Sail number removal question.....
Posted By: Pirate
Sail number removal question..... - 12/03/14 11:37 AM
Mylar sail with "stick-on" numbers.....
any tips / tricks for the removal of the numbers from this type of sail would be appreciated (before I stuff it up ) wink
cheers
Posted By: Jake
Re: Sail number removal question..... - 12/03/14 12:37 PM
No real tips - they should come off pretty easy. Once you get an edge, though, go sloooowwww. It will make you pay a penalty if you get anxious and the second you try to go for speed, the number will tear and explode into tiny strips. If you are patient and go slow, it should come up in big pieces. Also go super slow at the very last bit or it leaves a tiny tip.
Once removed, if you have any adhesive left behind on the sail, use goo-gone or denatured alcohol to remove the remaining tacky spots.
Posted By: brucat
Re: Sail number removal question..... - 12/03/14 01:49 PM
Does heat help, or just for hulls?
Posted By: rehmbo
Re: Sail number removal question..... - 12/03/14 04:55 PM
I'd be afraid to delam the sail, but never tried.
Posted By: bacho
Re: Sail number removal question..... - 12/03/14 05:20 PM
It certainly helps to leave it out in the sun for a while and do it.
Posted By: Jake
Re: Sail number removal question..... - 12/03/14 05:44 PM
Yes...a little heat won't hurt you but I wouldn't put much more heat on it than a hair drier can supply (I wouldn't use a heat gun). Sunlight is a good option.
Posted By: Anonymous
Re: Sail number removal question..... - 12/03/14 08:11 PM
I took some numbers of a second hand sail with a sailmaker last week and he advised the exact opposite. Keep it out of the sun get a corner then rip it of fast like a bandaide. Worked a treat
Posted By: brucat
Re: Sail number removal question..... - 12/03/14 08:15 PM
Interesting. Maybe depends on the age of the materials? Do they become brittle (likely to shred) with age and/or UV exposure?
Posted By: bacho
Re: Sail number removal question..... - 12/03/14 10:23 PM
I was thinking about vinyl numbers when I wrote my post.
I guess the cold technique may be better for Dacron numbers.
Re: Sail number removal question..... - 12/03/14 10:39 PM
I've never had vinyl numbers on any of my sails. I'm talking standard dacron numbers on mylar.
Posted By: Jake
I admit I've never tried to rip them off with speed but I've removed a fair share of them. Every time I've done it, it's been room temp and I removed them slowly in order to get them to come off in one relatively large piece at a time.
Posted By: Isotope235
Re: Sail number removal question..... - 12/04/14 12:38 AM
For PSA Dacron insignia cloth, I'd put some Goo-Gone on them first to soften the adhesive. They should peel off pretty easily. I have a friend who swears by lighter fluid (cigarette lighter, not charcoal lighter), but I prefer the odor of citrus solvent.
Eric
Posted By: P.M.
Re: Sail number removal question..... - 12/04/14 01:42 PM
+1 on the lighter fluid. I've been using it for decades and it works better than most products on the market. Great for tar removal also.
Re: Sail number removal question..... - 12/04/14 06:11 PM
we used gas as tar remover when i worked at the local car wash in the 70's. that worked great too
was probably terrible for the car's paint/finish
Posted By: waterbug_wpb
Re: Sail number removal question..... - 12/04/14 06:15 PM
Posted By: jollyrodgers
Re: Sail number removal question..... - 12/04/14 07:41 PM
If you have good gloves and respirator, the chemicals that work well to dissolve the glue are xylene for the ripstop numbers, and goof-off for the vinyl glue. Maybe one or both of those works for everything. Goof-off takes of the glue from foot pads better than most other products, and xylene removes sharpie from mylar as well.
Posted By: mikekrantz
Re: Sail number removal question..... - 12/04/14 07:48 PM
sunblock does a great job of removing permanent sharpie
makes me wonder what it's doing for my skin...
Posted By: Karl_Brogger
Re: Sail number removal question..... - 12/05/14 02:29 AM
That is certainly something I wouldn't have tried.
Re: Sail number removal question..... - 12/05/14 01:03 PM
Jay it was much more like this (i was the short white guy in the back)
Posted By: Ventucky Red
Re: Sail number removal question..... - 12/08/14 07:13 PM
Mine pretty much pulled off, but there was a few spots that didn't...
Wife's hair dryer took care of it...
