Plugs/molds
Posted By: BadLatitude1337
Plugs/molds - 02/10/12 07:20 PM
Ok guys and girls, I’m about to start building sum hull plugs/molds. Anyone with any info that can save me sum hardship that would be great. So if you have any info/picks that could help me I would appreciate it very much
Posted By: Mark Schneider
Re: Plugs/molds - 02/10/12 07:29 PM
Start here
http://www.usaca.info/index.php?option=com_content&view=article&id=476:new-a-cat-design-racer-x-is-back&catid=67:icon&Itemid=122
Tony's A Cat
Re: Plugs/molds - 02/10/12 07:32 PM
awesome that's a good start!!!! thx
Posted By: Jake
You might as well asked for a manual on world peace! It's a tricky, artful process to make molds on this scale on a normal person budget. I've made a few on a considerably smaller scale and you can see some of it here (you have to read from the bottom up since the posts are chronological).
http://www.teamseacats.com/category/other-projects/one-meter/page/11/
If I were doing it and intending to build only one boat, I would consider using a strip foam planking method like Ian did on his LR series of a-cats. The process would be the same for you - only the number of layers of fiber would need to increase and you probably need a little more structure in the hulls (including a sub-deck to help with spinnaker and forestay loads). I can't help with the exact lamination schedule but perhaps the Man Shed can shed some light relative to the trimaran he's building.
http://lindahlcompositedesign.weebly.com/lr4-build.html
http://www.themanshed.com/tms-20-trimaran.html
Posted By: TEAMVMG
Re: Plugs/molds - 02/10/12 08:04 PM
Plugs and molds....are you starting production as opposed to a one off?
Re: Plugs/molds - 02/11/12 03:39 AM
we are thinking production but are not even close yet.
Posted By: catandahalf
Re: Plugs/molds - 02/11/12 03:49 AM
Hobie, Micky, and Phil started with two surfboard blanks. Hobie Alter shaped the original Hobie 14 by eye and simple tools.
CAD programs suffice for now smile
Re: Plugs/molds - 02/11/12 04:14 AM
haha I hear u smile
Posted By: pitchpoledave
Re: Plugs/molds - 02/11/12 12:55 PM
ok who did the design? Do you have renderings?
Posted By: F-18 5150
Re: Plugs/molds - 02/11/12 04:21 PM
What you making?
Re: Plugs/molds - 02/11/12 06:56 PM
2 cats a f16 and also a open20
Posted By: TEAMVMG
Re: Plugs/molds - 02/11/12 07:06 PM
So you want a couple of prototypes before tooling up for a production
Thermoform foam [Corecell/airex] in female formers, skin the inside, fit bulkheads, pull from formers, join the halves and then laminate the outside. Fill, fair and paint
Sail it, then if you are happy with it - you have a plug for production molds.
Re: Plugs/molds - 02/11/12 07:15 PM
yea that's about what i was planing on. Guess im heading in the right direction.
Re: Plugs/molds - 02/11/12 09:54 PM
Why not an F-18 too?
Posted By: Karl_Brogger
Re: Plugs/molds - 02/11/12 10:12 PM
dead class......
Just kidding, wanted to jerk Dave's chain. laugh
Posted By: daniel_t
Re: Plugs/molds - 02/11/12 10:24 PM
He's probably worried that he wont be able to make the boat heavy enough.
Posted By: pgp
Re: Plugs/molds - 02/11/12 10:27 PM
Worked with a guy we called "spoon", for good reason.
Re: Plugs/molds - 02/22/12 06:10 PM
who has a good lead to foam core strips?
Posted By: Jake
Re: Plugs/molds - 02/22/12 06:47 PM
Buy sheets, rip the strips on the table saw, and use a router table to machine a radiused bull-nose on one edge and matching relief in the other side. This way they will pivot inside each other to reduce the amount of fairing you need to do and will increase the glued surface area.
Posted By: TEAMVMG
Re: Plugs/molds - 02/22/12 06:58 PM
anyone building a Farrier trimaran - start at f-boat.com
Re: Plugs/molds - 02/22/12 10:05 PM
How squishy is the foam? I'm just thinking about ways to do it, and if you set it up in a shaper you could have a powerfeed and keep things consistent for width and finish of the cut.
