Catsailor.com solcat 18 traps
Posted By: AzCat solcat 18 traps - 03/29/06 06:58 AM
I started sailing on a hobie 16 20 years ago and havent sailed for at least 12 years. Just aquired a solcat 18 that I am rebuilding as it was in pretty rough shape and I have some questions for anyone that can help.
1)The wheels that the bungees run over that flip up the rudders are shot and I need to remove the pin that holds them in to replace them. How do I remove the pin?
2)I have ordered a new tramp from saltydog and would like to know how traps should be set up. Does the tramp need anything special installed at the factory?
3) Do I need to pull the end caps from the frame to install the new tramp? I cant get whats left of the old tramp out of the track without pulling the caps it seems. If so, do I need to drill out the rivets in the crossbeam and/or pull the mounting bolt?
4)I will be using a righting bag but have never used one before. Where is the best place to attach it, what size line,blocks,lengths, other particulars.
5)I have set my trailer with a winch set high on the mast dolly. when singlehandedly stepping the mast the side stays are slack so the mast can swing to the side. I experimented a little and ended up using the jib sheet attached to the sidestays to pull them tight and thus keep the mast centered. Is thisn right or is nthere a better way?
6) Foot straps. It seems like a great idea, but I dont want to get them in the wrong positions. Anyone have them and if so, measured positions? I read the thread but it is on a hobis 16- mine is a solcat 18.
7) The daggerboards seem like they will push right through the hulls. Just push them down flush and forget? Also, I have read the term " dolphin striker". Does this refer to the daggerboards?
8) I liked the rudder/tiller setup on the Hobie 16. Will this, or a similar setup bolt up to my solcat?
Thank you in advance for the hours of your precious time that you all will be devoting to ansewering these questons.I hope that I wont be the only one to benifit from your timely responce.
Posted By: fin. Re: solcat 18 traps - 03/29/06 11:46 AM
I know nothing about Solcats.
However, the "dolphin striker" keeps the forward crossbar from breaking. It is the rod and cable mechanism located directly under the mast step. The rod is probably attached to the mast step.
I don't use anything to help raise the mast, just "muscle". But, I'm short and stocky. I've seen taller guys who are obviously stronger, struggle a bit because they can't get under the mast. I saw a guy put a light bungee around the shrouds, but can't say that I recommend it. The safest way would be to get help raising and lowering, lots of guys do it.
Posted By: Andinista Re: solcat 18 traps - 03/29/06 01:04 PM
To keep the mast straight you can attach the trapeze wires to both ends of the cross beam (I don´t know the solcat but I think it should work)
Posted By: jmhoying Re: solcat 18 traps - 03/29/06 03:07 PM
Like the other poster mentioned, connecting the trapeze wires to the front corner castings is the best way to prevent the mast from swinging side to side while raising it. Here's a photo of my P18 mast going up.
Another photo -
http://www.pbase.com/jmhoying/image/38984007Good luck with your new boat.
Jack
Posted By: AzCat Re: solcat 18 traps - 03/30/06 06:15 AM
Also, I have noticed that most of the 18' and up cats have diamond wires on the mast. Mine is an older cat and dosnt have this. Is it a good idean to have this? If so can I just order one for a hobie or nacra off salty dog ind it will work? I dont see one for a solcat 18 on their website.
HEY, IS THERE ANYONE IN ARIZONA WITH A CAT THAT I CAN RUN WITH? Im in Glendale.
When I had a Hobie 16 I put the mast up singlehanded a few times by lugging it into place by hand, dont want to do that any more, it hurts. I am more into easy these days.
The winch does the lifting just fine, I just need to keep the mast strait. The jib sheets worked ok but maby there is a better way. Thanks for the input.
Posted By: PTP Re: solcat 18 traps - 03/30/06 06:18 AM
if there were no diamond wires originally, I am not sure of any reason why you would have to add them.
Posted By: basketcase Re: solcat 18 traps - 03/30/06 05:09 PM
Just your luck. Check out
www.fleet42.com AND
www.azcatsailor.com AND
www.fleet66.com (hobie fleet). There is a fun sailing weekend next weekend at Lake Roosevelt. The fleet is going to Rocky Point towards the end of April also.
About the solcat 18. I used to own one here in the valley. It was white, with red and black sails. I thought there was a blue one floating around the valley too. I never did get the trap wires hooked up on that boat though, so I cant help you there. I dont think you need to removed the end caps to get the tramp off. I think if you look at the endcaps, they should have a groove in them to get the tramp off. It might only be on one side. Maybe bring the boat next weekend to the lake, even if it is not ready for sailing. I dont know if I will be there, but there will be plenty of people with the knowledge to help you out, give you some ideas, and get you going in the right direction.
Jonathan Grant
Mesa, AZ
boatless
Posted By: ReefedOne Re: solcat 18 traps - 03/31/06 06:51 AM
azcat, sounds like the locals are ready to help, if you can trailer the "patient" (or parts of it) out to the lake. Kudos for cat spirit!
I don't know the SolCat at all, but I do have a cool sales poster from them, early 1980s vintage. They have pretty distinctive looking hulls, and someday I will take a trip to see one:
http://www.boatlinks.com/image.asp?ObjectID=10181Is Sol Cat the one where the tiller crossbar is in FRONT of the mainsheet blocks, so you don't have to throw the hiking stick 'round the back of the boat when tacking and jibing?... or was that the G-cat????
But Solcat has a flush-mounted tramp similar to the Prindles I've had, so I'll try and help you out....
1)The wheels that the bungees run over that flip up the rudders are shot and I need to remove the pin that holds them in to replace them. How do I remove the pin?Not sure... are the ENDS of the sheave pins visible/accessible? If like the Prindle, you may have to remove the sub-assembly from the rudder castings in order to access/change the sheaves (roller wheels). Probably there is no drilling or torching involved, maybe just a centerpunch and small hammer.
2)I have ordered a new tramp from saltydog and would like to know how traps should be set up. Does the tramp need anything special installed at the factory?Out near the side edges of the tramp, up near the shrouds (side stays), Prindles have grommeted holes for the trapeze shock cords to ride through. One pair of holes (for the skipper) is approx. 6-8 inches behind the shrouds, the other pair (for the crew) is about 6-8 inches in front of shrouds. Do you see something like this on your OLD tramp? If saltydog knows the SolCat, they probably know to do this... but hey, why not call and MAKE SURE!?!? ;')
On the Prindle, just outboard of these grommets, you tie on a small "block" (pulley) for the shock cords to ride through. (Go to
www.performancecat.com and download the Prindle 15/16/18 Owner's manual for pics.)
