Catsailor.com 7:1 to 8:1 conversion
Posted By: Andinista 7:1 to 8:1 conversion - 02/16/12 01:38 PM
I'm thinking to modify my mainsheet system for 8:1. Anybody tried this option?
- Invert upper and lower triple blocks
- Add hihger diameter block with becket
- Connecting hardware must keep all blocks parallel
I have enough room for the additional block.
Posted By: HMurphey Re: 7:1 to 8:1 conversion - 02/16/12 04:25 PM
Hi,
Please look at Annapolis Performance Sailing ... catolog 2011/pg56 ....
You will find in the upper left corner a pic of a Harkin "Quad Block/ part#H2631 that you can use as your "Boom Block". Combine that w/ a Harkin part# H2687 (pg57) for your "Bottom Block" and you will have a 8X1 Mainsheet Stack.
Now, I like Lewmar Blocks and have used them for my 7X1 Mainsheet Stack .... but I do have a 8X1 Mainsheet Stack using the Harkin Quad Block since I have been unable to locate a Lewmar Quad Block .... I set the 8X1 Mainsheet Stack up for use on my P19MX to control the mainsail leech ... but ... I found out that there is a big difference between a 7X1 vs 8X1 in the amount/length of mainsheet line that you need to take-in or ease-out. For me it is generally too much ... and I went back to just using the 7X1 systems ...
Harry
H18Mag/P19MX
Posted By: srm Re: 7:1 to 8:1 conversion - 02/16/12 05:12 PM
Interesting idea, but you better verify the load rating on the single upper block. I'd be concerned about pulling the becket off the upper block where you're attaching the triple to the underside of it. The becket is generally intended as a tie-off point and would typically only see the load from one "throw" of the line. In the configuration you've drawn, the becket will see seven times that load.
sm
sm
Posted By: Opher Re: 7:1 to 8:1 conversion - 02/16/12 05:54 PM
I would add a block on the inside, probably a 40mm Harken, on the top becket where you currently end the line. Then add a tie point by creating a loop of 3mm dyneema through the center of the bottom 3 blocks, and attach the end of the line there. Working inside keeps all the loads down, except for the external block fittings, which are designed for the high loads.
Also, you should reeve the line with the top and bottom blocks perpendicular to each other, not parallel. That makes it easier to avoid crossings
Posted By: Andinista Re: 7:1 to 8:1 conversion - 02/16/12 06:08 PM
I like your idea, it's also easy to test with an existing block. Regarding paralell blocks, I've found that there's more friction with the blocks perpendicular. Crossings is not such a big issue but I never thought that was the reason for using them perpendicular, I'll be testing that too.
Regarding load, what do you think is a reasonable value of total load? (or single segment load)?
Posted By: Opher Re: 7:1 to 8:1 conversion - 02/16/12 06:17 PM
Loads on the inside are exactly the strength you pull on the line for the line end, and double your pull for the internal block - unless you are a gorilla then several tens kg max. Loads on the outside are 7 - 8 times your pull.
That's why if you mount the block externally it see's much greater loads and will be prone to break
Posted By: Andinista Re: 7:1 to 8:1 conversion - 02/16/12 06:18 PM
Right. The question was how much do you think we normally pull
Posted By: Opher Re: 7:1 to 8:1 conversion - 02/16/12 06:23 PM
Several ten kilograms
Posted By: Jake Re: 7:1 to 8:1 conversion - 02/16/12 06:30 PM
shoot...you should try the 10:1 on F18s.
Posted By: Jake Re: 7:1 to 8:1 conversion - 02/16/12 06:32 PM
I presume you mean 30 kg or so? I bet it's not quite that much - probably more like 20kg...I bet we surprise ourselves with how low it really is. I've been wanting to do a bench test to see what I pull single and double handed - I would be very interested in some tested information on that.
Posted By: Opher Re: 7:1 to 8:1 conversion - 02/16/12 06:41 PM
I think you're probably right, and Ive been wondering the same. My guess is that the final schlepp out on the wire, with both legs and upper body, is aaround 30
Posted By: F-18 5150 Re: 7:1 to 8:1 conversion - 02/16/12 07:17 PM
or the new 12:1 on the Wildcat.