Posted By: Jake
Re: Plugs/molds - 02/23/12 01:00 AM
it's fairly rigid. If you were to hold a 1.5" x 1.5" x 8 foot from one end, it probably wouldn't flex 2 inches on the extreme end. It machines like butter.
Posted By: orphan
Re: Plugs/molds - 02/23/12 01:47 PM
Check this thread lot of good stuff.
http://www.catsailor.com/forums/ubbthreads.php?ubb=showflat&Number=217766&page=1
Posted By: carlbohannon
Re: Plugs/molds - 02/23/12 03:50 PM
A tip for one off customs. Have paper templates of what you want the core to look like between the female forms so you can make sure what you just built, matches what you designed(you may need templates for the form too, depending on what technique you use). Having the ability to make additional templates at 2AM, when things start looking odd and you need to check places you don't have templates for, helps. Some CAD programs can put alignment marks on 8.5x11 paper so you can tape them together to make big drawings.
The issue is, core strips don't usually bend the way the CAD curve-fit "bends". Sometimes the strips don't lay up perfectly on a form. Curve-fits have assumptions that physically translates into compression or tension on the strips between female forms. If you create a curve-fit that assumes no tension or compression on the strip at the forms, friction on the real strip produces compression and tension. You can minimize this by using a curve-fit that approximates your strips and by making a CAD drawing of a strip built core but there are a lot of variables in assembly. If you make a CAD drawing of the strips, the CAD can give you measurements from one end of the core strip, to where the female forms touch that strip. You can measure and mark the strip so you can check to see the strip lays in the female forms they way it should. ALL of this is a pain in the butt but it beats discovering your hulls are different and having to build a third one, to match one of the first 2.
For boats built from good plans, this all been sorted out.
I don't want to start a discussion on merits of materials but you can use cedar instead of foam. Depending on where you are, there can be a huge price difference between foam and cedar and you will need less material in the laminate. Cut the strips out of 1-3" thick planks.
Wood battens, were used for "curve fits" once a upon a time. I read a article last year about simulating wood batten curves with CAD curve-fits. This went a long way toward explaining why I had such a bi**h of a time getting the real world to match what I created on a computer.
Re: Plugs/molds - 02/23/12 05:24 PM
I like it im getting lots of great info and I appreciate all of it, you guys rock
Posted By: LCD
Re: Plugs/molds - 02/24/12 02:53 PM
Assume 64 sq. ft. area for an A-Class cat hull.
5.3#/cu.ft.foam (3/8" thick) equals 10.6 lb. and cost for material and labor cutting strips is $370.
21.2#/cu.ft. white cedar (1/4" thick) equals 28.26 lb. and cost is $512.
Re: Plugs/molds - 02/25/12 05:23 PM
What would an an appropriate amount if Nomex cost?
Posted By: TEAMVMG
Re: Plugs/molds - 02/25/12 08:30 PM
Nomex needs to go into a mold
Re: Plugs/molds - 02/27/12 02:54 PM
1/4" (8mm)white ceder with 2 oz glass on each side and some reinforcement on the inside would make a very strong hull.
8mm of white ceder is roughly/sorta/depending the equivalent of 2mm bidirectional carbon
I would probably use 3mm or 2mm as a core
Re: Plugs/molds - 02/27/12 03:39 PM
I think im going with Core-cell, for the prototype boat. will make changes in production boats if need be.
Posted By: TEAMVMG
Re: Plugs/molds - 02/27/12 03:59 PM
Yes, cos no-one can afford to use it in production boats! Good choice for your prototype tho'. Don't bother with routing long strips, do vertical wider strips and glue them with PU adhesive [Gorilla grip]
Posted By: Anonymous
Re: Plugs/molds - 02/27/12 09:19 PM
the best thing about corecell with regards to this project is how well it takes to heat forming. Either buy yourself an old domestic oven from Craig's list or make a heating box ( for small projects these are often made with timber, fibreglass insulation and a couple of heat guns) and you will able to shape wide transverse runs of foam and do minimum fairing or gluing.