3) Do I need to pull the end caps from the frame to install the new tramp? I cant get whats left of the old tramp out of the track without pulling the caps it seems. If so, do I need to drill out the rivets in the crossbeam and/or pull the mounting bolt?As stated by the previous poster, I'd be VERY surprised if such major surgery was required to swap out the tramp. As he said, if one end is blocked, check the other end. If BOTH ends appear blocked, then perhaps there's a "feed slot" towards one end or the other, i.e. a short stretch where the curf (groove) gets wider, as on the mast where you feed in the luff of the mainsail...? Also look UNDERNEATH for some feature of the crossbars that leads to tramp removal... removable plate?... can't believe there'd be riveting involved.
4)I will be using a righting bag but have never used one before. Where is the best place to attach it, what size line,blocks,lengths, other particulars.On Prindles, there's a grommet dead center on the tramp, just aft of the mast. They say to drop the righting line through there, and just tie a figure-8, and let it pull on the tramp. I've never liked putting that much stress on the tramp, so after passing it thru that grommet, I tied it off to the center post of the dolphin striker, which is a strong structural member.
As for line, a length of beefy old mainsheet that's too fuzzy to run through the blocks works great. I wouldn't go smaller than 3/8". That cheap poly ski rope that comes with the Murray's basic bucket ain't worth shyt! It will decay in no time. Length will have to be at least 13-15' to go up, over, and reach the water. In time you will find the magic spot to tie a loop for your hand-hold, and maybe another loop for your trap harness hook.
You take up the slack by hoisting the bag over your shoulder, and running the slack under your harness hook... then just lean back as when trapezing... if bows are into wind, wind will get under sail, and boat will roll back up... slowly at first, until sail clears water, then SCHWING!
Hopefully SaltyDog included a big pocket on the tramp to stash your righting line + rolled bucket... if not, just wrap the whole mess around one of the side V-bars of the dolphin striker, in a way that's secure, but quick to deploy, e.g. half-hitches, bungees, etc.
5)I have set my trailer with a winch set high on the mast dolly. when singlehandedly stepping the mast the side stays are slack so the mast can swing to the side. I experimented a little and ended up using the jib sheet attached to the sidestays to pull them tight and thus keep the mast centered. Is thisn right or is nthere a better way?Sounds good. Jib sheets and blocks are strong enough to do the job.
6) Foot straps. It seems like a great idea, but I dont want to get them in the wrong positions...On lakes I've never needed foot straps... ocean, 'nother story... you need to sail the beast a few times before you decide on foot straps... non-skid material from stern to front crossbar is probably more useful. Also, footstraps (boardsailing type) can be DANGEROUS, e.g. if you do a wicked PITCHPOLE, it's better to take a wild ride 'round the forestay and go "SPLASH", than to have your leg ripped off at the knee, eh?
You need something like snow-ski bindings, that release before your bones snap.
If you wear some kind of booties/aqua-socks with good traction soles (and you should), then you will probably only need--at most--1 foot strap on each side, and that's way in the back/stern, behind the rear crossbar... and you may want it mounted at a 45-degree angle. That's because that's where you'll be trapezing when you're far off the wind (broad-reaching), and the force-vector of the sail is well forward, and trying to push your bow(s) under. Your bows plowing under is really the only "braking" action that's going to produce negative (forward) G-forces that would pull you off your feet.
When sailing close to the wind, you'll be trapezing up near the front crossbar, trying to hold the bows down, keeping too much wind from getting under the tramp. You'll be even with where the trap wire is strung, no footstraps needed.
7) The daggerboards seem like they will push right through the hulls. Just push them down flush and forget?NO WAY! If they're down flush, how will you PULL THEM UP? They should at least have holes near the top for thick rope handles, and maybe another hole for rubber stoppers...? Thick rope will prevent over-insertion. There may also be a gasket down in the board slot to keep water from spraying up through gaps...?
8) I liked the rudder/tiller setup on the Hobie 16. Will this, or a similar setup bolt up to my solcat?Doubt it. At minimum you'd probably have to drill new holes to replace one or both gudgeons on each side. OTOH, there's lots of busted-up Hobies out there, whose owners are parting them out. You're not far from So-Cal, and the ocean breaks up a lot of Hobie hulls... watch the web.
Posted By: ReefedOne Re: solcat 18 traps - 03/31/06 06:58 AM
PS: If your mast doesn't have diamond wires, it's because it doesn't NEED them... be HAPPY, much less hassle, and one less thing to poke through your new tramp when trailering.
Posted By: Dean Re: solcat 18 traps - 04/01/06 03:23 AM
Hi, Azcat,
I owned a Sol 18 for a number of years and can answer all your questions. I have some photos that I will e-mail to you and will also send many e-mails that I've sent to restorers of the Sol 18's during the past couple of years.
Aftermarket tramps will slide onto the boat via a bolt rope on the hulls. The tramp is a lace-up with lacing amidship. I have a photo. Endcaps removal? No. The boltrope on the each of the two halves slides into the aluminum guide along the inboard gunwale of each hull. A photo will follow.
I weighed 130 lbs when I was sailing the boat. It was a lot of boat for a small skipper but I didn't have trouble righting it by myself without any aids. I did it by swimming the tip of the mast into the wind. Then held onto a righting line attached to the hull while I leaned out as far as I could while standing on the hull in the water. Seal your mast caps and all the rivets with Goop/silicone. It always came up, eventually.
I stepped the mast with a winch mounted on the trailer. Tie the mast down near the step with some line in case it wants to jump off the ball during stepping. The mast did go side-to-side a little but no so much as to stop the stepping. I think I raised it with the main halyard and then pinned the forestay to the adjuster.
My boat was double-trapped. I didn't use footstraps. Too scary. It seemed like a great opportunity to break your ankles. I rigged a "chicken line" and barefooted it on the hull while out on the wire. This was back in the late '70's-early '80's. That's what we did back then. We were indestructable.
The daggerboards will get stuck about two inches into the hull. Rig a shock cord line through a hole in the top of the board to keep them semi-secured. They may slip down into the dagger well a couple of inches before they stop. Those are Nacra 5.2 boards.
The rudders setup and the auto release worked well. I never had a problem but I kept them adjusted properly. I may have a photo close enough to show them.
The dolphin striker is below the foward beam. On the 18 it the vertical rod, threaded on one end, was connected by horizontal aluminum flatbar, about 1/4" thick x 2" wide, extending from hull to hull. It dipped down at an angle to connect to the rod about 6" below the forward beam.
