Catsailor.com ARC 17 Ultimate boardless beach cat...
Posted By: Seeker ARC 17 Ultimate boardless beach cat... - 11/05/03 06:28 PM
It’s back…The Super Cat 17 is back as the ARC 17 better than ever ARC-17 Web Page.…lighter weight…stronger construction (epoxy)…larger sail area sloop (257 sq/ft)…wider beam (8’-6”)…Spinnaker option (290 Sq/ft=26.94 m2)…Tom has definitely not been a sleep at the wheel.
My old 1981 Super Cat 17 was my all-time favorite boat…what I consider the ULTIMATE ALL AROUND BEACH CAT! Simple, fast, no boards, bomb proof! What more could you ask for? How about lighter/stronger/more sail/max trailer able beam/highest level of finish and hardware/Unirig or sloop configuration/Spinnaker option…Tom (and Bill Roberts)awesome job!
Bob Hall
Posted By: thom Re: ARC 17 Ultimate boardless beach cat... - 11/05/03 07:34 PM
Tom's also developed an interesting snuffer system for that boat as well.
thom
Posted By: Jake Re: ARC 17 Ultimate boardless beach cat... - 11/05/03 07:47 PM
WOW.
a 17' boat with 257 sq feet of sail? Upwind? My 6.0NA has a reputation for being seriously overpowered monster and it's 3 feet longer and has a measly 264 sqft of area (only 7 more!).
the link to the website is here:
http://www.aquarius-sail.com/ Posted By: dave mosley Did Bill Roberts invent... - 11/05/03 07:55 PM
Did I dream this, or did someone tell me that Bill designed the first snuffer system?(sorry if thats a name brand product infringement thing)
dave mosley
www.seacats.orgbtw we are proposing to have a second annual supercat 20 Nationals, and would like to include the whole line of SC's and ARC's. I understand there was some talk of a national event to be held next year in Pensacola, is this right, and if so, would you consider letting the SEACATS run your event here in Columbia SC May 15-16th 2004?
Posted By: BRoberts Re: ARC 17 Ultimate boardless beach cat... - 11/05/03 09:31 PM
Hi Jake,
There are two important parameters when it comes to a boat being overpowered or not with a sail plan. The first important number is sail area. The second important number is sail aspect ratio which is closely related to mast height.
Bill
Posted By: BRoberts Re: Did Bill Roberts invent... - 11/05/03 09:36 PM
Hi David,
Yes I did, and I have a US patent on it. In the mid to late 1960s I was sailing a Flying Dutchman. There I came up with the spinnaker launching and retracting system which has now spread to many classes and all over the world.
Bill
Posted By: Luiz and you can see Bill's patent online following... - 11/06/03 01:43 AM
...this
L I N K. It was filed [color:"red"]Oct 6, 1966[/color].
Posted By: dave mosley Re: and you can see Bill's patent online following... - 11/06/03 02:33 AM
I find it incredible that this system was not widely used for all these years. I have seen versions of it for awhile, but not until the I20 did I really see it used on cats. Maybe others were using it, but that is the most prominant example that seemed to jumpstart it. I hope Bill's making a killing off of it, I know I sure love mine. I have sailed the Viper(20' monohull with open stern) and it has a molded in version, and I think the Laser 2 is doing something similar too.
Thanks Bill,
David Mosley
Posted By: JoeLeonard Re: ARC 17 Ultimate boardless beach cat... - 11/06/03 04:17 AM
Anybody have a clue what this boat has for a Portsmouth number?
Posted By: Luiz Re: and you can see Bill's patent online following... - 11/06/03 01:20 PM
This fact is a proof of how conservative the worldwide sailing comunity is - even the most competitive ones. Multihullers have a reputation of being more open minded.
But I remember lots of IOR boats in the 70s using this system, with a big tube inside the cabin. After some time the system was abandoned. Maybe it is not so efficient for bigger spinakers, but the truth is I don't know the actual reason. I was too young...
Anyway, even the best engineering takes some time to replace traditional methods. When refrigerators were invented, it took a long time and extensive advertising for people to start buying. Sounds like a joke today, but it's true.
One reason why sailing evolves so slowly, is the small size of sailing related industires. Big industries and corporations are faster then individuals with regards to (profitable) inovations. Mass production turns small unit profits into interesting results.
