOT epoxied in.
Posted By: Twister Re: Dart 18 specs - 09/09/10 01:33 PM
That's what I thought. Just wanted to confirm. Thanks.