The 18 does have diamond wires and the boat needs them. I'll send photos to you.
I loved that boat. It was durable, fast, and terminally cool...until the Nacra 5.2 came along.
Check back to re-read this same post this weekend. I may do some editing for accuracy. Send me your e-mail and I'll zip the photos to you.
Posted By: AzCat Re: solcat 18 traps - 04/01/06 09:10 AM
Thanks guys for your posts,
The bolt ropes wont pull out past the end caps dispite grabbing them with a pliers and pulling like a madman.
Whats a chicken line.
The rudders have a shock cord running down thru the tube, over the sheave and down thru a hole in the back of the rudder. when loose, the chord pulls the rudder up.
To hold them down, there is a 1/4" line running from the front side of the rudder, up over a sheave, and to the front of the tube thru a clam cleat.
It seems to me that if I run acriss anything in the water or run aground and cant release the clam cleats in time its going to bust up my rudders pretty good, or rip them off the stern. I had a H16 25 years ago and the cam release worked great, although I was sailing off north carolina mostley and when the jellyfish were swarming and the rudders would strike them they would kick up a little too often. Is there a better way to hold down the rudders than a clam cleat?
I tried to pop out the pins that hold in these sheaves using a punch and they didnt budge. I stopped because I didnt want to break anything. I fugured I better get some response before brating the crap out of my boat. It looks like this has to be the way to remove the sheaves and pins. I guess I'll try it again. Im sure the pins havent moved since 78 when the boat was built, they'll be a little tight.
The diamond wires. Do they help produce more power? I understand that they keep the mast from bending. How does this help performance? Is this an off the shelf, universal item that I can buy and just bolt on?
Quick shout to all those AZ catters. I dont think that I can make it to rosevelt this weekend. Im having some problems getting my trailer registered. The previous owner didnt register it properly and there are no vin #'s on it so I have to get a bonded title next week. If anyone knows where I can get a decent trailer cheap, I am interested. Even just a frame with a bad axle. This one is chopped up and rigged together but I have replaced everything on it to make it usable. The registration is the biggest glitch.
You guys have a great time out there. A few more parts and i'll look you guys up. Im the yellow solcat.
Posted By: Dean Re: solcat 18 traps - 04/01/06 02:51 PM
The cleat on the stock boat was not a clam cleat. It was a cast aluminum part that was hinged with a pin on the stern end of the part. When the rudder hit something, this part would pop outboard and would pivot on it's pin to allow the release of the cord to the back of the rudder. It sounds like that part was replaced with clam cleats on your boat. The original parts would have looked like clam cleats but without the grooves for grabbing the line. Is that what you have on the boat?
A chicken line was a rope that was tied, mine was eye-spliced, around the aft beam near the cap and extended forward toward the end caps on the forward beam. The forward end of the line was tied to shock cord. The cord ran through the forward beam to connect the forward ends of the chicken line on each side. While out in the trap if you started to dig the bows or began to go flying toward the mast, there was a chance that you could grab the chicken line to arrest your flight forward.
Murrays.com might have the diamond wires or contact
pcat@performancecat.com for the specs of the original wires. The wires are there to simply hold the mast up. They can be made by a decent rigging shop if you have the dimensions of what you need. West Marine's specialty riggers are located in N.C., I believe.
My Sol 18 was yellow. I bought it in New Orleans.
I tried to upload photos last night but my page space may be full. Send me a note to my e-mail:
deanhubb@yahoo.com Posted By: ReefedOne Re: solcat 18 traps - 04/04/06 12:26 AM
AZ, I knew a real Solcatter would show up eventually. Sorry about the bad advice on the diamond wires, but in the huge photo I posted a link to, there are none. Upon closer inspection you can see the lower attach points, but I still see no clear marks where the missing spreaders attached...?
About the TRAMP: Saw a closeup pic on a Sol 18 that's on Ebay right now. As Dean says its main lacing is down the center, fore-and-aft... this leads me to question whether there's not a feed-slot dead-center on both front and rear crossbeams???? Perhaps Dean can elaborate on that. No doubt SaltyDog can set you straight on the order and method of install. Hopefully they include the correct lines for lacing too.
PS: On the Ebay photos, it looks like there's a pole running beneath the full length of the center tramp lacing gap... did Solcat come with a built-in righting pole? Or is that some aftermarket device? Am I seeing things? Go to Ebay Motors-->other vehicles-->boats-->Sailboats-->Sailboats under 20'... and check it out.
Edit: here it is...
Sol 18 on Ebay Posted By: AzCat Re: solcat 18 traps - 04/04/06 05:48 AM
OK. I thinknI have the tramps figured out. I talked to salty, tramps should be here in about a week, any further problems, i'll let you know.
I am in the process of ordering trap gear and am unclear as to exactly what I need. I am ordering 4 trap line sand two shocks but do I need two or four dog bones? I have also seen the chrome bones and cable bones, any thoughts on preference? Also, thoughts on double adjusting setups. It looks like a it would work great. Is this something I need?
Thanks for the posts RE rudders. I havnt yet figured out a good solution other than getting a rudder release system off another type of boat and doing some fancy re-rigging has anyone had to do similar?
Thanks for all the help. It wont be long before im on the water, wont sleep well till I am.
Great wind
Posted By: ReefedOne Re: solcat 18 traps - 04/05/06 10:20 AM
OK, so what's the secret of the tramp vs. front crossbar slot? The suspense is killin' me. Gotta say though, the more pics I see of Solcats, the more I like them. Someday I will give my cool, rather large Solcat poster to an owner who takes me out for some hull-flying.
Did you look at the Ebay pics? Is that just the boom that's under the center tramp lacing during trailering, a righting pole, er whut?
DOGBONES: You need 4 total, 2 on each side. Never used the cable kind; seems like they might be a bit springy/stretchy...? I have seen them on serious racing rigs, and with that "can't miss" type, you always have a handle in the same place, regardless of how long your rope tail is. I guess at $100 for a set of four, they'd better be AMAZING in some regard! Maybe it's just snob appeal, LOL. (If you had a swaging tool, you could make your own "can't hurt" or "can't miss" cable type bones for what, $1.21 in parts?)
I recommend the solid ELONGATED stainless bones, part #25-3620 on p. 48 of the current Murrays catalog. They orient correctly in your hand, and I have no trouble hooking up that huge loop without looking.
Strangely enough, those elongated bones are cheaper than the crappy old-fashioned original Hobie type chrome ones with just a small hard-to-hook cirle at each end, and a single skinny hard-to-grab hard-to-orient connector in between. AVOID THOSE.