Keeping with the refrigerators, Lokheed's representative in Brazil once told me the following story when he rented my apartment there:
A company (there) started to mold the foam insulation instead of just jam pieces of foam between the internal and external walls of the refrigerators, as was customary at that time. The insulation of the molded foam is far better then that of pieces of foam, so the insulation could be thiner and still more efficient. Then, a smaller engine could be used (cheaper and less power consumption) and the internal volume grew (more groceries inside a refrigerator that looks the same in the outside).
This inovation found its way into every industy in the world and also helped that Brazilian industry a lot - they owe some very popular international brands today.
Comercial planes also copied the same idea (to keep the heat inside) and that explains why the guy from Lokheed knew the story.
We need more people sailing and greater production volumes. Then, improvements will be introduced yearly, like in cars.
Cheers,
Posted By: Wouter Re: ARC 17 Ultimate boardless beach cat... - 11/06/03 02:52 PM
It provisional Texel number = 100 with spi and 104 without (I have not taken into account the oversized spi as that will drop the handicap number but it remains to be seen wether the craft is really faster with such a large spi)
This leads to some "conservative DPN" to be expected at 65 (spi) and 67,5 ( no spi) under PN.
I used 8 kg's for the weight of the mainsail, battens and jib together and added that to the 136 to give 144 kg's overall no spi = 318 lbs. My smaller Pentex sails together are this weight and so this should be a good comparison. Weight of spi package has NOT been included in this. With it the ready to sail weight of the spi version will be 144 + 5 kg = 149 kg's = 329 lbs. Pretty standard for a 5.18 mtr. = 17 ft long 2,59 = 8'6" wide platform with an 8,76 mast. Fully fitted Hobie FX-one and Inter-17 are on either side of it within a few kg's (lbs).
Its jib is quite normal in size 4,74 sq. mtr. = 51 sq. ft. The remainder of those 257 sq. ft. = shy 24 sq. mtr. is all to be found in the mainsail and mast. WOW ! just 3 sq.ft less than the US I-20 main.
measure of aspect ratio of the mainsail = luff^2 / area = estimate 8.5^2/19,1 = 3.78 (other definitions are used as well but this is a good approximation)
Compare this to some other types :
A-cat = 8,8^2 / 13,95 = 5,55
US I-20 = 9^2 / 19,4 = 4,18
F18 = 8,5^2 / 17 = 4,25
F16 = 8^2 / 15 = 4,27
Prindle 16 = 7.37^ / 13,82 = 3,93
Hobie 16 = 7,33^2 / 15,21 = 3,53
Nacra 5.0 = 7,65 / 13.50 = 4,335
Bill, how does aspect ratio impact on being overpowered exactly ? You have me at a loss here.
Spinnaker area 27 sq. mtr. I-20's is 25 sq. mtr. Boats of comparable length and mastheight have typically 17-20 sq. mtr.
Aspect ratio spi :
ARC 17 = draw^2/area = 8^2(max !)/27 = 2,37 (probable 7,6^2/27 = 2.14)
I-20 = 8,3^2 / 25 = 2.75
F18 = 8,25^2 / 21 = 3.24
F16 = 7,5^2 / 17,5 = 3.21
ISAF youth trail boats = about 7^2/ 15 : 7,2^2 / 17 = 3.26 - 3.05
NA NE Nacra 6.0 with 250 sq.ft. spi = 8,5^2/32.5 = 2.22
Mosquito 17 = 6,38^2/16,9 = 2,41
Mosquito 15 = 6,38^2/14.2 = 2,87
Mosquito 15 was found to be faster in most conditions than the Mosquito 17 both in Aus as in South Africa. We all know how the NA NE N6.0 spi performs with respect to that much smaller I-20 spi.
More than a few sailors have noticed that smaller spis of higher aspect ratio are quicker than larger spis with lower aspect rations; in most conditions except a small wind range between light and medium winds. When the winds are light than the large area spi limps before the smaller spi does so; therefor the smaller spi is more efficient again in light winds.
For this reason I did not hit the ARC 17 with the kind of several Texel penalty for oversized spis. Remember the Tybee 500 where the NA NE had to give the US I-20 time on Texel handicap but where they were found to be about of comparable speeds.
The jib is pretty normal is aspect ratio and comparable to those of the newer boats with spi kits.
