what type of boat will you be carrying? This setup seems more suited for pontoon/deck boat types that are very heavy...?
Prindle 18.... it is the trailer that came with my $100 boat... I cut of the risers that held the boat... fronts we 14" and the rears were 18" as pictured... In talking to the trailer store guy the other day he was pretty versed on these things. Told me they manufacture made a one size fits all trailer
It kinda looks like a De Dion rear car suspension.
Other than boat trailer racing, do you really need an independent suspension?
I got this boat a good 200 miles from my house... there was a few times it felt like it was not even back there when towing it home,, it was pretty smooth... Boat Trailer Racing hmmmmmmmmmmm you got me thinking here!
I bet those Rancheros would be really stiff shocks for what he has there (not to mention pricey). I put a set on a Nissan 4x4 I had once and the ride turned into the equivalent of a log wagon.
I'm not sure what the coilover shocks add to that suspension anyway, though...Having both the leaf spring and coil over shocks is nothing but redundancy...leaf springs provide a bit of frequency absorption through friction between leafs and don't typically use shocks (on trailers anyway). However, in that application, I presume those leaf springs only serve the purpose of a fourth link in that suspension system and keep the axle in place while the coil over shocks do most of the suspension work.
With that in mind, I would consider something like the Gabriel load carrier shocks. They have some with a variable rate spring that only starts to add relative load carrying capacity under some compression...that should be pretty good for that application. You would need to call someone and give them travel dimensions for that shock to figure out which version would fit.
https://www.summitracing.com/search...ing&keyword=gabriel%20load%20carrier I don't think these are the original shocks... there is another trailer with the same set up at our storage yard... a Hobie 20 that hasn't moved in 13 years... that has some Sears $9.99 specials...
Summit Racing... they can burn a hole in your pocket pretty quick..