Double-adjuster setups? 99.9% of people live without them, even racers. At most you would need them only on the rear traps, so the skipper could get low off the rear crossbar. Still, I may rig my own someday.
The good kind that keeps the T-handle close requires you to have your original wires shortened. Another good reason to meet up with the local fleet guys, and try out their various rigs first.
You already have daggerboards and diamond wires to deal with, plus your problem rudders. If you want to get out on the water, keep the other gear simple, for now. GOOD LUCK, post pics!
Posted By: hobie1616 Re: solcat 18 traps - 04/05/06 03:27 PM
I really have to disagree with the use of dog bones of any type. Those things will beat your head or break out teeth. Go with either the cable type handles or the balls. There’s been a lot of discussion in the Sailing Injuries thread about what’s the safest. The ball type seems to be getting the most thumbs up.
Posted By: Dean Re: solcat 18 traps - 04/06/06 02:56 PM
I used the long dog bones back then but I would go with a more modern and safe design, today.
Posted By: Mary Re: solcat 18 traps - 04/06/06 05:54 PM
What do you mean by "cable-type"? Are you talking about the plastic-coated, round ring with the little bar across the middle? If so, they are safer if you get hit in the face, but they can also break. They distort and get pulled out of shape, and because of this bending or "crimping" action, the cable can eventually break at the point where the hook attaches to the bottom of the ring. So if you use them a lot, they should be replaced occasionally when they develop that elongated, distorted shape.
Rick made an unexpected departure from our boat at least once, maybe twice, because of the ring breaking. We switched to stainless steel.
Posted By: hobie1616 Re: solcat 18 traps - 04/06/06 07:20 PM
The first set I used lasted for eleven years. They went with the boat when I sold it. The second set lasted for ten years. They went with the boat to the Boy Scouts.
Posted By: ReefedOne Re: solcat 18 traps - 04/08/06 07:46 AM
RE: pricing on "Can't Miss" cable bones... MY BAD, they're $50 for 4, not $100... vs. $32 for 4 on the indestructable stainless ones I recommended... not sure how those light stainless bones are gonna knock any teeth or lights out? If I'm sitting that close, or it's that rough, I hook up. Otherwise the shockcords keep them out of harm's way.
Anyway, good advice here on trap systems, but I'm assuming our man azcat inherited old hook style harnesses with his boat, and just wants to get out on the water for minimum $$...
Interesting debate 'tween Mary and 1616 on "Can't Miss" bones... seems 1616 got much more life span out of them than Mary... wonder what his usage/storage/crew weight numbers are?
Seems to me the plastic grab handle is under COMPRESSION, and is the weak part of the concept. I wonder what the UV resistance of that plastic handle is?
PS: While the ball and socket is snag-free when NOT trapezing, aren't you usually hooked up during wicked pitchpoles? And doesn't the tension of flying 'round the forestay usually KEEP you hooked up? If you're underneath the boat, you still have to unhook the ball from the socket.
... I solve the problem w/ the excellent ol' Matson Quick-Release buckle... nice.
Posted By: hobie1616 Re: solcat 18 traps - 04/08/06 05:58 PM
Useage - Sailed my a** off
Storage - Religious use of tarp
Weight - S 175/C 80 to 130
Posted By: ReefedOne Re: solcat 18 traps - 04/08/06 11:39 PM
So tarp usage implies rigging (incl. bones) are coiled under tarp. (I had a nice lakeside setup once where the mast stayed up, but of course rigging was outside my tramp tarp...)
Well, I look forward to specifics from Mary. Certainly we can't dismiss her and Rick White as being in the "don't know what they're doing" cat-egory, eh?
Besides, I'm not sure I could LIVE without that positive metal-on-metal "clink-thump" feedback when I hook-on... LOL.
Posted By: John_C Re: solcat 18 traps - 04/09/06 02:20 AM
I'm curious about your Sol Cat 18. It has been years since our club owned one, but I didn't remember diamonds on it or on one that someone I knew owns. Here are some links to pictures of Sol Cat 18s on the web that don't have diamonds either. Is it possible that your boat has been modified or did they ever change the design?
http://www.animatedknots.com/indexb...og.jpg&Website=www.animatedknots.comhttp://www.sailboatshopaustin.com/usedsailboats.htmlhttp://www.sailingtexas.com/ssolcat18a.html John Courter
Posted By: John_C Re: solcat 18 traps - 04/09/06 02:42 AM
I was trying to ask Dean about the diamond wires in my previous post.
I need to figure out how to do replies better.
I just noticed in Dean's second post about the diamond wires just holding the mast up. Could you be referring to the shrouds? Diamond wires are to keep the mast from going too far out of column.
In reply to Reefed One about the pole in the middle, there is a support beam running fore and aft in the middle of the boat. I don't know if it was to try to stabilize the frame or hold the tramp up.
John Courter
Posted By: Mary Re: solcat 18 traps - 04/09/06 04:13 PM
Well, I have talked to Rick (a rare occasion
), and he has revived my memory, since I haven't crewed with him for at least 13 years. I am half wrong. He says he has continued to prefer the circular cable trapeze rings to this day. Even after one broke on him, he continued to use them but replaced them every two years or when they got too deformed (bent out of shape), whichever comes first.
It was I who went to the metal rings, because, as crew, I wanted the option of being able to hook into the lower ring or the upper ring, depending upon the sailing conditions. My preference was a ring that was kind of fat and elliptical, with a small round ring at the top of it, so I could hook into either.
I also tried various adjustment systems for trapezing height, but I still liked the option of being able to hook into the lower or upper ring, especially when conditions were stable and one or the other would work best. I never really trusted those cleats on the adjustable systems.
Anyway, the skipper doesn't really need as much adjustability for his trapeze, because he doesn't go anywhere. He is stuck in the same spot. Rick just sets his height adjustment and leaves it.
The crew has to be sometimes all over the place, moving fore and aft for proper weight distribution, and needs to have more adjustability for their trapeze.
As far as the dangers of being hit in the face with a trapeze ring, in our case it was always the crew's fault. In the conditions we always sailed in up in the Midwest, the winds would be light-to-moderate, and shifty and gusty. So the crew always had to be hooked to the trapeze and ready to go out. So the wind is light and I am up on the bow, lying down, but hooked in to the trapeze, just in case I have to go out instantaneously. Skipper is also forward, right behind the main beam. I make a mistake of turning my body a little bit the wrong way, and the trapeze ring slips off my hook and, "BOIING," it flies back and hits my skipper in the face. Not good for crew-skipper relationships.
