Is this true about our auto gas - 02/11/1408:27 PM
Just got an email with the link below on ethanol in our gas. I know for Outboards you need to use Rec90, which is free of ethanol, but this sounds really bad.
Ethanol also removes some of the varnish and deposits in the cylinder heads/valves which then moves around and cruds up everything.
Most importantly (to a cheapskate like me), Ethanol does not contain the same amount of energy per gallon as gasoline, so I'm getting fewer miles/gallon using E10 fuel.
My outboard mechanic said E10 will corrode the aluminum carburetor in a short period of time, and it could eat some of the fuel hose, clogging the filter.
Re: Is this true about our auto gas - 02/12/1412:32 AM
It's actually cars prior to 2001 that shouldn't use the E15 stuff (that fox report that said 2012 was wrong). I haven't seen the E15 in any gas stations but I suspect the public is at it's threshold with the 10% ethanol stuff and the blow back will make it go away soon enough.
Re: Is this true about our auto gas - 02/12/1401:41 AM
Still being fought - article here Unless you plan on burning all the fuel within a week or two, never use automotive pump gas as you can never be absolutely sure whether its an ethanol blend or not. Don't ask me how I know...
I have 2 cars here that love the stuff and actually have better dyno figures with E85 than the usual pump stuff and indeed some of the not so usual pump fuels.... and before we all argue about it being an Australian thing.... ONE of the engines is from your beloved ole USA
Pricing is competitive too with the ethanol fuels on average 10-20% cheaper over traditional fuels. yes we use more but not 10-20% more so it does actually save you $$$$$$
Older engines don't like it so much but, specifically re-built engines and tuned to run on ethanol fuels will give better power and economy over the original engine even when it was at its very best.
Re: Is this true about our auto gas - 02/12/1412:17 PM
This, it's really bad in applications like outdoor power equipment.
Re: Is this true about our auto gas - 02/12/1402:48 PM
Ethanol is basically alcohol. Alcohol has about half the energy per volume. In some performance scenarios it makes sense because of the added cooling and lower cylinder temps with pounding so much more fuel in.
Re: Is this true about our auto gas - 02/12/1409:32 PM
Corrosion is one thing. Stratification in the fuel is quite another. The latter will totally eff up your fuel injection system no matter what kind of filtering you have.
Re: Is this true about our auto gas - 02/13/1402:58 PM
I drive a 20 year old Z-car. In the past 18 months I've had to have the injectors replaced, the fuel lines replaced, and the tank dropped and drained. All ethanol related problems. I run premium fuel, keep the tank topped off, and use a fuel stabilizer, but that is not enough...
Re: Is this true about our auto gas - 02/13/1404:55 PM
Originally Posted by bacho
Originally Posted by samc99us
And the publics opinion on what gas we buy matters to who exactly? We buy what they put in the pumps.
You can vote with your wallet, plenty of stations around here have started selling non-ethanol again.
Maybe you can, but the only stations on this list (http://pure-gas.org/index.jsp?stateprov=MD) within a 1 hour drive are Marinas. I know the places and their docs aren't going to support even my 3,000lb econo car.
Had the same issues with my 1990 jeep and the generator on the old RV. After spending almost $1000 in repairs on the gen I ran only non-ethanol and stabilizer......never had another problem. Same for the jeep, have not had any issue since keeping away from the ethanol.
Was also told that it is not good for my 05 durango.
Re: Is this true about our auto gas - 02/13/1409:24 PM
1994 300 ZX TT, perhaps? Maybe black 2 seater? man, I loved that car. added bigger turbos, stronger waste gate springs, camshafts, tapered valves, 50 shot nitrous and a roll cage.
To be young, stupid, and spend all your money on go-fasts...
Re: Is this true about our auto gas - 02/14/1402:41 PM
seriously jealous. But now I know why they're so hard to find (at least the un-mod ones).
Would have liked that anniversary edition ('97 I think?) Supra TT coupe as well.. but way out of my price range at the time.
I applaud you both for (1) the budget to mod/race those things and still have money for sailing, and (2) spouse/family that approves of such road monsters.
the only thing i DIDN'T like on the 300 TT was that HICAS setup . Got it tuned right but the OBDC kept throwing codes at me so I had to override it eventually. Must have had something to do with the torque loading in full boost, or the replacement differential I had on there after we destroyed the first one dyno testing.
Re: Is this true about our auto gas - 02/14/1403:46 PM
I've had a hard on for a Supra since I was in high school. Every time I shop for one, they're more money than the last time I looked. The untouched low miles ones are about extinct at this point.
Re: Is this true about our auto gas - 02/14/1406:03 PM
I drive a 20 year old Z-car. In the past 18 months I've had to have the injectors replaced, the fuel lines replaced, and the tank dropped and drained. All ethanol Mike, related problems. I run premium fuel, keep the tank topped off, and use a fuel stabilizer, but that is not enough...
I think they went to ridged tubing back then, but if not check the rubber lines and see if the used 30R9 from the regulator to the fuel rails. If not, not a problem, they probably used the 30R7... Just keep an eye on it them as the alcohol can cause premature deterioration.
Re: Is this true about our auto gas - 02/14/1407:17 PM
Those are some nice Z's. I kept all my mods under the skin. I wanted a stock look.
I'll check the fuel lines and see what was done. The shop that works on my car specializes in Z32's so I'm pretty sure it was done right when it was rebuilt.
Re: Is this true about our auto gas - 02/15/1402:52 AM
If you have an older vehicle/engine, the fuel system was built with rubber and plastic parts designed to be resistant to gasoline only. It may or may not be resistant to ethanol by luck. Newer engines fuel systems are usually resistant to ethanol, especially the "rubber" parts. But, there have been some circumstances where cheap plastic carburetors have swelled over time from ethanol and need to be replaced.
Absolutely fresh ethanol-gasoline mixes in clean engines will run fine, without problems. If you use it quickly and constantly, you will not have problems... But, there are a lot of "ifs and buts".
Ethanol absorbs water, lots of it. It will actually remove small amounts of water from a wet fuel system, if it is fresh. But if you do so, use the fuel up quick!
Here are the problems: Ethanol is constantly absorbing water. If there is water in the bulk tanks at the gas station, it will absorb it. If there is high humidity in the air, it will absorb it, either at the gas station or in your own gas tanks. Over time it will keep absorbing water, until the ethanol-gas mixture becomes saturated and can absorb no more. Now, if it is saturated, and conditions change (such as temperature, evaporation, additives, etc.), water may actually come out of solution and sink to the bottom of your tank, carburetor bowl, or fuel line. Seperated water can cause all kinds of unwanted chemistry inside your fuel system. A common problem for 2-cycle engine owners' is water in the fuel. If you buy or keep old ethanol-gas mixtures with significant water dissolved in it, you cannot see the water,YET! Now, you add your 2-cycle oil to your gas, and you have changed the chemisty.--Like a magic trick, water drops out and settles to the bottom of your tank. That water will rust the bottom of a metal tank. Since that dirty water is on the bottom, when you hook up your outboard motor to the tank, that is the first liquid into your carburetor. Now your motor won't start. So you put the motor aside in the garage for awhile,--now you will need a carb re-build, if not a whole new carburetor.
When it comes to 2-cycle engines, BUY PURE GAS ONLY!
