The 2-Minute Tack
Posted By: Danno
The 2-Minute Tack - 06/27/05 06:12 AM
I need help tacking. I sail a nacra 450, 1-up and just learning. Only experience besides the 4 trips in the 450 are 12 trips in a Force 5.
Here's how I do it in 5-15 knots:
Sail close hauled, traveller centered (cuz I don't want to mess with it). Ease the tiller out until I'm facing the wind. Uncleat the burdened cleat and make it tight on the new side. Boat stops, not able to tack. Sometimes I drift backwards. I backwind the jib. 2 or 3 minutes later and I'm off!
I've got Rick's video and don't see what I'm doing wrong. I also was surprised that I could tack better in 10 knots compared to 15. At least I know how to park
Any suggestions?
Danno
Posted By: Rolf_Nilsen
Re: The 2-Minute Tack - 06/27/05 08:46 AM
I dont know your boat, but some immediate toughts after reading your description:
Dont bring in the mainsheet to quickly on the new tack, get the boat going again before you sheet in. Sheeting out about 40cm should be enough.
Dont hurry over to the new side (unless you risk capsize), stay on the old windward hull.
Take care to steer trough the whole tack, dont let the rudders straighten out.
Good luck!
Posted By: Mary
Re: The 2-Minute Tack - 06/27/05 10:23 AM
What do you mean by "uncleat the burdened cleat and make it tight on the new side"? It sounds like you are talking about the jib.
Posted By: Marc Woudenberg
Re: The 2-Minute Tack - 06/27/05 11:44 AM
Having had a N450 my self, the trick is not to loose boat speed. The N450 and ist predecessor N4.5 have a keel, no daggerboard to pivot around.
Turning into the tack not too abrubtly. Keep the jib out on the side of the previuous course as long as possible to pull the bows around. Only cleat it for the new course after the main flips over to the other side. The main should be sheeted in only slowly to pick up.
To get you on the right tack floating backwards, apply opposite rudder. This pushes the sterns in the direction you want rather than aiming the bows.
Good luck.
Posted By: Jake
Re: The 2-Minute Tack - 06/27/05 12:11 PM
Danno,
If your jib remains cleated and backwinded for even a second, it will stop the boat. Make sure that as soon as the jib collapses when it gets close to the wind that it is uncleated. The timing on moving the jib is important - too soon and you are loosing valuable speed into the tack - too late and the jib will push the boat backwards. As the other folks said too - don't put the tension back in the mainsheet until the boat is moving and you are moving your weight forward again. You want some twist and belly in the main while the boat is accelerating back to full speed.
Your weight placement on that boat will probably be important too. Make sure you have the crew weight as far aft as possible when tacking. This will help to lift the bows clear of the water so they don't have to push a lot of water as they turn. To see this affect exagerated, turn hard while reaching and you will see how much water the bows have to push when turning. Moving your weight back will lift the bows so the boat doesn't encounter quite as much resistance while it turns.
Re: The 2-Minute Tack - 06/27/05 12:14 PM
Danno also have a bent rudderstock, so the rudders are not aligned. This might be part of the problem..
Se the "Rudder Tubing Bent" thread.
Posted By: Chris9
Re: The 2-Minute Tack - 06/27/05 12:52 PM
When I had a Hobie 16, I found that in most conditions (*), backwinding the jib is a really good way to stop the boat, prolonging your tack by forcing you to sail backwards. I have found that you are better served by releasing the jib as soon as it wants to travel around the mast, then trim it on the new tack for power, not as tight as you would have it for close-hauled course at full speed. You may want to easy the main a considerable bit just after you come head-to-wind. I found that about 6’ was the right amount of sheet to let out on the Hobie 16. I believe this is important because of the change in apparent wind as my boat came through head-to-wind. It was going so much slower, although still moving forward, that if your main sheet is full on you couldn’t get down to the new tack and if you did the acceleration was slow because the top of the sail was over trimmed, way stalled!
You noted a difference between 10 and 15. It might be the wave state. Even with our dagger board boat, n6.0, in waves, big waves, we end up sailing backwards sometimes when I pick the wrong time to tack in a set of waves or the jib is cleated on the old tack for second to long. Also, any time attempting to bring the jib to the new tack side to early always, always stop us! Also, with the n6.0, I easy about a foot or so of main sheet after head-to-wind. When the wind is blowing 15, the backed jib may be stopping you much more effectively then when its only blowing 10.
(*) Your wind range with relatively flat water. I recently had two different crew on board for a race. One of them backed the jib once very appropriately during a race. The other tried to back the jib on the first few tack with my response being “Please don’t back the jib.” I think I said please the first couple of times.
Posted By: Danno
Re: The 2-Minute Tack - 06/27/05 03:10 PM
Thanks, everybody :-)
Even though I'm cutting my teeth, it sounds like you folks sometimes stop during a turn too. Makes me feel a bit better.
Some clarification:
I pretty much ignore letting out the main until I'm on the new tack. If successful, I don't try to sail close hauled until I've got a bit of speed.