Posted By: hobie1616 Re: solcat 18 traps - 04/09/06 07:26 PM
Any indication why it failed? Bad swage, corrosion?
That’s why I haven’t used them for over twenty years! They were the first things to replace on both of my H16s. The 20 came with the cable handles. Thanks Hobie!!
Posted By: ReefedOne Re: solcat 18 traps - 04/09/06 08:19 PM
I'll put Mary down as another happy user of the stainless elongated bones. Such a vast improvement over the Hobie originals.
Cable bones, aka "Can't Miss" handles... hopefully I'll have the chance to try some while crewing on someone's boat in the next few weeks... (too much LIGHTNING this Sunday!) In general, the thrifty Scotsman in me looks askance at dogbones that have to be trashed every 2 seasons.
I just noticed in Dean's second post about the diamond wires just holding the mast up. Could you be referring to the shrouds? Diamond wires are to keep the mast from going too far out of column. Exactly, I had the same reservations, but having NO experience with Solcats, I had to defer. The grainy photos were ambiguous.
In reply to Reefed One about the pole in the middle, there is a support beam running fore and aft in the middle of the boat. I don't know if it was to try to stabilize the frame or hold the tramp up.Wow, looks like a real KNEE-BREAKER. The mfrs. must know something about the weakness of the hulls/decks to include such a structural member... hmmm... I'd thought just maybe it was the first production cat to include a built-in righting pole!
Posted By: Mary Re: solcat 18 traps - 04/09/06 08:27 PM
Sorry, but we did not do an autopsy on it.
Rick's memory about it is very vague -- it was 20 years ago. He says part of it also had to do with the handle crossbar in the middle of the ring bending, which allowed the ring to deform even more, prior to the failure.
I did not know there was a swage involved. If so, I already knew that I don't trust swages for other reasons, and if that happened to be at the point where the trapeze hook attaches, I would trust it even less.
But, then, I don't trust any of the many components of a trapeze system between the mast and me.
Posted By: hobie1616 Re: solcat 18 traps - 04/09/06 09:11 PM
No guts no glory!
It does pay to inspect the rigging and trap lines for wear, loose fittings and corrosion on a regular basis.
Posted By: Mary Re: solcat 18 traps - 04/09/06 10:18 PM
For sure.
Posted By: sparky Re: solcat 18 traps - 04/10/06 01:47 PM
In the Nacra 18 Square I had in the 80's, these fore and aft tubes were used to prevent rotation of the front and ream beams. Later, Nacra was able to eliminate the tubes (on the N5.2) by putting fittings inside the end of the beams that screwed into the hull and prevented rotation of the beam. I don't know about the Sol Cat, but this might have been the reason for the fore and aft tube, just like it was on early Nacras.
Posted By: AzCat Re: solcat 18 traps - 04/11/06 12:47 AM
I just lost my new post so im going to make this brief
Bolt ropes wont come out through the channel in the end cap, Ill just open the hole up a little with a stepped drill bit and a rotozip.
If diamond wires are needed I'll install them at a later date. My question was to weather they are added to increase the efficiency of the mast. Probably so.
Dean, thanks for the post on the rudder releases. Upon more informed inspection, I discovered that one of the original releases is still intact. I definately would'nt have noticed this without the info. Now I just have to fogure out how to make another one for the one thats missing. Possibly a peice of thinwall ABS. I'll figure out something now that I have something to work with. I would still like to replace the wheels that the ropes pass over but hav'nt figured out how to remove the pins without damaging the castings.
The pole down the middle of the tramp does seem like an ancle and knee buster. Im thinking of padding that with some foam or something if possible.
I think i'd like to put a Hobie bob on top of the mast. Anyone know if the bob will fit or not? I'll goop it up good but would still like the extra security.
I think that in a couple weeks I'll have all the parts on the boat and this week I'll get the trailer registered.
I hav'nt even gotten out on the water yet and the wife is already getting jeious of the time im spending with the boat.LOL
Posted By: ReefedOne Re: solcat 18 traps - 04/11/06 12:51 AM
Ahh so... guess the decks were initially not thick enough to do that, a la Prindle. Always wondered how Nacra's strapped down ROUND crossbeams were "keyed" into the deck.
I'm guessing you quickly get used to "stepping" over the bar on your hands and knees... or while "skooching" over on your buns, lol.
I've found your lengthy feedback on my 18 sq queries over in the F-18 forum, and thank you profusely... this boat seems to have seized me recently, with such intensity that I fear the only sure cure is to purchase one... at least one.
Just a question of how many states I'll have to drive across...
Posted By: ReefedOne Re: solcat 18 traps - 04/11/06 02:01 AM
D'OH!... I simultaneously posted w/ our man azcat. ("He's a Sol man..." (*brass solo*) "He's a So-o-ol MAY-en..." (*twangy guitar solo*)... lol.
az, take a deep breath before you fire up that drill, bro!
Does this problem exist on both the front and rear crossbeams? Perhaps some fine needle-nose pliers might be able to start the apparently swollen old bolt-ropes on their way out of the slot? Can you post some digital pics of the problem tramp and endcaps?
At least wait until your NEW tramp is in hand--that properly-made pup might answer a LOT of questions.Help me out here: How does the tramp attach along the SIDES, to those hull-rails? Does it lace on? Clamp with screws? Slide DOWN after you slide it OVER on the crossbeam? Looks like the new tramps are 3 pieces: left-front-main, right-front-main, and a narrow strip spanning the rear crossbeam, which provides your fore-aft tension.
Here's the ebay fancy painted one again... look familiar?
Posted By: Dean Re: solcat 18 traps - 04/12/06 08:42 PM
John Courter
Well, that's what I get for trying to think about fun while I'm at work. The SolCat18 did not have diamond wires. I was trying to describe the forestay which was led to a stay adjuster located on a bridle.
Also, I can add some info to the rudder release. The stock rudder release was a clamcleat looking thing and was cast aluminum. What I should have mentioned is that the piece, when "cleated", fit into a stainless clip, shaped similar to a C section, but pinched to grab the piece along it's length on it's edge. The stainless clip had enough grip on it to keep the cast piece in place until the rudder hit something. Then, the cast piece would pivot out on it's pin to release the tension on the shock cord to the rudder. There was a handle on a stainless cable, secured by a ball swaged to the cable, that you pulled on to pull the cast piece into the stainless clip to lock the release. To release the rudder normally, you would grab the handle, pull it outboard to pull the cast piece out of the stainless clip.
How can I remember this from thirty years ago but can't remember what my wife said last night?