Posted By: HMurphey Re: 7:1 to 8:1 conversion - 02/16/12 07:24 PM
Hi,
Are those F18 Mainsheet Stacks (10X1 or 12X1) straight singular ratios ... or ... are they a type of "cascade" system like those developed by Mr Greg Scase for Tornadoes and marketed by Harkin that have two ratios such as 6X1/12X1 that effectively mean they have a "macro" and "micro" modes.
Harry
Posted By: Hullflyer1 Re: 7:1 to 8:1 conversion - 02/16/12 07:27 PM
There should be enough room to add an 14-16 inch pigtail between the boom and the upper blocks, that will allow you to shorten the mainsheet by at least 8-10 feet when using an 8-1 you can do the same thing with a 7-1.
Hi,
Harry
H18Mag/P19MX
Posted By: waterbug_wpb Re: 7:1 to 8:1 conversion - 02/16/12 07:33 PM
I I've been wanting to do a bench test to see what I pull single and double handed - I would be very interested in some tested information on that.
Well, get you a market (hanging) scale, tie it to the sheet and pull away. Some have a max indicator needle, too. What's that... about $12 USD total?
But being the jakemister you are, you've probably spliced a load sensor into your mainsheet and have it wireless transmit to your wrist computer
Posted By: samc99us Re: 7:1 to 8:1 conversion - 02/16/12 08:31 PM
I don't suggest modifying an existing block system. "Upgraded" an 8:1 system to a 9:1, but the existing block hardware was not beefy enough to handle the loads, found out the hard way 3 days into Tybee.
Posted By: Andinista Re: 7:1 to 8:1 conversion - 02/16/12 08:45 PM
sm
sm
Checking the numbers, it seems that the limit may be on the sheave rather than the becket:
Safe working load for H002, H004 and H076 is 227, 454 and 544 kgs respectively.
454 is 2 times 227 but 544 is not 3 times 227, so I guess the limit is on the sheave for the first two and on the structure for the third one. Probably too much guessing on my analysis, but 227 kg for the single block seems close enough to the 30 kg pull anyway. But on the other hand, not close enough to 1100 kg breaking load, so I would probably try it anyway... Plus, much of the pull tension is lost in friction, so effective loads are actually a lower.
Posted By: Andinista Re: 7:1 to 8:1 conversion - 02/16/12 08:47 PM
Oops... my previous message was entered before reading samc99us's, who is contradicting me with solid proof.......
Posted By: Anonymous
Re: 7:1 to 8:1 conversion - 02/16/12 08:55 PM
On a N20 or F18?
Posted By: samc99us Re: 7:1 to 8:1 conversion - 02/16/12 09:14 PM
Hi,
Harry
10:1 system I've used on the N20 was just like this:
http://www.harken.com/OneDesign/tornado.phpI haven't seen a cascading setup (per here:
http://www.catsailor.com/forums/ubbthreads.php?ubb=showflat&Number=185848) on an F18 but somebody's probably tried it.
Posted By: samc99us Re: 7:1 to 8:1 conversion - 02/16/12 09:15 PM
N20, but I suspect the leech loads are pretty similar these days on the F18 high aspect ratio mains.
Posted By: Walls619 Re: 7:1 to 8:1 conversion - 02/18/12 04:11 PM
Any diagram, for harken quad stack main block?
Posted By: F-18 5150 Re: 7:1 to 8:1 conversion - 02/18/12 07:23 PM
I have the 5 block on top with a triple and a double on a becket on bottom . Using a tapered main it works great for me.
Posted By: Walls619 Re: 7:1 to 8:1 conversion - 02/20/12 05:23 AM
line route for 8-1 main block
Re: 7:1 to 8:1 conversion - 02/20/12 02:16 PM
Posted By: Timbo Re: 7:1 to 8:1 conversion - 02/20/12 02:58 PM
Nice! Thanks for that picture, worth a thousand words. Now I've got to pull mine apart and re-do it right!