With this I think the estimates of the PN given are dependable; the old sc17 was DPN = 73. Quite an improvement.
Posted By: Keith Re: ARC 17 Ultimate boardless beach cat... - 11/06/03 03:04 PM
The old SC-17 with a PN rating of 73 was a ratings beater! The new one should be awesome. Even though it's a foot short, any chance of seeing this in the F-18 wars, either without boards or a version with?
Posted By: BRoberts Re: ARC 17 Ultimate boardless beach cat... - 11/06/03 07:29 PM
Hi Joe,
For a first cut at a PN for this boat why don't we go to the US Sailing rules? The base PN for the previous SC17 was 73. The major changes between this boat and the old boat are in the sails. The mainsail is larger and square top and the boat has a spinnaker. The adjustment factors are as follows: 0.95 for the larger mainsail
0.995 for the square top
0.96 for the spinnaker
The boat without spinaker is slightly lighter than the old 17 but add the pole and rigging and sail and sheets and blocks etc and we are back up to the old 17's weight. The boat is 6 inches wider out of 8ft, or 6%, which will be hard to find in boat performance but the rules say wider boat so we better apply it. That is another 0.995. This brings us to a total adjustment factor of 0.9029. Apply this to the original 73 PN and you have an estimated PN for the new boat of 65.9 calculated using US Sailing rules. Looks like a fair starting point to me.
Bill
Posted By: Seeker Re: ARC 17 Ultimate boardless beach cat... - 11/06/03 08:41 PM
Bill… So what you are saying is that if the ARC 17 lives up to the 65.9 PN number it is going to be rated faster than all of these cats with Dagger boards…
Prindle 19 @ 66.4 original stock not MX w/o spinnaker
Nacra 5.8 NA @ 66 w/o spinnaker
Super Cat 19 XL @ 66.6 w/o spinnaker
18 sq Cat II Including Nacra 5.5, 11' beam@ 67 w/o spinnaker
Inter 17 Uni 30’ @ 67 with spinnaker
Taipan 4.9/F-16 @ 66.9 with spinnaker
If this proves to be true on the course, what a testimony for boardless cats.
Looking at the photos on the web site…there is a sequence of three photos where the bow is purposely driven down…was this to show the pitch pole resistance of the cambered deck? Is it to show how to motor up wind by utilizing the bows instead of boards? Both?
Bob.
Posted By: BRoberts Re: ARC 17 Ultimate boardless beach cat... - 11/06/03 09:50 PM
Hi Seeker,
I appreciate your good wishes. I hope they come true. Only time will tell.
Don't jump to the conclusion that all boardless beach cats can carry chutes. Most boardless beach cats have non symmetrical hulls for the full length of the hull. Some others have a skeg well aft on a symmetrical hull. Either one of these hull designs have the CLR well aft on the boat. This leads to severe lee helm with the chute up. The ARC beach cat hull design has a deep vee hull shape forward to generate lift in the forward section of the hull and then the hull shape transitions to a round bottom at the transom. This means the rudder has to be oversized because it acts as the other half of the laterial resistance,LR or centerboard area, and rudder blade at the same time. So on the ARC17 the lift , the laterial resistance, is made up of a deep vee fore foot on the front end and an oversize rudder/centerboard on the aft end. The center of effort with the chute up will never go far enough forward to get in front of the bows on this boardless beach cat hull design.
The pictures showing the bows being driven down to and under the water (skipper and crew sitting forward) were taken to show the foregiveness of this hull design and high crown foredeck. A design with low bows and flat decks would have 'pitchpoled a long time ago'.
The ARC17 sails to windward best with the waterline half way up the bows. Don't forget on an ARC boardless boat, those rudders are working hard for you sailing to windward generating lift. A little less than half the lift comes from the bows. The rudders are much higher in aspect ratio than the fore foot of the forward hull, therefore the rudders make less drag than the hull for a required pound of sideforce.
In racing the boardless ARC17, it will struggle to windward but it will really scoot downwind.
Bill
Posted By: Jeffwsc17 Re: ARC 17 Ultimate boardless beach cat... - 11/07/03 04:13 AM
WOW....been away for awhile. I saw the preview pics last year....now in production....wow...sign me up!