Corecell is probably the best foam on the market, however, it is banned in the F18 class, not worthwhile on a boat built with a chopper gun or inferior to nomex for high end builds. As a result we see very little of it in beach cat land.
Posted By: Rolf_Nilsen
Re: Plugs/molds - 02/28/12 04:20 PM
With quite a few hundred hours invested in a strip-plank project I feel confident when advicing: Stay away from the devils building method if you want a fast build wink
Posted By: samc99us
Re: Plugs/molds - 02/29/12 04:46 PM
Jake, which foam? There are sooo many different types of foam available it can be overwhelming...right now I have 7 different types of extruded polystyrene in my shop, along with Rohacell and Nomex for use as cores in molds. All the polystyrenes act differently and most wouldn't be suitable for a boat building project but they exist!
Posted By: TheManShed
Re: Plugs/molds - 03/02/12 07:54 PM
Quick word on foam. There are several types I used 3/8 Divinycell H80 and H60 on my project a bit cheaper than core-cell and does not need to be heated. I bought full sheets and ripped them to strips then used a router and cut it with a “canoe bit” which has a combo bead and cove blade. There are two main thoughts on foam stripping horizontal or vertical, the farrier guys like the vertical method. It looks like a good method - but did not work with my design. I used the older horizontal method. Gorilla glue worked good to glue the strips together and fares out well.
Posted By: pgp
Re: Plugs/molds - 03/02/12 07:56 PM
Am I reading you right? You can sand gorilla glue to shape?
Re: Plugs/molds - 03/02/12 08:00 PM
Pete when I glued the strips with epoxy it did not sand at the same rate as the foam and wanted to dish between the glue and foam.
With Gorilla the dried glue it is about the same density as the foam and sands out fare. Rememeber this is a thin line of glue that may come out between the stips.
Posted By: pgp
Re: Plugs/molds - 03/02/12 08:04 PM
Okay, thanks.
Re: Plugs/molds - 03/02/12 08:12 PM
Here is picture of a sanded hull with a little help.
Posted By: Jake
Re: Plugs/molds - 03/02/12 08:47 PM
Also - if you wet the surfaces before you apply the gorilla glue, the glue will foam as it cures. More water makes it foam more.
Re: Plugs/molds - 03/03/12 09:33 PM
BadLat
From my experience there are two ways to do a foam lay-up. For a one-off you can lay the foam on the inside of the forms or on the outside of the forms.
On the inside of the form method it allows you to do your foam lay-up and first glass them remove the hull half from the form and easy access to the outside of the hull. It takes more care in the alignment of the forms on the strong back as it is harder to visualize the same and form of the hull when looking inside of the forms. When planked out with foam you can see the inside of the hull but again you cannot see the outside of the hull and look down the hull for fairness. This method I believe is easier for the one off boat. It easy to attach the foam and for the most part it stays in place although it wants to curl during curing, I found out the hard way.
Foam on the outside of the forms is much more difficult to attach to the form as you working under and inside the form on a narrow hull. Also you must deduct the finished hull dimension from the form size or you will be adding to size of the hull. If this is done during the lofting it will be easier but often the plans are drawn to the finished size - Just something to think about in the early planning stage.
Now if I were just building a plug I think I would just attach the foam to outside of the forms as it much easier to see the fairness as you go along. You can run the screws into the foam and fare over them. The only thing is that you are putting all your eggs in one basket in hopes that not going through a prototype boat your design will be a good one. You are putting time and money in the plug and mold for a untested boat.
Either way good luck with your project it is a lot of work and fun if you like that sort of thing. I yeah I almost forgot to mention it takes up most of your free time also. Bad lat if you would like some more information about what I have learned to do and not do feel free to contact me. I’ve learned much during my endeavourer.
The Man Shed
Re: Plugs/molds - 03/03/12 09:43 PM
mike thx for the great info. i will save your email as im sure sumthing will come up lol
Re: Plugs/molds - 03/03/12 10:02 PM
Feel free to contact me. If you go though my website it goes though a spam filter first I check it every so often.....damn spammers.
© 2021 Catsailor.com Forums
