Posted By: ROLAND HAILE NACRA 5.2 JIB SAIL AREA AND MAIN SAIL AREA - 09/08/10 10:34 PM
I'd like to know the jib sail area and main sail area of the NACRA 5.2. I know the total area of both is 220 sq ft, but would like to know the individual area of the main sail and the jib. Also would like to buy a used/new 5.2 mast in the Dallas Ft Worth area. Thank you.
Posted By: erice Re: NACRA 5.2 JIB SAIL AREA AND MAIN SAIL AREA - 09/09/10 05:56 AM
these details, and most other specs on most available cats, can be found on the huge texel spreadsheet downloadable from the texel ratings website
"think it's complete list, all details" on this page
http://www.knwv.nl/zeilen/Content.aspx?sid=2&cid=129&mid=&mnu=2415.2 mainsail 15.5m2
5.2 jib 4.12m2
Posted By: DennisMe Re: NACRA 5.2 JIB SAIL AREA AND MAIN SAIL AREA - 09/09/10 07:57 AM
Are you building a boat or something? If so, what type?
Posted By: ROLAND HAILE Re: NACRA 5.2 JIB SAIL AREA AND MAIN SAIL AREA - 09/10/10 12:55 AM
Thank you ERICE for the link. I did not find the NACRA 5.2 there. Found 18 square,5.5sl, 5.0 etc but no 5.2. Thank anyway because it's a good link. My boat is TRRC 1802M80K and I've had it since the early 90's but its spent more time in storage than on the lake. Past boats were Hobie 14 and NACRA 18square (I really miss that boat {the 18 square not the Hobie 14}. Windsurfing and work got in the way in the '90s.
DENNISMe.....no, not building, just have the wants for a NEW NACRA and wanted to compare the 5.2 with newer NACRA. I did try to build a design by JohnLindal early 90's using the stich and glue and marine plywood method. Hulls got built but left behind when I was relocated from where I lived. Shoulda kept the boat plans. I'm in the mood to try again. Built rowing shells with stich and glue from CLCC (Oxford Shell) and Wayland Marine (Merry shell).
Posted By: jcasto1 Re: NACRA 5.2 JIB SAIL AREA AND MAIN SAIL AREA - 09/10/10 02:27 AM
I'm pretty sure there's a spare 5.2 mast in Austin.
contact craig tapley
craigt
csr.utexas.edu
Posted By: ROLAND HAILE Re: NACRA 5.2 JIB SAIL AREA AND MAIN SAIL AREA - 09/10/10 03:33 AM
jcasto1........I've no idea how you knew I needed a 5.2 mast. The one I have is servicable but has a dent and corrosion from yrs of storage at Jim's Boat Barn in Corpus Christi Tx. The damage is my fault from the way I stored it. Disimilar metals touching each other type thing. Thank you.
Posted By: DennisMe Re: NACRA 5.2 JIB SAIL AREA AND MAIN SAIL AREA - 09/10/10 06:27 AM
Roland, I can keep up with most newer Nacras on my 5.2, but only with the badly sailed F18s though... Probably worth refitting the 5.2. One just sold near me for only 130 USD! I was just too late to snap that up ....
Keep us posted if you do build at some time in the future, there are lots of builders here and interested folks like myself.
Dennis.
Posted By: erice Re: NACRA 5.2 JIB SAIL AREA AND MAIN SAIL AREA - 09/10/10 10:31 AM
have a look again on line 180
nacra 5.2 2 111 105 5.2 5.18 155 15.03 7.80 4.32 4.66 2.28 2.43 2.54 13.32 1.43 3.46 19.93 305 311 3.15 110 105 7.8 0.00 7.8 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 4.96 1.74 4.32 4.96 0.00 0.00 0.00 4.32 0.32 1.23 0.12 1.4 2.08 2.28 2.26 13.81 0.0 2.35 2 730 685 0.94 1.0071
Posted By: ROLAND HAILE Re: NACRA 5.2 JIB SAIL AREA AND MAIN SAIL AREA - 09/10/10 01:43 PM
ERICE.............................Thanks again. I had stopped looking around lines 30-42 and expected it to be in that area. Wrong. Line 180 it is.
I'll probably keep the 5.2. Solid beams and hulls and no leakage. I installed the newer style uphaul *hook* at the top of the mast this week. The original had the *stopper* swagged on the uphaul wire and the Vee for it to go into. *Stopper* is the wrong term but I can't remember the proper term right now.
Posted By: Dan Berger Re: NACRA 5.2 JIB SAIL AREA AND MAIN SAIL AREA - 09/10/10 02:17 PM
I'm in Norfolk, VA and I have a spare 5.2 mast, two mains and a nice jib.
Danberger
mindspring.com
Posted By: ROLAND HAILE Re: NACRA 5.2 JIB SAIL AREA AND MAIN SAIL AREA - 09/10/10 02:22 PM
JASTO1......I obviously forgot I mentioned the mast in the first post I made. Ooooops.
Posted By: ROLAND HAILE Re: NACRA 5.2 JIB SAIL AREA AND MAIN SAIL AREA - 09/10/10 02:25 PM
I might have a interest in the jib. I believe it would cost tooooo much to ship a mast that distance. I already have a spare main. Zipper any good in the jib? Never hurt to ask.