Posted By: brobru Re: ARC 17 Ultimate boardless beach cat... - 11/07/03 03:27 PM
Bill, Wouter, Bob and All,
What a great time for innovation in singlehanded racing cats!
Reading this line of 'sailing minds' is very valuable,...especially the last post by Bill about the 'bow volume under spinnaker load' design.
...it was a good read!
..here is an idea,...make a 'Uni-rig open' portion of a large regatta,...allow the participants to sail other manufactures' design(, for example, Fx-1, T 4.9, N5.5, I-17, SC17, A-cat..etc)...kinda like a round robin, except on different boats,...the 'winner' would be a composite of 'all' types sailed.......since all these designs have their differences, sailpersonship would be the test..
....is that an idea,..or a dream...?
..congrats to your new 17 Bill,....where can we demo this???
regards,
Bruce
St. Croix
Posted By: Colin Re: ARC 17 Ultimate boardless beach cat... - 11/07/03 05:57 PM
Hi Mr. Roberts
The SC 17 was the first catamaran I ever sailed. What a revelation it was. I have been a fan since.
The website mentions the rudders have a series 63 section. Are they designed to operate in the bucket upwind or does that happen only when reaching?
If not, maybe rudders with more area could be used (with mast rake) to give the boat a better drag angle racing upwind. It would be neat carry one set of foils to make it the ultimate beach boat and one set for racing around the buoys. That would be little extra investment to have essentially 2 boats.
What is the design displacement? The SC 17 I sailed on seemed better able to handle an extra passenger than many other cats it's size.
What is the design waterplane beam of the hull? Are the hulls any different from the original SC 17?
It is nice to see a new cat with a lower aspect ratio sail plan. Not all of us sail our boats around the buoys. Reaching fast is the best part of catamaran sailing.
If I was in the market for a new cat there would be no question which one to choose. I hope you sell as many as you can build.
-colin
Posted By: BRoberts Re: ARC 17 Ultimate boardless beach cat... - 11/07/03 08:00 PM
Hello Colin,
Thanks for your comments. I will try to respond to your questioms in order.
The rudders are NACA 6300 series foil shapes. They are the same rudders as used on the ARC22, therefore they appear large in size for a 17ft boat but the large size is needed for reasons already mentioned. To operate in the "drag bucket" of a 6300 series foil the lift coefficient must be small. That means in general terms that the rudders are not working hard. But the rudders on the 17 are working hard going to windward. The time that the rudders can operate in the drag bucket is when the side forces are small and the boat speed is high, at a low lift coefficient. This point of sail is sailing deep downwind with the spinnaker.
I don't think two sets of foils, rudders, are necessary. The ARC17 already has large foils by industry standards. Smaller foils have been tested and that is definately the way not to go.
The design displacement for the ARC17 is 700 pounds. Now 700 pounds displacement for a lake sailing boat and 700 pounds displacement for an ocean sailing boat are two entirely different amounts of free board. You could take a foot off the bow height if the boat was a "small lake only" design. This extra free board for ocean sailing, SE coast of Florida, leads to more passanger carrying capability if that is the way you want to use it. Without the extra passangers, the extra bouyancy keeps the beams up out of the waves in the ocean.
The max hull width is 14 inches (at 2/3rds hull height) and it is the same as the old SC17 hull shape. The max waterline hull width is 12 inches.
This boat with its lower sail plan aspect ratio should be one heck of a beach cat drag racer.
Thanks for the good wishes, Colin.
Bill
Posted By: David Re: ARC 17 Ultimate boardless beach cat... - 11/09/03 07:48 PM
Bill,
I went to the Aquarius site to look at the 17 and saw a new ARC 21 at 8.5' in width. Besides width, what is different about this seeming new design over the ARC20, which you state is able to be still ordered? (besides the variable width on the 20).
David
H20
Posted By: BRoberts Re: ARC 17 Ultimate boardless beach cat... - 11/10/03 03:44 AM
David,
Aquarius Sails builds production boats as advertised and shown on their website. Aquarius will also build whatever size boat you want as long as it can be built with production tooling. In response to questions about a 20ft ARC boat from sailors considering a distance racing circuit, I pointed out to them the capability built into the original 22 tooling. A 20ft boat can be built in the ARC22 mold by simply placing the transon immediately after the rear beam. This boat is a true 20ft ocean racing catamaran with the mast 1ft aft of half hull length and the tall eliptical hull forward for sailing in big waves. This forward hull shape allows for the maximum forward migration of the instantaneous center of bouyancy and the rear beam being on the transom allows the crew to move further aft freely; no rear beam and tillers in the way. This maximises the distance betweem the CB and CG for maximum pitchpole resistance. This increase in forward stability leads to more reaching speed and downwind speed with the spinnaker especially in big waves.