Don't answer that.
That pole amidship will keep your shins black and blue and yellow and purple. Learn to avoid it during a tack.
Sorry for the late reply.
Posted By: ReefedOne Re: solcat 18 traps - 04/12/06 09:37 PM
Dean, welcome back! Keep mining your memory banks--you're our best hope for keeping AZ from pounding his head against a wall, lol. Nice looking lines on the Sol 18 hulls... loose-footed, aggressive main with a large modern "roach" area... do you remember who made the Solcats, and where?
Also, where do the shockcords for the traps run? Fore and aft under the outer deck lip? Or underneath the tramp and out through special tubes through the hull? It's not apparent to me from limited pics available. I may have sent azcat looking for grommets in his new tramp which just aren't there... my bad.
PS: In your previous post, did you mean that Sol 18 can/does use NACRA 5.2 daggerboards??
Posted By: ReefedOne Re: solcat 18 traps - 04/12/06 11:55 PM
A little inspiration for azcat... SASSY!...
Posted By: Dean Re: solcat 18 traps - 05/01/06 02:13 PM
Hey. I just got back into town.
I will mine my info in my files at home tonight for the facts.
I know NACRA bought the company around 1978. The Sol 18 soldiered on for a couple of years after that, I think but the 5.2 and the Prindle 18 were hotter sellers.
I can't remember how the traps' the shock cord was routed but I have photos at home that may job my memory.
A few years ago I remember someone posting here that mentioned the 5.2 boards would fit the Sol 18.
You could pull up the daggers if they slipped down in the well to far. There was shockcord in a hole at the forward end of the the top of the board that hooked to a spot on the hull a couple of feet forward of the board well.
Posted By: solcat18 Re: solcat 18 traps - 05/07/06 07:52 AM
Its been a While since I posted so I forgot my password and have been re-encarnated as azcat18.
I just got my tramp from saley dog and have already discovered a couple of additions i'll have to make before installation.
First off there are no grommets for the traps so I guess I'll need to ad them. Sounds like 8"fore and aft of the rear stays should work. Do I need to run the shock chord thru a block? Or just up thru the tramp? I assume that the block is there to keep tension off the tramp. Right?
Hey Dean have you found those picks? If so, could you email them?
Also, the dog bones that I got from salty have a block at the top so i'm wondering if I ordered the wrong ones. It seems that maby I'll have to rig up an adjustable rig to use them. There wasnt a pick on there site but the description sounded right and said nothing about a block on the dogbone. can someone let me know the deal?
I think that these are the challenges at hand. All help is appreciated.
Posted By: davefarmer Re: solcat 18 traps - 05/08/06 05:16 AM
Murrary's carries the Privmatic kick up cleat for your rudders, just requires the proper diamter tubing on your tiller arms, which I suspect you have. I think you want the 7.5" elongated ring (Murray's again) instead of the trap ring with sheave, which is desinged for use with the adjustable system.
dave
Posted By: AzCat Re: solcat 18 traps - 05/17/06 05:18 AM
Got the cat out last weekend, most everything is in good order, had a blast,think that I may have gotten my son and his buddy hooked. AWESOME!!!
One problem, When I tied in the battens on the main, One of the pockets ripped right behind the grommet. I guess there was some sun damage down the trailing edge. so far the rest are holding up.
s there a quick fix for this or do I need to look for another sail?
If i am going to need a new sail, what other cat sails will fit my solcat 18?
Also, if I get new travlers for main and jib do I need to replace tracks also?
How about down haul? is this an option I should install?
The SOL is coming together great. I rebuilt hte trailer also. The first time I buuilt it a little light and it folded up in the middle when I stepped the mast with the winch and then my son(220)his buddy(150) and I (180) jumped on the front of the boat. I beefed it up and I think its solid now. It turnede out pretty good. If I can figure out how,Ill post pics. also am building beach wheels, will also post pics of this if it works out well.
Gotta go watch the Phx Suns game.
Thanks in advance for your help.
One other thing, I think that the best way to run my traps is to drill holesw thru the hull, insert PVC thru,and glue them in. I belive the nacra has this setup.
Opinions and suggestions appreciated.
Posted By: Dean Re: solcat 18 traps - 05/18/06 07:04 PM
[Also, if I get new travlers for main and jib do I need to replace tracks also?]
Only if the new travelers won't fit the old track. I believe a Harken traveler would fit that track.
[How about down haul? is this an option I should install?]
Yeah, there was a downhaul on the boat and you will need it once you start understanding which sail shape to use in different wind speeds. See the photo I sent labled "Sol 18_1.jpg". You can't tell much about it but there is a downhaul there.
You will usually not want to drill holes in a hull any more than you would want to drill holes into your head. Since most of us have a surplus of holes there already, go to Plan "B". There should be a hole in each end cap for routing the bungee. Run the bungee through the forward beam. In that same photo you can see that the bungee is routed from the dogbone through the end cap on the forward crossbeam, through the beam, and out through the cap on the other side to the dogbone. You will need a plastic insert of some sort to place in the end caps so that the bungee doesn't chafe on the hole edges. You will have to drill the rivets out of the end caps in order to remove them.
In the same photo on the port side beam cap you can see the dogbone. It looks like a couple of links of chain just above the end cap. The tension on the bungee has to be only enough to keep the bones in place when not in use which should be enough stretch to make the trip out to the hook on your harness.
Posted By: AzCat Re: solcat 18 traps - 05/23/06 04:53 AM
OK, NEW CHALLENGE!!!
Took the sol out to lake pleasant AZ this weekend, of course had a blast. Winds were off and on, but goodenough to fly a hull solo every time i crossed the lake.
Then came the big gust of wond that knocked me over like right now.
I had flipped her earlier for fun and had no prob righting with two on the righting line but I guess that I missed a couple holes in the top of the mast with the goop and it took on some water so when I flipped for the second time she went turtle within 30 seconds.
When I hit the water, somehow the tramp bolt rope tracks on the hulls popped loose. I think the previous owner had taken her in salt water and the salt corroded the rivets so they just snapped in half. A couple pulled out of the hulls and popped the glass and gelcoat loose around the holes.
Also, got a 6" rip in the sail where it looked like there was some sun damage. this rip is also right next to where one of the batten pockets ripped when I was tying them in.
Whats the best way to repair the hulls and re-attach the boltrope tracks?
Also, will sail tape repair the sail? How long does it last. I think I may just have to buy new sails eventually, but i'd like to get through this summer without doing so.