Re: 7:1 to 8:1 conversion - 02/20/12 03:32 PM
Y/w
Posted By: Walls619 Re: 7:1 to 8:1 conversion - 02/21/12 01:39 AM
thanks ,now on to nacra rudder system non pivmatic..pull down line to cam cleat on rear beam continuous line,,schock cord up through rudder control arm?Sound right any decent picture will help possable upgrade;;
Posted By: HMurphey Re: 7:1 to 8:1 conversion - 02/21/12 04:56 PM
Not so fast ....
Study that diagram closely on how to weave/thread the mainsheet line .... now, if you rotate the single block attached to the camcleat 90*, so that it is orientated ACROSS the axis of the triple and quad blocks, there is a way to weave/thread the mainsheat line w/ no crosses .... so it will operate cleanly ...
Can you fiqure it out??? (Hint: At one point, you will need to thread the mainsheat from the extreme outboard sheave on the Quad Block, down and through the Single Block, and then back up to the other outboard sheave on the Quad Block ...)
Try it ... it works really well, but you need to actually see it/play with-it ... to apprieciate how it works
Note: It works best if the Single Block is the same size sheave as the Triple and Quad Block's sheaves ....
Harry
H18Mag/P19MX
Posted By: Andinista Re: 7:1 to 8:1 conversion - 02/21/12 05:33 PM
This statement suggests that an increase in purchase means necessarily an increase in max load applied. Is that really true? Don't we want to actually lower the pull to acheive similar results? Therefore more pulleys should mean lower load and not higher, except at the connections in both ends, where the total load is applied.
That's assuming that the goal is to distribute the load rather than apply more total tension. Maybe I'm wrong there.. Still, we are talking about a 10 to 15% increase in purchase, which comes with a decrease in overall efficiency because of the higher friction, therefore, the total tension is increeased in less than that. Would that be enough of an increment to break the blocks? If not rearranging blocks too differently (like the single block suggested in the first post) I think it shoudn't
Re: 7:1 to 8:1 conversion - 02/21/12 05:49 PM
I agree with Andinista and have recently added another block to my 8:1(even after reading this thread).
Sure i can now probably apply more force, but i don't want to. my goal was to need less strength to sheet to the same amount (i have shoulder issues).
Also i have a hard time believing the sheeting forces are the same on an f18 and n20... but i am not an engineer
Posted By: Andinista Re: 7:1 to 8:1 conversion - 02/21/12 06:35 PM
Did you notice the difference?
(I'm feeling guilty about spending that money in blocks rather than with my wife.. I need some reassurance..)
Posted By: pgp Re: 7:1 to 8:1 conversion - 02/21/12 06:39 PM
I haven't actually tried mine but went to the 8:1 in the belief that I'm undersheeting while sailing alone.
I've little doubt the money is well spent.
Posted By: Andinista Re: 7:1 to 8:1 conversion - 02/21/12 06:44 PM
I ordered the quad blocks by the way. The single block idea was probably good but was about half the price, not cheap enough for a probably compromised solution. (That's how I convinced myself anyway..)
Posted By: pgp Re: 7:1 to 8:1 conversion - 02/21/12 06:47 PM
I did the same, for much the same reason. A lot of F16s are using the system and I wanted to keep the boat as current as reasonably possible.
Posted By: Andinista Re: 7:1 to 8:1 conversion - 02/21/12 07:00 PM
Here is how I intend to route the line, it seems to be the option with less crossings and with a more even distribution of the line segments speeds:
What do you think?
Posted By: pgp Re: 7:1 to 8:1 conversion - 02/21/12 07:10 PM
http://www.catsailor.com/forums/ubbthreads.php?ubb=showflat&Number=244434&page=3I ran mine like the other example, though I came up with it through trial and error.
I could not make fine adjustments with 7:1, to sheet hard I'd actually lift my butt off the hull, that resulted in steering all over the place.
Posted By: TEAMVMG Re: 7:1 to 8:1 conversion - 02/21/12 07:20 PM
What do you think?
Whoa! cats cradle! The top block needs to be at 90 degrees to the triple
Re: 7:1 to 8:1 conversion - 02/21/12 07:21 PM
i can't say i felt much difference but my shoulders are less sore than usual.
