Posted By: Gmerrell Paint suggestions? - 03/16/15 05:15 AM
I just bought a used G-cat 5. Its my first sailboat ever. She is in good shape but needs a fresh coat of paint. Any brand suggestions or tips?
Posted By: brokenrinker Re: Paint suggestions? - 03/19/15 06:38 PM
I am by no means an authority on this but I think, if possible the best solution is to buff out the gel coat. Having said that, last year I decided to paint my boat. After much research I decided to try
http://www.rustoleum.com/product-catalog/consumer-brands/marine-coatings/topside-paint You can brush it, roll it or spray it. I sprayed it and was pretty happy with the results. I've also used Basecoat/Clearcoat automotive paint on fiberglass boats but eventually the clear started to peal off and the stuff is pretty toxic.
Posted By: tback Re: Paint suggestions? - 03/19/15 06:45 PM
Did you use the White? And presumably you did various sanding after painting?
Posted By: Anonymous
Re: Paint suggestions? - 03/19/15 06:53 PM
is there paint on it now? or gel-coat?
if gel coat you can use acid to clean it and a "poly" product to seal and shine it up
I use new glass 2
a lot easier and cheaper than painting
Posted By: brokenrinker Re: Paint suggestions? - 03/19/15 06:56 PM
Yep - White. I just followed the instructions, sand, primer, paint. It took a couple/three coats since I was spraying it.