Also, I have noticed that there are a few holes in the top of the mast withiin about three ft of the tip. The water ran out of these holes when I pulled down the mast. they are pin holes and look like they came from the inside. I think that possibly salt water was left inside the mast for the last 20 yrs and coroded through. Is there any way to prevent further damage? and also, has anyone tried to fill the tip of the mast with expanding foam used to seal up doors and windows? I guess that its possible this is also corrosive or may not be able to dry inside the mast. Maby theres another material that could be used.
Posted By: ReefedOne Re: Expanding foam - 08/13/06 09:41 AM
GREAT idea with the expanding foam in the mast... why have I never heard of it before? Think about it: doesn't add any buoyancy, but does the job of keeping water out of mast, without the added wind drag of a float-bob.
The foam is heavier than air, so you might want to check by how much... ;')
Anyway, I don't think that foam (e.g. 'Great Stuff') is corrosive, as it's used in contact with all kinds of metals, incl. aluminum.
Don't know what to tell you about the bolt-rope tracks, but you seem to be very crafty at keeping the old gal lakeworthy!
Posted By: Jake Re: Expanding foam - 08/13/06 03:38 PM
The expandable foam will absorb water over time (if exposed) and will become very heavy and impossible to remove. It also does take away from the buoyancy by adding material inside the mast (air is pretty much as bouyant as you can get). Remove the existing hardware and reinstall it with 3M 5200 sealant or the like and/or plug up the holes with it. You'll be sorry about the foam in a couple of years.
Posted By: JeffS Re: solcat 18 traps - 08/14/06 09:13 AM
I wouldn't panic too much about the pole down the centre, my previous stingray had one and the block for the mainsheets was attatched to it. If you pad it up you will make a lump that is harder to slide over. You will soon get used to avoiding it if you dont make it any higher. I would take the boat to a club day and let an experienced person look at the beams to see if you can do away with the centre pole, everybody that looked at mine said I could do it no problem I just needed a combined main sheet block and traveller. The only advantage it gives you is when your stepping your mast it gives you secure footing and can make an old tramp last a hundred years because it only droops a little. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Just my thoughts regards
Posted By: ajnawrocki Re: solcat 18 traps - 06/14/08 02:06 PM
I am here to revive the SolCat thread. Hopefully some of the original contributors to this thread are still around....
I rescued a Sol Cat 18 a few weeks back and have been able to piece her back together. I was able to still get new rigging and a tramp from Salty Dog, and score some used dagger boards in decent shape for spares.
The rudders were complete garbage so I fitted a complete rudder / tiller setup from a H16 to the hulls. This was a bit of a challenge as I had to fabricate new grudgens and tweak the tiller, but over all they seem to work very well on the boat. (On a side note, I have the original rudder castings, grudgens, and tiller parts if someone is looking for replacements / spares)
We got her on the water last week in light air and she sailed well. Ran into two snags however. She is taking on more water than I would have accepted as normal in both hulls and the dolphin striker which was damaged by previous owner tailoring actually broke when putting her on the trailer.
I am making a new spar for Dolphin Stiker as no spare could be found. Only place that in my mind she could have leaked that much was through dagger board wells. Can anyone tell me if this is common on these boats?
One last question, I had one person tell me that they believe that is was common for masts to snap under high wind conditions and that diamond wires should be added to this boat if we plan to sail her hard (we do). My mast does not have diamond wires, and as far as I can tell, never has. Can anyone confirm the Sol 18 Mast as being problematic, and have any recommendations for retrofitting diamond wires? I understand the very basic physics concepts behind how these would strengthen the mast, but up till now have only owned / sailed H16s.
Thanks in advance for any help.
Posted By: DaveFoster Re: solcat 18 traps - 06/16/08 03:40 PM
Hey, i have some Sol Cat 18 parts if you need them. ...
Posted By: ridge_pilot Re: solcat 18 traps - 06/18/08 05:10 PM
Put the SolCat in the water last week and did a nice easy shake down cruise with no problems. Went out after work last night in gusty 0 to 20+ hammer gusts. Heard a few pops out on the water which I knew could not be good from past experience. Popped the forestay bridal attachment out of the port hull (the bolts held, but the bar up under the lip of the hull popped through leaving a pretty good hole). Also snapped aluminum bar on the dolphin striker. The bridal attachment is going to be a challenge to fix, does anybody have any good ideas?
Ajnawrocki, I may be interested in you rudder castings and hinge pins. Shoot me a pm if you are interested in selling them.
About the mast, I have not snapped it in 20 yrs, and sail a lot in wicked gusty conditions. But if you are sailing ocean, or a lot of heavy swells it may be worth beefing it up.
Posted By: ajnawrocki Re: solcat 18 traps - 06/20/08 02:39 PM
ridge_pilot - I PMed you but I think the PM did not go through. It is not showing up in my sent PMs.
E-Mail me if you are interested in the rudder castings.
ajnawrocki_at_gmail.com
Posted By: Oldbaldie Re: solcat 18 traps - 06/20/08 09:41 PM
Ajnawrocki,
I owned a Sol Cat from 1974-1986 and can answer some of your questions. Yes the boat does have a tenancy to take on water if it isn't "sealed properly. There is a way to find them and works the best if the boat is dismantled, but you can try it with the boat assembled.
Take a vacuum cleaner or other source of LOW pressure and blow it into the drain plug. The hulls will expand slightly. Then apply soapy water all around the hulls. You'll see bubbles at all leaks. Mark where the leaks are then dry the boat real good. Then turn the vacuum cleaner around so it sucks air out of the hulls, and while its attached, apply silicone sealant to the leaks. The vacuum should draw some of the sealant into the crack/seam.
I used to do this and only had a little bit of water in the hulls after a hard day of sailing/racing.
The Hulls flex when sailing, so when you are coming off a gust and the boats slows down, the hull will expand to normal and suck in water. I found that its the edge of the top deck that draws in a lot of water.
Sol Cats did not come with spreaders, at least the ones I saw, I had mine out when it was really blowing like stink and never had a problem.
What was the sail number of your boat?
If you have any questions, just let me know.
Charlie
Posted By: ajnawrocki Re: solcat 18 traps - 06/21/08 05:49 PM
Thanks for the vacume in sealent tip,I have not heard that method before but it makes sense. Might not try it until this winter. We plan to disassemble and give her a new paint job.
Well, two votes of confidence on the mast, I think I will sail her hard (as soon as I get done repairing the dolphin striker) and see what happens. Can always chenge the mast to a TheMightyHobie18 setup at some point in the future if it all goes to heck. We usually don't go out until we have 15 MPH + winds and that gets us 3' - 5' swells on Mille Lacs.