Bill
Posted By: Colin Re: ARC 17 Ultimate boardless beach cat... - 11/10/03 06:01 PM
Hello Mr. Roberts,
Thank you for your reply!
To see if I could learn something from your reply I did a rough calculation of the size the rudders would need to be to operate in the bucket. I considered a catamaran of similar dimensions to the SC-17 sailing upwind at 6 meters per second, and looked at the effect of rudder area on resistance (assumed NACA 63-009 section).
I learned that while increasing the area (and span) of the rudders would reduce resistance, the effect of operating in the low drag bucket was minimal (~ 10 N) compared to the total resistance. The rudders also would need to be impractically large to provide the required lift at a Cl of only .20. Did not see any obvious minima to optimize around, but I did not (could not) consider the effect of leeway angle on hull residuary resistance.
So, my rudder question was a rather silly one.
The 63-0xxx are nice sections for avoiding ventilation at high speed and load, which is a much more important consideration in this case (guessing that's why it was chosen).
Thank you for indulging an amateur with your explanation.
-colin pitts
Posted By: BRoberts Re: ARC 17 Ultimate boardless beach cat... - 11/11/03 02:02 AM
Hi Colin,
Your question was not silly. Look at what you learned. That is very worthwhile. To windward the best we can do is have the daggerboard and rudder operating at leak lift to drag ratios. To calculate L/D, simply divide Cl by Cd at points along the drag polar. I think you will find that peak L/D occurrs at or very close to a lift coefficient value of one, Cl = 1.0. Read several points along the polar. Calculate L/D. Plot L/D vs Cl and against angle of attack. This will tell you some interesting things.
Good luck,
Bill
Posted By: Seeker Re: ARC 17 Ultimate boardless beach cat... - 11/11/03 06:46 PM
Bill…could you briefly explain the “Drag bucket” concept?
You always seem to have explanations that are technical enough to give a good grasp of a concept without making it necessary to have a graduate level of Engineering knowledge in order to comprehend.
I feel in this case like I missed the foundation that the rest of the discussion was based upon...as if coming into the middle of a conversation already in progress.Thanks...
Bob
Posted By: Colin Re: ARC 17 Ultimate boardless beach cat... - 11/12/03 12:13 AM
Hello Mr. Roberts
Well, that really is interesting.
Section peak lift to drag ratio occurs - just as you said - at a lift coefficient close to 1.
Then I included a term for the hull total resistance (using Dr. Norwood's estimation method) and the induced drag of the rudder (since it has finite span). The optimum lift to drag ratio for the hull and its rudder occurs when the induced drag is equal to the sum of the hull total resistance and section drag - which makes sense. The induced drag is decreasing with speed while the other drag terms are increasing so there is a local minimum in the curve of resistance versus speed when these terms are equal.
The more rudder area I gave it the lower the speed at which the optimum lift to drag ratio occurred. The lower the speed at which optimum lift to drag ratio occurred the better the optimum lift to drag ratio got.
The rudder really is working hard no matter what. The optimum lift to drag ratio for the whole boat happened when the rudder was just about to stall no matter how large I made the rudder. That happens at a lift coefficient - as you said - of about 1.
At the high angle of attack the rudders operate it is really nice they can be angled relative the hull.
Thank you for your suggestion and encouragement.
-colin pitts
Posted By: Colin Re: ARC 17 Ultimate boardless beach cat... - 11/12/03 12:30 AM
Hi Seeker,
I just meant the low drag portion of the lift vs drag plot for the section.
The 6 digit series airfoil sections have pressure distributions that encourage laminar flow over a good portion of their surface at low angles of attack. Laminar flow reduces the skin friction so they have lower drag when it is present. It shows up as a "bucket" on the lift drag plot for the airfoil section.
This turns out to be not so important in the overall lift to drag ratio of a catamaran. I could not see the forest because there was a tree in the way.
-colin