The only time I backwind the jib is when I'm stopped, not before. I unleat the jib, hold it tight until it starts luffing, then pull it tight and cleat it on the opposite side. Most the time it doesn't fill on the new tack because the boat doesn't turn that far. I do stay on the old side until the jib fills on the new side.
One thing about the jib: I'm not sure how tight to set it, so I just pull it sorta tight.
Sounds like I need to experiment with how fast to turn and keep my weight back.
Thanks so much,
Danno
Re: The 2-Minute Tack - 06/27/05 04:05 PM
Danno, I would really recommend you to give the mainsheet about 40cm of slack when the jib wants to cross over. Keeping the main sheeted all the time is a big "no-no" when tacking (unless you want to park the boat of course)
Posted By: jollyrodgers
Re: The 2-Minute Tack - 06/27/05 09:43 PM
if it's taking you 2 minutes to tack in 15 mph winds, maybe you should just plan on a backtack.
on a h14 it's normal proceedure in big waves and wind.
just get head to wind and reverse the rudders w/ the sails backwinded. once you are backing up it only takes a second for the bows to swing around then you are of once sheeted in on the new tack.
just getting head to wind can be a problem if it's really rough, so there is no shame in a planned backtack.
Posted By: Danno
Re: The 2-Minute Tack - 06/28/05 01:41 AM
Thanks, Rolf and JR.
Rolf:
I'll try letting out the main as you said. I know that's what you're supposed to do when you tack. My view is that the boat stops before there's any wind filling the sail. Or if it does fill with wind, then I should be well into the new tack and could let it out then.
JR:
Thanks for another idea.
Danno
Posted By: Timbo
Re: The 2-Minute Tack - 06/28/05 02:15 AM
Since you are not racing, why not do the fun and easy thing, go for a gybe instead of a tack? You just bear off, ease the main way out, get some speed and complete the turn, flip the jib over, trim in the main and off you go.
If you must tack, make sure you keep the tiller hard over until the bows are way off the wind and the main is eased out quite a bit, get the jib over and in asap to help get the bows down, don't trim in the main until you have some speed to steer with or it will round right back up and you will be parked again, but when that happens, you just reverse the rudders so the sterns go the other way, then again, ease the main and get some speed up on the new tack before you trim it in.
Posted By: RickWhite
Re: The 2-Minute Tack - 06/28/05 12:50 PM
Since you do have the video on roll tacking, you might want to review it again. It sounds like you are not turning the rudders hard enough. That and not releasing the mainsheet when head to wind. Both of these are major errors that will get you head to wind and stop.
Review: You must be sailing close-hauled with main tight. Start your turn with steadily increasing pressure on the helm (If you jam it over, it will stop the boat; if you steer to easily, you will blow off all your speed before you make it through the turn)
And with the mainsheet tight, you are using the tight leech of the main to weathervane your turn into the wind. You must then release the mainsheet a foot or two when you go through the eye of the wind. That eases the leech of the sail -- otherwise it will want to continue weathervaning directly into the wind. That also allows the mast to straighten, making the sail fuller -- this is akin to a race car driver shifting down into 2nd gear from high when going through a tight turn. By easing the main sheet, you are making the sail fuller and more powerful to come out of the turn.
Hope this helps. If not go watch the video some more.
Good luck,
Rick
Posted By: Anonymous
Re: The 2-Minute Tack - 06/28/05 12:59 PM
Hey speaking of the video, didn't Tim tell us the DVD version would be out in April or May. What's the latest on that?
Mark.
Posted By: Andinista
Re: The 2-Minute Tack - 06/28/05 01:18 PM
I'm not very good at tacking correctly, but the wrong way always works for me: I uncleat the jib late, after it has filled on the other side and helped the boat to cross the wind direction. It doesn´t take long, so the boat won´t reverse direction.
I think I read this on the Prindle 16 manual, so it´s probably not so wrong
I don´t race though..
Posted By: Danno
Re: The 2-Minute Tack - 06/28/05 01:56 PM
Thanks, again, guys!
The video I have is 'total boat handling'. Does the 'upwind sailing' cover tacking single-handed?
Posted By: Jake
Re: The 2-Minute Tack - 06/28/05 03:14 PM
Andinista,
That is probably some good advice until the rudder problems are ironed out. Leaving the jib cleated on the wrong side will help to turn the bows through the wind - but it makes for a very slow tack and reduces boat speed dramatically.
Re: The 2-Minute Tack - 06/28/05 06:19 PM
That's why I said I don´t race...
It always works, so I use this method if things are complicated or if I feel too lazy..
But I´ll try the advices on this post, I wasn´t paying attention on easing the main (except for reverse direction turns). Didn´t think about moving the weight back either.
Re: The 2-Minute Tack - 06/28/05 06:30 PM
On the DVD of all 5 videos, Tim was a bit delayed with a project on his real job. He working on it now.
The Upwind and Roll Tacking video goes much more in depth on how to tack fast.
And YES, backwinding does stop the boat. Racing sailors don't want the boat to stop.., thus the reason we developed this roll-tacking procedure that truely works. The Prindle Manual was probably written before the development of the cat roll tack.
And yes it works great for uni-rigs.
Rick
© 2024 Catsailor.com Forums