We have a non original sail on the boat, with a faded 776 on it. Who knows......
Posted By: Oldbaldie Re: solcat 18 traps - 06/21/08 06:29 PM
Ajnawrocki,
Couple of tips before you go out on the heaver days. Make sure the rigging is really tight. We found that when racing in 3-5' swells, the hulls would flex and some boats would start to crack across the deck right in front of the main cross member if the rigging wasn't tight. Tight rigging will reduce the flex.
Second item, when sailing in heavy air, do not set the jib blocks to the very inside of the track when going upwind. With that setting the mast will flex and close off the slot, screwing up the air flow. Set the jib blocks at least 6-8" out. This allows you to trim the jib without closing the slot.
My dolphin striker started to crack in the center where the dolphin striker bolt went thru.
If you are going to wait until Winter to really seal the hulls, I would strongly suggest that you put sealant along the edge of the deck,now. Where it curves over the hull and faces down. Not the seam between the hull and the deck. Just apply a bead of silicone along the edge, and push it in with a blade or finger.
My sail number was 1210.
Charlie
Posted By: ajnawrocki Re: solcat 18 traps - 06/21/08 09:20 PM
Thanks for the great tips! My buddy and I are pretty stoked to get the dolphin striker fixed and back on the water. I'll take a crack at the sealent and see what happens.
Here is a picture of her the first day we took her out this year two weeks ago. We discovered the broken dolphin striker when taking it off the water. I hope to finnish making a new post this week.
Posted By: Oldbaldie Re: solcat 18 traps - 06/22/08 12:37 AM
Looking Good. Makes me wish I didn't sell mine.
Noticed the wrinkles in the main luff. When I got my boat I had that problem and no matter how much down haul i put into it, I couldn't get them out. Seems it was a defect, the bolt rope was to short. Took it to a sail maker that added a section to the lower portion of the rope. Worked like a champ.
If you have any other questions and want to contact me directly feel free.
c_oerter@bellsouth.netCharlie
Posted By: ajnawrocki Re: solcat 18 traps - 06/22/08 04:02 PM
I don't think the sail is right/original for the boat. There is an aftermarket sail makers patch on it (can't remember who's off the top of my head) and the bolt rope is just a tad too small. Getting the sail to feed is a PITA because if you don't have a second person guiding it into the slot it starts to bypass the slot and jam as it approches a batten pocket.
If we get all the other wrinkels worked out we may buy a new sail in the next year or two.
Anyone have an oppinion on replacing the halyard cable with line? The current halyard does not have the locking stop on it like my H16 did and the cable is frayed in one spot which is nice on the fingers.....
Posted By: Oldbaldie Re: solcat 18 traps - 06/23/08 03:42 AM
I purchased my boat brand new and the bolt rope was to short. When I contact Sol Cat about it they told me to either send the sail back to be repaired, or cut the threads that attached the rope at the clew, and allow the sail to stretch past the end of the rope, Since I didn't want to wait weeks to send the sail back, and didn't like the second option I took it to a sail maker. Somehow they attached an extension to the existing rope. If the sail is in good shape, I would take it to a local sail maker to get their opinion.
As far as feeding the sail into the slot, I had that also. I folded my sail, and didn't roll it up. Placed it closed to the mast and with one hand pulled the halyard, and the other fed it into the slot. Don't think a new sail will cure that.
Now for the Halyard. DON'T use line. Replace the cable and put a swage fitting on it to catch the "hook" on the forward side of the mast, top. There are a couple of reasons why you want to hook the halyard at the top. First, line stretches, so you will never be able to get the down haul adjusted correctly. When strong winds/gusts hit the sail, the line will stretch, altering the sail shape, and not in a good way.
The second reason is by using line, and pulling the halyard tight and tying it off at the cleat, it will bow the mast to one side, (think of a bow and arrow).
You have a performance boat, but the performance can be stripped out of it if not setup correctly.
Charlie
Posted By: ajnawrocki Re: solcat 18 traps - 06/23/08 01:25 PM
Makes sense, thanks again for the great tips!
Posted By: Oldbaldie Re: solcat 18 traps - 06/23/08 03:58 PM
Here are some old pictures I had of my boat. Looking at the main, my sail had 9 Battens that were parallel to each other, while your sail had 10 and were angled towards the top.
So the sails are different, don't know if they made a change, or you have after market sails. But who cares if they work.
Happy sailing.
Posted By: ajnawrocki Re: solcat 18 traps - 06/23/08 10:49 PM
Nice looking boat. I guess I have found myself wondering if it is an aftermarket set from an TheMightyHobie18. The day we wend out air was light, and she still was suprisingly quick compared to the H16. I hope to have her back out this weekend.
Posted By: ajnawrocki Re: solcat 18 traps - 08/26/08 12:51 PM
Well folks, there is one less sailing Sol Cat in the world. Some heavy air sailing somehow managed to swamp a hull und rupture when trying to get her off the water. After sealing every spot we could find and having her come in twice almost completely dry I have no idea what happened. Starting to believe she was a cursed boat. I found a great deal on an TheMightyHobie18 and am not looking back.
I have already disposed of the trailer and bare hulls, but I have a huge stockpile of parts and spares, including a mast, a never used tramp, new rigging, 4 dagger boards, sails, and the H16 Rudder Conversion I built. I am going to try to recoop as much money as possible by selling the parts. E-Mail me if there is anything specific you need @ ajnawrocki *AT* gmail.com
Posted By: Breakwater Re: solcat 18 traps - 08/26/08 04:17 PM
Trampoline Trampoline!!
Posted By: Oldbaldie Re: solcat 18 traps - 08/28/08 08:38 PM
Ajnawrocki,
Sorry to hear about your boat, especially after you put so much work into it.
Charlie
Posted By: ajnawrocki Re: solcat 18 traps - 09/05/08 09:21 PM
What are you gonna do? Old boats, you never know............ She was fun while it lasted. I have so many spare parts that if another came along...... who knows.
Posted By: Mpls_Nacra Re: solcat 18 traps - 09/06/08 12:22 AM
Sorry about your boat. My Sol Cat Died an ugly death as well.
I have some parts left over as well. ....
Posted By: Adrianvh Re: solcat 18 traps - 10/12/08 12:06 PM
Howdy guys.
Just got my first cat and its a solcat but a 15 not an 18. Picked up dirt cheap and it was a fresh water boat that sat under a tree for 8 years. Great condition once hulls were given the spit and polish.
Just letting you all know this page has been a huge help.
Thank you all!