Posted By: ccat Re: 7:1 to 8:1 conversion - 02/21/12 10:00 PM
HM is right.
There is a much better way to reeve than the Harken diagram.
PM for a pic
Posted By: Jake Re: 7:1 to 8:1 conversion - 02/22/12 02:13 AM
Nacra 20 has a softer, bendier, mast so you have to be careful not to oversheet more so than the F18...but, we sheet them similarly.
Posted By: Team_Cat_Fever Re: 7:1 to 8:1 conversion - 02/22/12 04:21 AM
If you added a point of purchase you decreased the load on the hardware (blocks)itself. I think you were just using some old busted-butt, brokedown, shite. i've used an 8:1 modded to 9:1 since it was allowed by class rules ,at least 4 Tybees worth.
Posted By: waterbug_wpb Re: 7:1 to 8:1 conversion - 02/23/12 03:26 PM
? I thought it was easier to oversheet Rob's wildcat than Forrest's N20 - both in 18+ conditions... maybe I was just seeing things? Or are you referring to the N20 with aluminum mast? I never considered that carbon mast particularly "bendy"???
Posted By: Mlcreek Re: 7:1 to 8:1 conversion - 02/23/12 03:38 PM
Jake,
Can you oversheet the N20 to the point of breaking the mast? Using the OEM 8:1.
Forrest
Posted By: ksurfer2 Re: 7:1 to 8:1 conversion - 02/23/12 04:00 PM
Jake,
Forrest
Not with a wuss like Stank pulling strings you can't!
Posted By: waterbug_wpb Re: 7:1 to 8:1 conversion - 02/23/12 04:10 PM
+1 on that Karl!
I don't recall anyone ever breaking a mast from oversheeting a main (on any boat except maybe an H16 before they started raking the masts back). Even with the 10:1 setups?
Only N20 masts I've heard that broke were stuffing into a wave with spinnaker up (Mike H), letting the mainsheet go with the spin up, and getting tossed around at Jensen Beach during the T500. Maybe there are more out there?
Posted By: Mlcreek Re: 7:1 to 8:1 conversion - 02/23/12 05:24 PM
Karl,
Don't let him fool you....when others ain't looking, he begs me to pull them. Plus, I'm expected to keep the waves off of him.....was that skipper or slave driver?
Posted By: Jake Re: 7:1 to 8:1 conversion - 02/23/12 05:53 PM
Jake,
Forrest
I doubt it. In big air upuwind and sheeted properly, the I20 mast looks like a wind surfer rig to me. After sailing F18 for a while and coming back to the 20, I had to get used to seeing that much bend in the rig. I'm not sure you could do any damage even with 10:1 though.
Posted By: ThunderMuffin Re: 7:1 to 8:1 conversion - 02/23/12 08:11 PM
I've got a 10:1 on my N20 and I crank the hell out of it with absolutely no concern about my stick breaking.
Posted By: Mlcreek Re: 7:1 to 8:1 conversion - 02/23/12 09:16 PM
So with a 10:1, you crank your stick and don't break it?
Posted By: David Ingram Re: 7:1 to 8:1 conversion - 02/23/12 09:29 PM
Typical 20 drivers, always inappropriately cranking their stick. Speed tip, less cranking more sailing.
Posted By: orphan Re: 7:1 to 8:1 conversion - 02/24/12 12:31 PM
But they can say "My stick is bigger than your stick".
Posted By: Mlcreek Re: 7:1 to 8:1 conversion - 02/24/12 01:04 PM
If Grand Pa can find the stick!
Re: 7:1 to 8:1 conversion - 02/28/12 02:27 PM
HM is right.
PM for a pic
Hi CCAT, i have PM'ed you 2x trying to see that diagram. Can you please send or post it?
Thanks
We sail with 10:1 as well on the I20 and can really crank it. Amazing how much it flattens the sail along with the downhaul. No problem on the mast for us.
Posted By: samc99us Re: 7:1 to 8:1 conversion - 02/29/12 10:21 PM
I've run < 2" separation block to block on the N20 with a 10:1 purchase, the mast barely winces.
